yes using it as my main non work laptop even now. no problemsAcheron wrote:Two years ago !!! A few Linux upgrades later the old T42 is still going well. Lately it has been spending its time as a music server.
Hope everybody's T42 is still finding a productive purpose in its old age.
Successful upgrade of T42 with Crucial M4 128 GB mSATA SSD
Re: Successful upgrade of T42 with Crucial M4 128 GB mSATA SSD
Mac-Chatter
Hi folks!
I just inserted in my T41 a 128GB SATA SSD with PATA adapter to replace the Samsung drive. Now I also face the UDMA 33 issue. The tool DriveInfo states the SSD supports up to UDMA 6. For he controller there is only a "yes" for UDMA 2. I did the reinstallation of the driver without success.
What is your recommendation:
- change the PATA-SATA adapter (For some reason I have a second spare one)
- update BIOS and enabler (btw:is the enablre automatically updated with the BIOS update?)
- any other, simpler way to enforce UDMA 5+ ?
That's what I have:
- My Bios is original 3.05a with corresponding enabler (3.01?).
- Controller 82801DBM Ultra ATA Storage Controller - 24CA;
- Driver: 4.0.1001.0 (by DiskInfo)
OS: Windows XP by consecutive cloning from the original Disk. Still the old company XP with full Office '97 is installed. I have no install disks.
Looking forward your comments & thanks, Mac-Chatter
That's what I have:
Working Vintage Stuff:
ASUS X72N, WinVista-32; DualCore 2,5Ghz; RAM 6GB; SSD (SATA): 480GB; Gavotte RAMDISK: ~2,5GB (PAE) for pagefile
IBM T41; XP-Pro; RAM: 2GB; SSD (IDE=>SATA):128GB; RAMDISK: 760MB pagefile
Medion 95400; XP-Home; P-1,7GHz; RAM: 2GB; SSD (IDE): 64GB; RAMDISK: 760MB pagefile
Welcome to the Forum.
Your BIOS is rather old.
Follow the Drivers link at the top of this page to get the latest BIOS 3.23 and EC 3.04 for your T41
They need to be updated separately, EC first, then BIOS.
I'll leave the drive-talk to others.
Re: Now I also face the UDMA 33 issue.
Tag Mac-Chatter!
Do me a favour, and help us all (You will be adding to public community knowledge!), by trialling intermediate BIOS revisions before you install 3.21 or newer. Install one or more revision from between 3.14 and 3.20 inclusive, then observe PATA bus speed and let us know result.Mac-Chatter wrote:That's what I have:
Mac-Chatter
Moin,
Thank you for your warm welcome! I progressed, but I'm not done yet.
Updating to BIOS 3.2.3 and Enabler 3.0.4 helped. The controller states a UDMA5 connection. ChristalDiskMark shows some 80MB/s for 512bit access and over 20MB/s for 4KiB access. This read/write performance is well acceptable I think.
Sorry Automobus: I have read your post too late and updated directly to BIOS 3.2.3 and Enabler 3.0.4.
I continuously struggle with "Suspend to RAM" and "Suspend to Disk"
even though I performed a complete Checkdisk. The 'shut down' of "Suspend to RAM" and "Suspend to Disk" seem to work as normal. But, the wake-up after "Suspend to RAM" ends with a dark screen (no light a all) while the "On-Sign" next to the battery symbol is bright. The cooler fan also runs. Restarting after "Suspend to Disk" the screens finally stops and shows the ANSI windows bar when the hypernation file is entirely loaded - and a final beep sound occur. Both suspend issues are not a result of the BIOS update. I never had this kind of troubles with my earlier mechanical Samsung HDD.
Any ideas how get the "Suspends to RAM/Disk" working?
Thanks, Mac-Chatter
Thanks, Mac-Chatter
Hibernation (suspend to disk) should be switched off and set to "never" if you use an SSD.
Sleep (suspend to RAM), if you do this while on battery, you risk losing any unsaved data if the battery gets empty.
Fn/F4 puts it to sleep, pressing the Power button should wake it up.
If your screen stays dark, check your Powersaving settings.
Windows XP is rather old, replace it with a Linux distro.
Mac-Chatter
Pressing FN/F4 for sleep mode and press POWER for wake-up is eactly what I have done.
=> What particular powersaving settings shall I look for?
Linux is not an option for me
Btw. on a different vintage Laptop with an IDE SSD "Suspend to Disk" works very well
(and of course "Suspend to RAM" too).
Thanks, Mac-Chatter
Thanks, Mac-Chatter
T420: mSATA SSD performance issue [SOLVED]
by Farro » Tue Mar 07, 2017 3:56 am » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 984 Views
Last post by jaspen-meyer
Tue Mar 07, 2017 5:00 pm
Story about a x40 msata ssd, pata chinese adapter and southbridge...
by silca80 » Fri Mar 31, 2017 3:06 pm » in ThinkPad X2/X3/X4x Series incl. X41 Tablet - 6 Replies
- 587 Views
Last post by silca80
Sat Jun 24, 2017 7:04 pm
T430: Any disadvantage to using mSATA SSD besides slightly slower OS launch?
by serpico » Tue Apr 11, 2017 3:53 pm » in ThinkPad T430/T530 and later Series - 10 Replies
- 878 Views
Mon Apr 24, 2017 4:46 am
Does it make sense to use mSATA SSD for data partition?
by serpico » Wed Apr 19, 2017 9:14 am » in ThinkPad T430/T530 and later Series - 11 Replies
- 610 Views
Thu Apr 20, 2017 12:36 pm
