Another update - This time on the T43
i'm sure there will be performance difference . but for the price you pay for a P model there better be a real Boost ....
Here are some numbers for you
Aquamark 3
GFX: 1893
CPU: 9830
Total: 17,263
3DMark 03 - 1911
PCMark 04 - 3163 (Im not 100% sure on this as i clicked the score away before i could write it down).
If you compare these scores to the T42P you can see that there is a noticable difference.
And my believe that the x300 chip is an inferior chip in regards to graphics performance is quite clearly shown in these benchmarks. It's almost 27% slower in the GFX score of the Aquamark, and a whopping 38% in the 3DMark. The sam results are found in the 2D tests i have done with the program i received yesterday. There's quite a performance difference. This fact alone is worth considering the P series over if you want a machine which will be able to handle things graphics wise in a few years time(Longhorn, new games etc.). The overall aquamark score is around 23% slower on the T43 than the T42P. And the general PCMark score is more than 24% slower as well. And with these results you need to remember that although the T42P has a faster processor it dosnt have as fast a bus or memoryspeed as the T43.
All in all i consider this a quite noticeable performance difference, and even though the T43 is cheaper priced i consider the T42P to still be the best option. Remember in this test the best option is not the cheapest but the one which gives you good performance now and proberbly a good performance in 2-3 years time at a good price and the T42P certainly delivers this.
Where i bought the machines the T43 costs 1950 euro and the T42P costs 2750. But for the 800 euro extra you also get 1 GB ram instead of 512 which will let you run mor programs at once much smoother(something the benchmarks dosnt test). You also get a much faster processor, which in normal office work dosnt make that much of a difference although the benchmarks actually show that it does give you almost 25% more. But if you use more than just a webbrowser and MS Office - For instance with programs like Photoshop, program development etc. then there is a very noticeable difference.
And on top of that you still get a much quieter machine.
But again - The result of this test all depends on what you use your machine for. If you only use your machine for a little webbrowsing, email, some office work then all the machines are MUCH MUCH faster than what you need. In that case you could use a three year old laptop and still have way more power than you need. And from that point of view the T43 is certainly a winner. But this test is mainly about finding the absolute best thinkpad available - although still looking somewhat at the price.
And if you do work like me which involves programming, databasedevelopment, photoshop work and generally have MANY programs running at once and you want a machine which can replace your desktop also in the gaming department then you can only consider the T42P and T43P in which respect the T43P wins from a purely performance point of view, but when you consider things like noise and batterytime etc. Then the T42P is the clear winner to me. It's got almost the same power as the T43P and in realworld tests in games both machines run games equally well and there is only a marginal difference in PCMark scores. So with the T42P with it's IBM WLAN card(in this config) you get a VERY quiet machine, which is very fast and which can run any game i have thrown at it at a very decent price. You get a machine which not only can handle anything you want done today but it sure will be able to handle most of what you throw at it in a few years time as well.
And in the graphics performance of the T42P you should also consider the fact that i have used the "official" openGL optimised drivers while the X300 has been using drivers optimized for games. If i where to use other drivers in the T42P i could proberbly get a better result in this department as well. And with the IBM card which constantly for days has been giving me 100% signal 10 meters away from my access point(through 4 walls) thats amazing stuff.
Since i've seen a few places where you can buy the T43P to the same price as the T42P - I would consider the T43P the winner if the noise hadn't been an issue(and it IS much noisier). Even if the room isnt completely silent you can still hear it and if it had a better batterytime.
After setting the CPU to dynamic switching with the Centrino hardware control software and setting the voltage at the lowest multiplier to the lowest possible voltage, the T43P could give me around 5½ hour of batterytime while the more or less as fast T42P could give me two hours more!! That is also a major plus if you use you laptop as an actual laptop
All in all the buildquality of all machines are excellent in every respect. The normal T43 had a slightly lower quality keyboard but that could just be a "monday" model, so i dont really consider that an issue - It's still much better than any other keyboard out there, so im talking about really nitty stuff.
So all in all they are all great machines, but the best buy is the T42P from the perspective of this test.
