A31p - a decade later (LONG)
R, A, G and Z series specific matters only. NOT for AMD-Ryzen.
Re: A31p - a decade later (LONG)
#151 Post by ajkula66 » Tue Oct 24, 2017 6:29 pm
Hierax_ca wrote:
Tue Oct 24, 2017 4:36 pm
Still a pleasure to work on a quality machine like this! It's dated but still great!
Hey you run Debian and I use mine with Ableton and Roland/Boss recording software. Not bad for an antique.
FlexView AARP club members:A31p, T43pSF, X60T
Abused daily: T520, X200s
Thinkpad4by3
#152 Post by Thinkpad4by3 » Tue Oct 24, 2017 6:54 pm
Not an antique yet(atleast in my eyes). Soon enough. When the it turns 20, well call it antique.
micrex22
#153 Post by micrex22 » Tue Oct 31, 2017 9:04 am
ajkula66 wrote:
Sat Jun 01, 2013 11:47 pm
I’ll keep on using my A31p on daily basis until the support for XP ends in 2014. After that it will enjoy semi-retirement as a Linux box and a typewriter with the best screen that the world has ever seen.
http://www.thinkwiki.org/wiki/Category:T41
http://www.thinkwiki.org/wiki/Category:A31p
Hey George,
So I installed ArcaOS (OS/2) on my T41 and got youtube working (while the CPU was pegged at 100%, it could still play videos). If the T41 can run a lot of current-world applications, the A31p should do a better job as the specifications are technically better than the T41.
Something to consider if you want to take it from 'typewriter' status to 'usable for modern things still' status.
Also, OS/2 has the advantage of still being able to run DOS and other stuff. Which is cool.
Moderator
Moderator
#154 Post by dr_st » Tue Oct 31, 2017 9:22 am
It's the opposite. In the CPU department, the T41 is much better (don't make the mistake of thinking a Pentium M is anything like a Pentium 4-M), and in the GPU department they are more or less equivalent, depending on the exact GPU in the T41. Neither is pleasant to use in a modern environment, unless your definition of a modern environment is OS/2 (?!) and "watching low-resolution Youtube videos, taking great care not to breath on the laptop, lest it gets overloaded and stutters".
Thinkpad 25 (20K7), X1 Carbon (20HQ), Yoga 14 (20FY), T430s (IPS FHD + Classic Keyboard), X220 4291-4BG
X61 7673-V2V, T60 2007-QPG, T42 2373-F7G, X32 (IPS Screen), A31p w/ Ultrabay Numpad, A21m 2628-GXU
kfzhu1229
#155 Post by kfzhu1229 » Wed Nov 01, 2017 12:01 am
It's not so much that A31p is any better than T41 or anything performance-wise, as a T41p's 9600 + Pentium M demolishes the FireGL V7800 + Pentium 4-M in A31p, and both share the desoldering problem. It's so much that A31p is the last A series computer ever made that made it worth collecting, as A series have all the perks such as comfy keyboard, good display, excellent speaker, two drive bays, etc.
T23 PIII 1.13ghz 1gb W7
T43 15" 1.86 XGA 2gb fp W7
T530i 15.6" i7 16gb fp W10
Flexview UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10
edik
#156 Post by edik » Thu Nov 02, 2017 7:21 am
Arguably the A31p was the last of the great Workstations imho... can't be compared to the T series (although the ultimate classic TP "almost" Workstation must be the T43p)... yes slower everything but built as a workstation should be built.
Suspect that the W70X wasn't hugely successful (2008-2010?) and that really was the end of the big beasts in the ThinkPad line, don't know why,the W 17" series (especially the Dual Screen version.. amazing) were class machines. About the same time Apple also discontinued their 17" line.
2018: T550/16/IPS 3K Touch/72Wh
2007-2018: T450, T520/i7-2760QM/8GB/320GB, WSXGA+, X200s, T500, A31p, A30p, T42p, X60s, X32, X31
Gone but not forgotten 1998-2006: 2006 T43p 2668-H2G (2GB/60), T22 2648-8EG (128/20) 2005 X40, X31 2004 T30 SXGA+, 600X, 2003 770 P233+DVD Card, 760XD 1998 760XL+104MB
wujstefan
#157 Post by wujstefan » Fri Nov 03, 2017 7:06 am
You should have in mind that it is the workmanship that made those A-units shine. When I recover I will be back building mine, at least just as far as I will be able. A workstation, shield and cutting board, all in one, and with the best display/keyboard available at the time.
T-series were the "slimline", while A-series were those to wield the power. No match with T41p performance-wise? Well try to convince your eyes thet they prefer T41 display vs A31p's Flexview. I can stare at those displays. With no pain, but joy.
As for W70x, I guess that it was a failed project. Those units were no match for both Elitebook and Precision 17" series workstations from HP and Dell respectively. Especially pointing at HP units. Just a small offtop.
(stable under reduction)
Moderator
Moderator
#158 Post by dr_st » Fri Nov 03, 2017 11:00 am
In T42 generation, though, the 15" high-res IPS panels were finally added to the T-series, when IBM realized that there is demand for slimmer workstations.
kfzhu1229
#159 Post by kfzhu1229 » Fri Nov 03, 2017 1:26 pm
Well, back then when only the A3x series carry the best displays, A3xp are considered as the bulky workstations. fast forwarding to today, after 1.5 decades, the form factor of T4x is considered as bulky by non-computer geeks, thanks to the light and thin ultrabooks. I am still not a fan of them, because I am the type of person who prefers bigger, more powerful and more comfortable devices more than smaller, lighter and more portable ones, and the value of ultrabooks really don't attract my eyes - as you can build your own desktop with the same performance or more and with more comfort for less than 1/4 of the price!
Flexview UXGA:
micrex22
#160 Post by micrex22 » Wed Nov 08, 2017 1:40 am
Unfortunately I couldn't find any benchmarks against the two CPUs, and I don't have a 2.6 Ghz mobile 4-M to do my own benchmarks.
http://www.cpu-world.com/Compare/674/In ... 291M).html
https://ark.intel.com/products/27363/Mo ... 00-MHz-FSB
https://ark.intel.com/products/27578/In ... 00-MHz-FSB
The only real disadvantage the 4-M has is is 512KB of L2 instead of 1 MB. Compared between the two CPUs the Northwood nearly has an extra gigahert in clock speed courtesy of its pipeline ;). While Netburst can perform better than what people remember (as the architecture is verbally bashed more than actually used), I cannot confidently say it will outperform Banias; but I wouldn't expect it to be less than on-par. Although perhaps the 3.8 Ghz Prescott I have has caused some complacency in my estimate.
I just have a T41, but OS/2 won't be used for CAD work so it's probably not necessary anyways ;)
Moderator
Moderator
#161 Post by dr_st » Wed Nov 08, 2017 2:57 am
You don't need benchmarks. Plenty of us have first-hand experience with these CPUs.
You cannot just compare raw specs of CPUs of completely different architectures.
It won't and it won't. 1.7GHz-1.8GHz Dothans are roughly on par with 2.8-3.2GHz Desktop Northwoods (the 800MHz FSB, Hyper Threading variants). That's from my personal experience as I own such systems and compared them back in the day.
Now, a Banias is slightly less efficient clock-per-clock than a Dothan (maybe 10-15%) due to the smaller cache, but that's about it. On the other hand, 400MHz FSB P4-Ms are also less efficient than the 800MHz ones, and they top out at lower clock speeds.
I imagine that if you take the lowest-end Banias available on a T41, and compare it to the highest end 2.6GHz P4-M that you could stick in an A31p (none of them left the factory with such a CPU, mind you), you will find that the P4-M is roughly on par, yes. But across the entire lineup, comparing average performance, the Pentium M will be miles ahead.
#162 Post by ajkula66 » Wed Nov 08, 2017 11:22 am
Indeed, although some of us are getting rusty... :D
Back in those dim, dead days we owned a top-spec'd T30 (2.4GHz CPU/2GB/7200rpm HDD/SXGA+) which was our "move around the house" machine. When the first T40 came along, a love affair with its lightness and battery life started immediately. Not with its lousy XGA panel, though, so it soon got replaced with a T40p.
Apples to apples, that T40p pretty much ran circles when compared to T30 in boot time and overall responsiveness, all other aspects of the equation being equal. And that was with a measly 1.6 Banias.
That's pretty much my take on the situation as well. Going from Pentium 4M to Pentium M was one of the biggest jumps in overall performance of the ThinkPad range according to my own - possibly flawed - memory lane.
On a sheer workstation level - when it came to expandability and user comfort - A31p still ruled the roost back then, no questions asked. I was happy to compromise and lose a bit of "ooomph" when it came to having a stationary system that ticked all the other boxes perfectly well. More than a decade later, that's simply not the case anymore although I'll admit that I'm beyond thrilled to be able to have fun - even limited - with my A31p once again. Bless the good folks at Ableton and Roland for keeping up with the support for XP is all that I'm going to say...
jaspen-meyer
#163 Post by jaspen-meyer » Wed Nov 08, 2017 2:31 pm
I've never seen an A31p but what I get from this thread is it has:
Great speakers. Great screen. Great keyboard.
What sort of work could it do which a T41 couldn't?
lophiomys
Contributing Member
Contributing Member
#164 Post by lophiomys » Wed Nov 08, 2017 2:34 pm
It could serve as a bullet proof vest.
Lophiomys
#165 Post by ajkula66 » Wed Nov 08, 2017 2:45 pm
It was simply more expandable, given its two bays as opposed to one on a T4x. Back in those days the hard drives were small, and the ability to shove in an extra HDD while keeping the DVD was a great option. Quite handy for copying stuff from one disk to another as well.
Thinkpad4by3
#166 Post by Thinkpad4by3 » Wed Nov 08, 2017 3:29 pm
The world of mSATA has made life so much easier :) .
kfzhu1229
#167 Post by kfzhu1229 » Wed Nov 08, 2017 9:14 pm
now this is the fastest way to copying large files to and from my A30p without a PCMCIA USB 2.0 adapter, thanks to the snail speed of USB 1.
I personally use the left slot for battery to extend the battery life of my A30p (right slot will NOT connect batteries) and the right slot for my CDRW/DVD combo drive.
Flexview UXGA:
initself
#168 Post by initself » Thu Nov 29, 2018 8:59 pm
kfzhu1229 wrote:
Thu May 05, 2016 5:15 pm
For A31 at least it still does run the latest browser, for A30, only these Chinese browsers which still give support for XP and IE11 works for latest version due to the lack of SSE2.
Which browsers are those? How do I get a hold of them? They are up to date and work on Windows XP? I heard Chinese companies are moding Chromium for XP...
Thinkpad T60p XGA
TPFanatic
#169 Post by TPFanatic » Fri Nov 30, 2018 1:22 am
Slimjet works on XP, I have it installed on my Z60m running XP SP3 and it breathes new life into the machine.
lenovo T420 i7 2670qm 16GB QHD + eGPU GTX 960
lenovo T430s i5 3230m 16GB QHD w/ optimus(RIP), lenovo T430 i5 3320m 8GB FHD, lenovo T500 P9700 8GB WUXGA(LED) w/ switchable graphics
Enable 2 finger scroll on old Synaptics touchpads with registry.
kfzhu1229
#170 Post by kfzhu1229 » Fri Nov 30, 2018 2:04 am
Well, for science I still have a copy of 360 browser from late 2017 at earliest that is on my ThinkPad 600 running Windows XP with PII 266Mhz and unofficial max 416MB of RAM.
Obviously it is slow to a crawl but it still worked when I connect the computer to internet half a year earlier as long as you have all the time in the world to spend on waiting.
And then a few years even earlier I was using Windows 2000, and I remember that Firefox 12 worked perfectly on Windows 2000 on that PII 266Mhz with everything finish loading within 2 minutes (slow but acceptably slow in my opinion judging by the age of that TP600).
Flexview UXGA:
priono2000
#171 Post by priono2000 » Tue Mar 26, 2019 12:14 am
Hope, someone will offer this classic unit to me :D :D
I will take care with full love
Now|T30 XGA|T41 XGA|T43 UXGA|T43p SVGA|T43p UXGA|
T60 XGA|T60 SVGA Flexview|T60p SVGA Flexview|T60p UXGAFlexview|T60pWUXGA
T601 UXGA FrankenPad
T61p WUXGA
W500 FHD|W700 WUXGA
X41t|X60|X60s|X61t|X200t|X220t
Dream|A31p/A30p|X300/X301
wujstefan
#172 Post by wujstefan » Fri Mar 29, 2019 8:36 am
Drop a post in the marketplace then :)
This is really one of my favourite systems. Sturdy, bulky, heavy, strong, equipped with Flexview screen... Boyoboy :D
friedrich-eugen
thinkpads.com customer
Re: A31p - a spare one
#173 Post by friedrich-eugen » Fri Mar 29, 2019 9:13 am
I still have two of them...
I had Windows 7 on one of them, but decided to go back to XP, using an ssd in a SSD-to-IDE converter
but I will not use it any more in daily service. It's a kind of memorial of my first steps into modding-light.
The second one I have is in principal the same kind 2.6 Ghz Mobil P IV, 2GB Memory, but I would have to test it,
whether it is still fully functional. (Keyboard: quertz) I think I have put a lot of spares in the dustbin... some I
should have, still
If somebody would like to have it and do some installation (CD's & drivers should be available) on it he is welcome...
to semd me a PM
-friedrich-eugen-
started with IBM-XT & AST-Ascentia (910N) in the 90ties, relying on Thinkpads (770X, A31P, T60-61P Frankenp.) until 2017,
now using TP W530 FHD (i7 Nvida 2GB, 32GB, 500GB & 1TB SSD), X230T (i7 32GB/500GB), Helix 2nd (M5-Y71 8GB) & Yoga 700-11isk (M7-Y65 (GB /1TB)
all Windows 10Pro
TheForgottenKing
#174 Post by TheForgottenKing » Fri Mar 29, 2019 5:32 pm
should have, still
to semd me a PM
Assuming it still works, how much would you want?
W701ds
i7-940XM
32GB DDR3
128GB SSD + 1TB HDD + ODD
FX 2800M
1920x1200 @ 17" + 768x1280 @ 10"
Dock + Wacom + Calibrator
Arc
#175 Post by Arc » Tue Apr 23, 2019 7:18 pm
Just snagged the A31p quickly off of eBay recently. Being patient paid off, because I saw a few erroneously posted regular A31's for absurd prices. It's preaching to the choir to say how glorious the screen is, and how nice the aesthetics of it are in general. But yeah, don't think I'd be able to daily an A31p. I guess it really is dual core or die these days, or at least Pentium M. My A31p came with 256MB of RAM though and a completely dead battery so that probably is a big problem, especially hearing that it will throttle without a proper battery.
Main two questions I got about this though, what fun stuff can you do with the S-Video input? And where can I get a relatively healthy IBM battery for it?
Lenowo [ X41t | X60s | X60t SXGA+ | W500 | X301 | X200s WXGA+ | X201t ]
ThiccPads 「 600 | 700Z | A21m | X22 | A31p | R52 」
[ Lifebook U810 | P1620 | P1630 ] [ iBook G3 Snow ]
Many others have come and gone!
ThinkPads are 👌
#176 Post by ajkula66 » Tue Apr 23, 2019 7:34 pm
I'm certain that I have a couple of working batteries left, but would have to look for them. If you can wait for a week or so...in the meantime remove the battery and run the machine on AC adapter only.
Never have I performed anything productive with the S-Video stuff. I remember my wife playing with it when we got our first one, but have no recollection what she did or did not accomplish at the time.
Thinkpad4by3
#177 Post by Thinkpad4by3 » Tue Apr 23, 2019 8:13 pm
VHS-backup? Maybe recording playing games from some old consoles?
micrex22
#178 Post by micrex22 » Wed Jul 10, 2019 10:47 pm
My T41 has the 1400x1050 display, it's pretty crisp and not awful by any means. The cheaper 1024x768 displays are definitely rather heartbreaking.
It's still possible that the A31p would beat my T41 depending on the situation due to the ATI Mobility FireGL 7800 with 64MB vs ATI Mobility Radeon 9000 with 32MB. But... that halved L2 cache is a real stinker.
wujstefan
#179 Post by wujstefan » Thu Jul 11, 2019 2:48 am
I have posted my ideas almost 2 years ago :D
T41 is still a very nice machine; I was rather aiming at the point that T were the slimline, while A were workstations. I believe the counterpart of A31p would be T23 or T30. Still, afaik T41 was offered only at 14,1" with TN panels.
TRANTOR1972
#180 Post by TRANTOR1972 » Fri Jan 24, 2020 2:13 am
I have a question!
What is the best WIFI card for the A31p? The most effective ?!
