Don't throw away your T4x, The new mobo is coming![Lots PIC]
Peptate
Re: Don't throw away your T4x, The new mobo is coming![Lots PIC]
#61 Post by Peptate » Fri Aug 23, 2013 10:49 pm
QWERTY Andreas wrote: You might be right on this one, but i don't have a T6x and T4x from the same time, so i can't tell. It is hard to determine, but you might be right. But i haven't had any problem on my TPs.
But ont he bottomline, both are extremely well build machines. I just can't get how the T4X is so much better than the T6X, because in my book they are below the T6x in some very important aspects.
When I say the T4x is better than the T6x, I'm not referring to the hardware specs. I'm referring to the materials used, the assembly and the aesthetics. The plastic used on the T4x seems like they sourced a better grade of plastic that feels denser and does not flex as much - In general, feels more "solid" instead of the "hollowness" felt in cheaper laptops. It's hard to describe, but I'm much happier holding my T43 than my T61p.
By far the biggest thing that does it for me is the keyboard. I used to think that all thinkpad keyboards were built the same, but that couldn't be farther from the truth.
In reality, it does all come down to personal preference. I'm not saying I'm right, but if the T4x had relatively similar specs to the T6x, there's no way it would still be in my collection. Keep in mind that I am biased though, as I feel that every generation of thinkpads released, there has been a noticeable decline in build quality. (and by build quality, I really mean the perception of touch - I acknowledge the T43 has southbridge issues and cooling flaws.)
Alas, I don't claim to be an expert in this area, but I do use both my T43 and T61p everyday. At the end of the day, they both handle my abuse equally as well.
IBM T42 (2373) | T43 (2668) | T60 (2768) | T61p (8890) | X61 (7674)
Debian & RHEL
Peptate
#62 Post by Peptate » Sat Aug 24, 2013 12:08 am
QWERTY Andreas wrote: They are harder to maintence.
I'll have to disagree with you on this one. IMHO once you disassembled enough thinkpads, they all start feeling roughly the same. A few extra screws doesn't discourage me. Replacing motherboards and backlight CFLs all stink equally across the generations.
QWERTY Andreas wrote: The hinges might very well be better on the T4x
Screen wobbles a bit on my T61p, none what-so-ever on my T42/3.
ajkula66 wrote: On T/R/Z 60, they're made to be broken.
I got a kick out of this. :)
Debian & RHEL
Orclas
#63 Post by Orclas » Sat Aug 24, 2013 1:51 am
Peptate wrote:When I say the T4x is better than the T6x, I'm not referring to the hardware specs. I'm referring to the materials used, the assembly and the aesthetics. The plastic used on the T4x seems like they sourced a better grade of plastic that feels denser and does not flex as much - In general, feels more "solid" instead of the "hollowness" felt in cheaper laptops.
Exactly! And the last parts sums it all up pretty good.
T61 (8895-2FG) T8100/Intel X3100/SXGA+/Intel 320 SSD/4GB/Win7 x64 Pro
T400 (retired)
T40 (semi-retired)
QWERTY Andreas
#64 Post by QWERTY Andreas » Sat Aug 24, 2013 2:51 am
I am reffering to the T6X as better than the T4x, i am reffering to the Construction of the machine. It doens't make sense to compare speed across generations ;)
But if you wan't to have a machine that "feels" nice, the MBP is a better choice. But even thought it feels better, its not better built :-)
Thinkpad W500 (2.53 GHz P8700, 4 GB RAM, FireGL V5700, WUXGA)
Thinkpad T61F 14" (2.53 GHz QX9300, 6 GB RAM, Quadro FX570m 256 MB, SXGA). Advanced dock with AMD Radeon HD7750
Custom build ITX desktop (i5 4590, 8GB RAM, AMD R7 260X, custom watercooling)
Thinkpad 8, Fujitsu F-07C
FS: T61F
Orclas
#65 Post by Orclas » Sat Aug 24, 2013 8:42 am
Taste is different and I can understand if someone thinks T6x is a better build. If you on the other hand would have said that T400 is a better build, I would have plain concluded that you're fully bonkers :D
Anyhow - does anyone have any perspective on heat dissipation if one compares an /undervolted/ Dothan and some of the cooler Core i processors? If we leave all the tech generation things (which a modern MB would solve) aside, the cooling system is after all the Achilles' heel of the T4Xs.
T400 (retired)
T40 (semi-retired)
#66 Post by ajkula66 » Sat Aug 24, 2013 9:05 am
Orclas wrote: Anyhow - does anyone have any perspective on heat dissipation if one compares an /undervolted/ Dothan and some of the cooler Core i processors? If we leave all the tech generation things (which a modern MB would solve) aside, the cooling system is after all the Achilles' heel of the T4Xs.
There are good news and bad news here...
The good news is that by eliminating ATi discrete graphics that were the main source of heat on (especially higher-end) T4x machines, we are making a step forward.
The bad news is that Arrandales run hot, period.
We'll see what issues need to be addressed once the board is actually grabbed by one of us, and we'll take it from there.
For now, let's just hope that the whole project reaches fruition and enters production stage...
lophiomys
Contributing Member
Contributing Member
#67 Post by lophiomys » Sat Aug 24, 2013 10:04 am
Count me in for a minimum of 2x new mobos
targeting 15inch T42p/T43p UXGA.
I currently do not know, which of my UXGA screens (operative and stock) have this EDID chip or not.
1st gen i5 is enough for me, with an emphasis on cool and silent.
(I do observe, that my T42p with single core 1.8GHz Pentium M and SSD on PATA/SATA adapter
offers the same speed in daily use, as a Win7 64 bit on an HP EliteBook with SSD.)
A docking connector (with drivers) would be a big plus for me.
If they should rebuild on used boards, I would have 3x T42p boards to contribute.
Keep up the good work.
Lophiomys
#68 Post by pianowizard » Sat Aug 24, 2013 10:13 am
ajkula66 wrote:As for build quality...the older I get, the less impressed I am with the T60 series build quality.
I am surprised to hear this. I had three 14.1" T4* Thinkpads (T41, T42, T43), and one 14.1" T60. They were all 2 to 3 years old when I bought them. All three T4*'s felt soft and had lots of flexes, whereas the T60 felt almost as strong as the T30 and the 600 series. I guess it's quite hard to predict how well a laptop will age.
On the other hand, the 15.0" T43p I had was much more solid than the 14.1" T4*'s.
#69 Post by ajkula66 » Sat Aug 24, 2013 11:12 am
I should've specified that my displeasure is primarily directed towards 15" (4:3) models. The frames crack like mad. The hinges are garbage. The plastics - all over the T6x range - age at twice the rate of T4x at the very least.
My experiences exactly.
Orclas
#70 Post by Orclas » Sat Aug 24, 2013 11:56 am
lophiomys wrote:1st gen i5 is enough for me, with an emphasis on cool and silent.
Same goes for my general usage pattern and where the difference between my old T40 and the T61 (with a C2D) mostly shows when viewing higher res flash content and such.
Running a bit ahead of things - since we don't know if a fully functioning MB will ever appear - I wonder if one could run the Core i's in something similar to the C2D LFM or SLFM mode to mitigate them running hot (since Ajkula say they do)? I don't have much knowledge about CPU technology myself.
T400 (retired)
T40 (semi-retired)
lanesharon
#71 Post by lanesharon » Sat Aug 24, 2013 12:07 pm
I also have a docking station and would like to be able to use it. The docking station allows me to have DVI connection and another usb port. Would have preferred HDMI, but hey, I will take anything I can get and be happy.
Take Care, Sharon
DaKKS
#72 Post by DaKKS » Sat Aug 24, 2013 6:25 pm
The prototype board has an HDMI port. Whether or not it will still be there on the final version is another question however.
Admittedly, google does a [censored] job of translating, but the board seems pretty solid. I've seen Gigabyte boards with more issues. And they are suppsed to be "pros".
Peptate
#73 Post by Peptate » Sat Aug 24, 2013 6:34 pm
DaKKS wrote: Admittedly, google does a *****Expletives removed by Moderator***** job of translating, but the board seems pretty solid.
Honestly speaking, if it was publicly for sale at the moment, I wouldn't think twice.
Debian & RHEL
Arturus
#74 Post by Arturus » Sun Aug 25, 2013 5:45 pm
So far, I don't think anyone would.
TonyJZX
#75 Post by TonyJZX » Mon Sep 02, 2013 2:36 am
i suspect this will not work in WS t61s
there's lots of 1,024 x 768 t40/t60s etc not the 1,400 x 1,050p ones are rare as
lophiomys
Contributing Member
Contributing Member
#76 Post by lophiomys » Thu Sep 05, 2013 5:06 pm
Two months since OP.
Anyone in command of the Chinese language has read any news concerning this on 51nb.com ?
Thanks...
Lophiomys
stevenvh
#77 Post by stevenvh » Sun Sep 08, 2013 8:37 am
I'm curious too, but actually am probably still going to offer up my old T42P for parts or modding.
If anyone is interested, PM me. It's 2379-DYU, bare bones, with failed SB/USB and some other issues too.
It does still boot and run, but not for much longer....Available to forum members for the cost of shipping.
cheers
T60P 2623 DDU
misfit
#78 Post by misfit » Tue Sep 10, 2013 2:51 am
I've only just discovered this thread and have a 15" T43p and a 14" T42p which I'd love to upgrade to these motherboards. I figure my T60s will be good for maybe a few more years before it starts becoming difficult to get drivers for newer versions of Windows...
I have subscribed to this thread and hope that there are Chinese speakers here who will be able to keep us informed.
(stevenvh, if it wasn't for the fact that I'm in New Zealand I'd be taking you up on your offer....)
Shaun.
T60 2007-72U [T7400, UXGA FV]
T43p 2668-H2M [FV]
T43 2668-84M [FV]
R52 1847-A18
T42p 2373-KXM [FV]
T42 2374-M97 [SXGA+]
R51 1829-E5C [FV]
R40 2723-BAM [SXGA+]
R40 2723-26M
X32 x 2 2672-CM5/W58
X31's x 8 Four working.
X30 2672-4HM
X24 2662-FMT
Etc.
posscakes
#79 Post by posscakes » Tue Sep 10, 2013 3:23 am
if copy in http://forum.51nb.com/ in google and hit translate this page you should be able to find and read the forum thread in english.
T23 (purchased for $20, built up from dead laptops. 1.2ghz cpu upgrade, wifi mini pci card and ufl jack mod. refuses to die)
T40 (dead in cupboard - gpu thing - inspired to fix after reading this forum!)
T410 (current flagship)
lophiomys
Contributing Member
Contributing Member
#80 Post by lophiomys » Tue Sep 10, 2013 9:21 am
I have checked the last pages of the T50 thread on 51nb.com
http://forum.51nb.com/thread-1352235-25-3.html
with google translate.
I seems that everyone is waiting impatiently and that HOPE is very busy.
Lophiomys
RMSMajestic
#81 Post by RMSMajestic » Wed Oct 09, 2013 6:54 pm
latest news
http://forum.51nb.com/viewthread.php?ti ... ra=&page=2
#19
昨天收到消息在安排贴片,应该快了,具体时间不好确定,但是确实是在安排生产,现在只能提供这么多消息。
SMT under arrangement, should be okay soon, can't really give an exact time but it's really under production.
51nb.com in English
http://forum.51nb.com/index.php?styleid=10&sid=BPtxrE
:lol:
BTW, could anyone please help me with this problem?
http://forum.thinkpads.com/viewtopic.php?f=30&t=111736
86turbodsl
#82 Post by 86turbodsl » Wed Oct 23, 2013 6:06 pm
Any updates?
T61p, RT61 frankenpad(the first), W500(s), T500, W700 (king beast)
petrovp
#83 Post by petrovp » Sat Oct 26, 2013 11:24 am
Too good to be true. Will be like a killer to all crappy laptops manufactured now a days.
Of course limited amount of people will be interested in this - like the members of this forum.
I hope for HOPE to get this mobo in production. Cheers.
skinnie
#84 Post by skinnie » Sat Oct 26, 2013 11:38 am
petrovp wrote:Too good to be true. Will be like a killer to all crappy laptops manufactured now a days.
If this comes to real I guess I would just buy a dead T4x to have "perfect" laptop.
Lenovo Thinkpad X230/12.5' IPS/i5-3320M/256Gb SSD/16Gb DDR3/Intel HD4000
Lenovo Thinkpad T410s/i5-560M/256Gb SSD/4Gb DDR3/Intel HD3000
PowerPC
#85 Post by PowerPC » Sat Oct 26, 2013 11:42 am
skinnie wrote:If this comes to real I guess I would just buy a dead T4x to have "perfect" laptop.
You and literally thousands of other users will suddenly do this as well, shooting the price of T4x units to the Moon.
I would advise to preemptively buy one now. Choose your screen format, buy the 15" inverter if you want a 14" unit and put it in a shelf.
#86 Post by ajkula66 » Sat Oct 26, 2013 12:40 pm
^^^^^^ An excellent piece of advice. The very reason I have three very decent 15" shells sitting and waiting... :twisted:
lophiomys
Contributing Member
Contributing Member
#87 Post by lophiomys » Sat Oct 26, 2013 3:11 pm
so do I,
We should nominate HOPE for the Nobel Prize!
This will be a lesson for responsible decision makers at Lenovo.
Lophiomys
ABuNeNe
#88 Post by ABuNeNe » Sun Oct 27, 2013 1:30 am
Does it have hdmi output?
current using t400 with p8400 2.26ghz processor, 8gb memory, 1288gb ssd, ... as a:
- media player (kodi)
- emulations (retropie)
- nas (2 x 4tb hdds connected to usb3.0 express card on gigabit lan)
previous
t43 with 1.86ghz processor, 2gb memory, 80gb ide hdd, x300 graphics, 1400x1050 display, ...
Medessec
#89 Post by Medessec » Mon Oct 28, 2013 5:56 am
Looks like the prototype mobos pictured indeed do have HDMI, where the S-Video port would be. Absolutely genius, if that does function 100%.
Ports-wise, it's quite minimal... but considering the board is 100% custom, and made from scratch, it's still absolutely amazing.
MEDESSEC
RMSMajestic
#90 Post by RMSMajestic » Fri Nov 01, 2013 7:03 pm
production nearly finish!!!!!
http://forum.51nb.com/thread-1407205-1-1.html
finally :lol:
but I guess we might have to wait for the next batch of motherboards :/ the first batch has only 200 ~ish motherboards only
I'm going back to China this Christmas and might bring back a few (<5) of those, if HOPE have no intention to sell those on ebay
Have faith in T4x :wink:
