DIGITALgimpus
It's impossible to tell before buying. One person may buy a model, and it works, you may buy the same model # from the same vendor, but get a different batch with a different firmware version which doesn't work.
That's the drag about all this.
Gotcha. That *is* a drag.DIGITALgimpus wrote:It's impossible to tell before buying. One person may buy a model, and it works, you may buy the same model # from the same vendor, but get a different batch with a different firmware version which doesn't work.
I suppose the safest way is to buy it (a drive) from the local brick & mortar store -- ensure they have a no clause, full refund policy -- and just try the thing out.
Thing is, though, it can sometimes be difficult to find an exact model of such a specialized item in stock at your local "Computers-R-Us" type establishment.
-CupOfJoe
FYI - It looks like cdw.com stocks the Seagate 7200rpm drives, and their return policy (according to the info on their website) doesn't state anything about a restocking fee.I suppose the safest way is to buy it (a drive) from the local brick & mortar store -- ensure they have a no clause, full refund policy -- and just try the thing out.
Anyone out there had any hands-on experience ordering from cdw.com?
-CupOfJoe
http://forum.thinkpads.com/viewtopic.php?t=20858
with the official firmware, there will be no warnning message
WD Raptor Hd advice/feedback
I know this is probably a shot in the dar, knowing it won't work, but i'm able to get a WD WD800 Scorpio 80 gb hd for 50 dollars brand new. Problem is, i tried this in my t43 and got the 2010 error msg. the hd itself is an EIDE, not a SATA drive.
Has anyone had any luck with this drive or should i keep the Fujusti drive in it that came wiht this machine? I just belive WD is a much better brand than Fujusti.
WD doesnt have any info for updating the firmeware on this device.
-B
does anyone else have this HD in their t43 machine and has it worked without any issues?
-B
DIGITALgimpus
This is debatable, as the Hitachi's are also said to have only ROM, which can't be flashed.messar wrote:http://forum.thinkpads.com/viewtopic.php?t=20858
May depend on the exact model though.
I swear that my solution is effective for any retail model. The only limitation is that the model must be difined in the FW.PRO file.DIGITALgimpus wrote:This is debatable, as the Hitachi's are also said to have only ROM, which can't be flashed.messar wrote:http://forum.thinkpads.com/viewtopic.php?t=20858
I guess that should be okay.
I have 7K100 with Firmware MCZOA40M and updated with MCZIA51A..
Everything works fine and great.
Thanks again Messar.
You may or should send this message privately to one of Lenovo/IBM CEO especially at Europe..(I heard one of them was very mad when he/she tried to upgrade HD with aftermarket one and saw the famous 2010 message and have to live with it)
T20, X20, T30, T40p 2373-G1A(Upgraded to 2.1 Ghz 765, 2GB Samsung DDR PC2700, HDD 72K60), T43 2668-4DA(upgraded to (replaced)MOBO w/ 128MB FireGL V3200, BMDC3, 2GB Crucial DDR2 533, Multiburner Plus, HDD 7K100)
CoolDragon
Where did you guys buy your 7K100 100G? I guess the probability of the same firmware will be bigger if buy from the same source.
Current: T43P-2687D5U: P-M 2G, 2G RAM, FireGL V3200 128M, 80G 5400 RPM(Will be 100G 7K100 when 2010 gone!), 15' UXGA, Multi Burner, Intel A/B/G, Bluetooth, 9 Cell, Fingerprint Reader, WinXP Pro
Previous: 390E, 600E, T23, X30, T40 ......
ZipZoomFly http://www.zipzoomfly.com (formerly googlegear). I bought mine back in January.
IBM X220 | T61p | R61e | T43 | Black Macbook | i5 Hackintosh | i7 iMac 27 | Dell 3007WFP-HC WQXGA
Non IBM option drive
Guys,
The reason you get an error when using non supporteddrives in the T43 machine 1872/2668 is that they both have a paralell to Serial bridge controller built in to the machines. Wehn using drives of non IBM/Lenovo option the machine warn the customer with the 2010 error that some instructions might not be supported on that actual drive when using specific serial ATA compatible software. So the machine works as designed.
I think most of us grasp the concept of the 2010 warning message (it's not a true error). Most of us doing this are willing to accept the risks in order to either have the fastest drives at our disposal, or because we want to keep a few more dollars in our pocket (or both!).
DIGITALgimpus
Re: Non IBM option drive
Many computers have this chipset. It's not at all uncommon. But only IBM laptops seem to have this limitation. I've been searching for another brand that uses the chipset and has such a limitation in place. To date I've found none.petroleum wrote:Guys,
I just ordered the seagate 80gb 7200 rpm that everyone's talking about. First I accidentally ordered the SATA version till I realized it was ata. I opted for the saturday delivery so I will have this ready to go by next week for my trip.
Thinkpad T61 7662-CTO
2.5Ghz
3gb ram
500gb 5400 Western Digital Blue
Thinkpad T60 2007-CTO
2.0 Ghz
2gb ram
320gb 5400 rpm
2.5Ghz
3gb ram
2.0 Ghz
2gb ram
320gb 5400 rpm
Seagate 80gb 7200 rpm drive came in today. Doesn't seem that much noisier to me than the 40gb 5400 rpm that came stock. I was able to install Windows with no problem. No firmware upgrades or hacks were required to get this baby to work.
Thanks for all the help finding this drive.
2.5Ghz
3gb ram
2.0 Ghz
2gb ram
320gb 5400 rpm
2.5Ghz
3gb ram
2.0 Ghz
2gb ram
320gb 5400 rpm
What (non-IBM) Issue?
I just put an Hitachi 100G 7200rpm hard drive into a T42 with no problems. No error messages, no issues. I cloned the old drive (40G) to the Hitachi 100G. This is the second Thinkpad I've upgraded HDD's on and have never had an issue. The prior one was a T23 where I replaced the orginal HDD with an Hitachi.
Hitachi was making all the OEM Thinkpad drives prior to the sale to Lenovo. The originals might have said IBM, but they were made by Hitachi. Has Lenovo started manufacturering their own drives?
Matt
DIGITALgimpus
kennethmgreen
I'm confused... Can you explain? Should we NOT order SATA?muffd wrote:I just ordered the seagate 80gb 7200 rpm that everyone's talking about. First I accidentally ordered the SATA version till I realized it was ata.
I just ordered a Seagate Momentus 7200.1 ST910021A 100GB drive from ZipZoomFly.com for my T43.
According to this article:
http://www.thinkwiki.org/wiki/Problem_w ... hard_disks
the ST910021A is supposed to work out of the box. That is the model number for the non-SATA drive.
Note that ZipZoomFly has both the SATA and the Ultra ATA version of this drive availabe. I ordered the Ultra ATA version (going by product number of page listed above - the SATA version is ST910021AS).
ZipZoomFly (model ordered)
Seagate Momentus 7200.1 ST910021A 100GB Ultra ATA/100 7200RPM Hard Drive w/8MB Buffer
http://www.zipzoomfly.com/jsp/ProductDe ... ode=101599
ZipZoomFly
Seagate Momentus 7200.1 ST910021AS 100GB Serial ATA 7200RPM Hard Drive w/8MB Buffer
http://www.zipzoomfly.com/jsp/ProductDe ... ode=101520
Was this a mistake? Should I have ordered the SATA version?
Sorry if this is a stupid question. I would appreciate any advice as soon as possible - I just placed this order yesterday, so I may be able to correct the mistake before they ship.
Thanks in advance.
DIGITALgimpus
kennethmgreen
OK, thank you for the response.DIGITALgimpus wrote:The T43 uses a standard IDE/ATA/IDE100/whatever hard drive.
NOT SATA.
There is an SATA bridge chipset
But my understanding was that an SATA hard drive would take advantage of an SATA bridge chipset.
If this is too esoteric to explain, I understand. It sounds as if I'll be fine with the hard drive I ordered, so I'm happy on that point. But if you have time to explain this more, I'm interested.
DIGITALgimpus
SATA has a different connection... not sure how that would work. Nor have I read of anyone doing that.
The T60 uses SATA and can take advantage of the chipset.
The T43 has a bridge chipset, so it can use standard IDE drives, but it appears to the OS as a SATA drive.
christopher_wolf
- Special Member
The T43 has, for the Primary Drive, a SATA-PATA bridge with a SATA Controller; it appears to anything going through the controller and associated protocols as a SATA device. The drive, though, is PATA.kennethmgreen wrote:OK, thank you for the response.DIGITALgimpus wrote:The T43 uses a standard IDE/ATA/IDE100/whatever hard drive.
NOT SATA.
SATA II supports certain functions, such as native, this is on the hardware level without a HAL running on top, hotswap and command queueing that PATA doesn't support.
The SATA connector is keyed too, as well as slimmer and smaller than the PATA connector.
HTH
~o/
She does the things you do.
But she is an IBM.
~o/
But she is an IBM.
kennethmgreen
Thanks - that explains it pretty well. What is the advantage of this? Is it just a matter of compatibility?DIGITALgimpus wrote: The T43 has a bridge chipset, so it can use standard IDE drives, but it appears to the OS as a SATA drive.
Thanks for the explanation. This stuff is just barely within my brain's grasp, though...christopher_wolf wrote: The T43 has, for the Primary Drive, a SATA-PATA bridge with a SATA Controller; it appears to anything going through the controller and associated protocols as a SATA device. The drive, though, is PATA.
HTH![]()
For anyone following along, I found these pages helpful:
PATA: http://en.wikipedia.org/wiki/Parallel_ATA
SATA: http://en.wikipedia.org/wiki/Serial_ATA
DIGITALgimpus
I believe it was done for cost and supply issues. SATA 2.5 inch drives are still somewhat new, and availability is more limited than IDE drives which exist in more quantities than demand requires.
Re: I dont think I'll wait on lenovo... so which drive work
I have the T43 2686m6u and just purchased the Hitachi HTS721080G9AT00 - 80 GB 7200 RPM and also have the 1.24 bios. I didn't think the bios update worked. But if I wait a few seconds after the initial 2010 error, I do not have to press the ESC key and the computer continues on after the 2010 error. I am having a little difficulty with the procedure to flash the hard drive firmware, but I will press on (having problems extracting the .img file). Besides the initial error, the T43 seems to work fine. I did notice a speed improvement from the OEM 60 GB 5400 RPM drive. The Hitachi drive is quiet and seems like a good buy. Newegg has them for around $160.barnickle wrote:I dont think I'll put my faith in Lenovo ever fixing this. It could happen but holding my breath seems a waste.
So, what 7200 RPM drives WILL work in my t43? I have a T43 model 266875U running firmware 1.03 and BIOS 1.24 (1YET59WW). I dont want to buy one of the mega-pricey Seagate drives (the 100Megger is $300!) but any 60-80Gb would be fine. As well, if you have one working can you let me know where you bought it? I generally use the almighty newegg.com but in this case I really just need it to work. I can't see downgrading my BIOS as anything but a invitation to disaster.
Anyway, any input would be great. I have a brand new laptop and am now holding one 60Gb 7200rpm drive that must be used in the ultra bay. I dont want to end up with two. If you've had good luck with a fast drive please let me know the make/model/part number and your t43 model and bios.
mb
I have to say, the T43 was a bit more money, but it is really a premium product compared to the Dell's we buy at work. The bundled software, construction and this forum make me a happy customer.
T43 - 2686M6U - 1GB - 7K100 80GB - MINIDOCK
- indi jey
- 778 Views
Last post by zap 1
Mon Jan 02, 2017 8:27 am
- 1364 Views
Last post by TonyJZX
Tue Feb 07, 2017 2:44 am
- 976 Views
Sun Feb 05, 2017 3:13 am
- 1192 Views
Last post by yakuza
Sun Feb 05, 2017 2:39 pm
