the windows 7 drivers are generic drivers or did you find them on dell support site?rzamz wrote:
I've used that card with both Windows 7 64 bit and OS X with no problems. Never tried with Win 8 though
Mavericks on X220
Re: Mavericks on X220
I purchased the mini card. Does anyone know how to batch the bios? I am using single boot OSXmozso wrote:hello to all<br abp="840"><br abp="841">I'm thinking to patch my bios and buy this wifi card: Dell HALF-MINI WIRELESS N CARD DW1515 ATHEROS AR5BHB92 AR9280 MINI CARD.<br abp="842"><br abp="843">My x220 has 2 ssd's and triple boots os x, ubuntu and win 8.1 . As google gives me mixed feedback's, I thought better to ask then later to be sorry, anyone using this card in a thinkpad and a windows 7,8.x; are there good drivers for it and are there any problems using this wifi card on other systems then os x?
Update:
Thank you rzamz for the link. It works great. Got it to install in Windows environment.
Patched 1.39 can be found here, need to do it from Windows though http://www.bios-mods.com/forum/Thread-R ... 1#pid61441sn50 wrote:I purchased the mini card. Does anyone know how to batch the bios? I am using single boot OSXmozso wrote:hello to all<br abp="840"><br abp="841">I'm thinking to patch my bios and buy this wifi card: Dell HALF-MINI WIRELESS N CARD DW1515 ATHEROS AR5BHB92 AR9280 MINI CARD.<br abp="842"><br abp="843">My x220 has 2 ssd's and triple boots os x, ubuntu and win 8.1 . As google gives me mixed feedback's, I thought better to ask then later to be sorry, anyone using this card in a thinkpad and a windows 7,8.x; are there good drivers for it and are there any problems using this wifi card on other systems then os x?
Hi rzamz, Do you know whether Patched 1.39 works for both Wireless card and WWAN card or only for Wireless card?rzamz wrote:sn50 wrote:
appreciated for further information.
--- installed Patched 1.39 ----
Dell DW1510 is working. I put Lenovo Sierra Mc8355 Gobi 3000 inside, that does not require whilte-list remover. so it is also recognized, I will put Mavericks 10.9.3 on my x220
X61 T8300 4GB Lion 10.7.3
Author of the patch said wireless card only in http://www.bios-mods.com/forum/Thread-R ... AN-removaljzhang18 wrote:
My DW 1515 just arrived and happily report that is working nice out of the box on all my 3 OS's.
Currently running 10.9.1. and thinking to upgrade to 10.9.2. Does anyone have experience upgrading it with the combo update, run normally with the os x installer and before reboot install all drivers again like after normal post install?
Does anyone have WWAN NWL BIOS link? I want to flash my X220 to install both non-Lenovo WIFI and WWAN card.rzamz wrote:Author of the patch said wireless card only in http://www.bios-mods.com/forum/Thread-R ... AN-removaljzhang18 wrote:
Thanks in advance.
---never mind ---
I bought Lenovo Sierra Mc8355 Gobi 3000. Installed and works
does anyone managed working the VGA port on a x220?
Anyone made SD card reader working?
Picked up this card, but had a heck of a time finding the whitelisted BIOS. Here ya go:sn50 wrote:Anyhow, I purchased the Dell 1515 wireless N and installed on the X220. However, the laptop stop working cuz the bios doesnt recognize the wireless chip. Is there a working, verified, way to approach this? a safe bios?superkhung wrote:Yes brightness adjust u can use ScrLk and Pause key to change it.
For wifi buy a Dell 1515 Wireless-N, it work out of the box
http://www.amazon.com/DW1515-U608F-Wire ... B00A31IXVY
If there is a bios that I can flash, will it work on an OSX cuz I am running Mavericks now
Has anyone got the DisplayPort to work?
Mine can connect to the TV with DisplayPort to HDMI cable. The Video works, but No sound
Thank you in advance
www.plymptonia.com/thinkpad/Modified_WL.rar
Confirmed it works on (one of) my X220's. I'll keep it at this URL until the end of days.
Has anyone successfully updated to 10.9.3 with this process? I keep running into power management kernel panics, and haven't found the root cause yet.
Finally figured it out, and everything appears to be working except:plympton wrote:Has anyone successfully updated to 10.9.3 with this process? I keep running into power management kernel panics, and haven't found the root cause yet.
1. SD Card slot (no biggie)
2. CPU won't go down below ~ 1.3 GHz according to sensors. :-/. Hmm. It does turbo-boost, however, which wasn't happening before (though it was going to 800 MHz)
3. Resume from power-outage doesn't appear to work (sleep/hibernate, pull battery, boots normal, not resume from Hibernate. Not sure how it's supposed to work.)
4. Sometimes the trackpad/pointer and/or keyboard doesn't work on boot. Not sure why
5. iCloud sign-on doesn't work - had to fix this on my Desktop, forgot what it was at the moment
Works:
[*]Sound (VoodooHDA) - both Speakers AND microphone
[*]Turbo-Boost (3.2 GHz - zooom)
[*]Graphics
[*]Wi-Fi (Non-whitelisted Dell Card with non-whitelist BIOS 1.39)
[*]Sensors (though I'm not 100% confident in their readouts)
[*]Sleep & resume (yeah!)
[*]Bluetooth
[*]Webcam
I ordered a 120GB mSata drive and will re-install on my i7 machine and report back.
Upgrade to 10.9.4. exception SD card reader.
All other works,
Sound, Bluetooth, Webcam, Wifi, Graphics Acceleration, Trim (need to redo it from command line, Chameleon SSD optimizer does not work on 10.9.4), Sleeping, CPU Throttling (P-State), Fan cooling, USB 3.0 connection.
External Monitor via Display Port or VGA -- not tested.
Using 1600Mhz 8GB DDR3 (not 1333MHz) RAM, Geekbench 64-bit goes up to 7918.
So far so good with my i7 2.8Ghz X220 - Samsung mSATA EVO 120GB SSD with Mavericks 10.9.4 and Samsung PRO 128GB SSD with Windows 8.1. The best machine in Thinkpad series. no way to go further with X230, X240 unless someone find the practical solution with NWL bios!
All other works,
wisamalrawi
Thanks a lot for the great tutorial. I spent some time and I figured out how to get the SD Card to load.
You need to use 1180, e823
For the pci and vendor IDs (don't know which one is which) in VoodooSDHC.kext. Using 1180,823e did not work for me.
I'm attaching the kext file so it's easier to download and install. I used kext wizard to install the kext file.
http://www.mediafire.com/download/qru1d ... C.kext.zip
http://i60.tinypic.com/11rdqc7.png
Yes, 1180:e823 is the correct value to update VoodooSDHC.kext.
The problem is-
VoodooSDHC.kext works well under Mountain Lion, but hanging under Mavericks for x220
Even I recompile VoodooSDHC.kext under Mavericks from the latest source code with Apple latest XCode!
The problem is-
So I'm new to this. I have a mavericks 10.9.4 dmg from the app store.
Will the guide posted in the first page work for it or do I have to get an 10.9 image and go through updates?
Im planning a fresh OSX install on a 256gb msata dual booting with a already working win7 SSD.
Tested with display port, does not work, but work with Windows 8.1, anyone has updated DSDT that is working with display port?
Really appreciated.
Really appreciated.
Very picky on SD card, my 32GB SD card be recognized with above KEXT, but cannot format, cannot read any files from it.wisamalrawi wrote:Thanks a lot for the great tutorial. I spent some time and I figured out how to get the SD Card to load.
My display port is working without issues. How can I help you?jzhang18 wrote:Tested with display port, does not work, but work with Windows 8.1, anyone has updated DSDT that is working with display port?
Really appreciated.
Could you post your DSDT and /Extra/Extensions files?My display port is working without issues. How can I help you?
Does it matter to use active or passive display port cable - I use passive display port cable now.
Really appreciate.
OK, so who'll be the first to get Yosemite working?
I got it workingplympton wrote:OK, so who'll be the first to get Yosemite working?
Followed this: http://www.insanelymac.com/forum/topic/ ... -for-1095/
Grabbed his files, tried to follow his instructions, kinda cryptic, but he linked to the guide for the t420 to install yosemite, plus his files for x220. I followed that guide, even used all the same files for the t420 and it all worked for install. In the post installed, I used most of the files from the first guy, except dsdt since I have the i7, conveniently in the zip for the t420 there was a script that generated one for me and even copied it to the right spot and everything.
So yeah, that all works, sound, sleep, cpu throttling looks good as hwmonitor reports, osx says 5+ hours for battery, sleep works, brightness controls. Only thing that seems to be broken is bluetooth, I thought I saw someone post a fix with proper product ids and stuff, still need to find it.
That's awesome! I tried myself following the t420 guide. Got the first and second part of the install but can't get it to boot from the ssd afterwards.
Any tricks or settings you used besides what was in the t420 guide? What version of clover did you use? I couldn't find the version in the guide so I used the latest and didn't work.
control wrote:I got it workingplympton wrote:OK, so who'll be the first to get Yosemite working?
Clover_v2k_r2976.zip, which I think is the latest. I really didn't do anything different from the guide from what I remember. Went through install, it rebooted twice I before it was done, then installed clover copying all the settings in the screenshot, then I just copied the efi partition from the usb drive. Installed the kexts, ran ssdtPRGen-clover.command from the zip and had it copy it to the right place. Didn't do the ethernet install, didn't think I'd need it. Sorry, I didn't document everything very well, didn't actually think it would work, having tried multiple times to get mavericks working properly and failing.
Oh and bluetooth does work, it was trying to pair with a bluetooth speaker, it was still bugging me about missing keyboard/mouse, so I didn't think it worked.
I'll give it another shot. Was really slow to install. Did you use anything from the x220 'guide'?
plympton wrote:I'll give it another shot. Was really slow to install. Did you use anything from the x220 'guide'?
Yeah, I grabbed all the files. Like I said, I couldn't use his dsdt/ssdt since he had the i5, and I have the i7, I used the config.plist from the t420 I think, 1366x768 one obviously, same with the acpi folder. Used all the kexts, using the newer ones. Yeah it took a while to install, even on ssd, but the guide mentions that it will look like it stalls when it says less than a minute left.
Did you have to manually copy the /ESP files from the USB stick to the HDD? (IE: Mount /dev/disk0s1 EFI partition and copy the Clover stuff?) The Clover installer isn't doing that for me, so I'm assuming that I have to do it manually (testing now, but verifying with you)
Did you use the pmpatched x220 bios? I'm only running the whitelist BIOS right now.
To answer my own question, yes, you need to mount the /diskXs1 and copy the Clover files directly there in order for the X220 to boot - once I did that, everything went swimmingly. Even recognizes my USB 3.0 card without any fidgeting. Amazing!
Only thing I haven't taken care of is the iMessage validation, since this is my "spare" X220, and I'll just use this experience to get my real i7 X220 up and running in Yosemite.
My trackpoint is a bit fidgety, though - sometimes it double clicks when I single click. Any advice there?
Thanks for all the help!
-Dan
-Dan
Is this what you are looking for?control wrote:I got it workingplympton wrote:OK, so who'll be the first to get Yosemite working?
http://www.tonymacx86.com/laptop-compat ... 220-9.html
#84
that was simple
Product ID: 0x217F
Vendor ID: 0x0A5C
Convert the hexadecimal values to decimal with searching in google. like '0x217F in decimal'. In my case it's:
Product ID: 8575
Vendor ID: 2652
Now open Finder, choose Go/Go to Folder and paste this location:
/System/Library/Extensions/IOBluetoothFamily.kext/Contents/PlugIns/BroadcomBluetoothHostControllerUSBTransport.kext/Contents/
Then open the file 'Info.plist' in editor and scroll down to the bottom of the file. I added this block:
<key>ThinkPad x220 Bluetooth</key>
<dict>
<key>CFBundleIdentifier</key>
<string>com.apple.iokit.BroadcomBluetoothHostContr ollerUSBTransport</string>
<key>IOClass</key>
<string>BroadcomBluetoothHostControllerUSBTranspor t</string>
<key>IOProviderClass</key>
<string>IOUSBDevice</string>
<key>idProduct</key>
<integer>8575</integer>
<key>idVendor</key>
<integer>2652</integer>
</dict>
Just by replacing idProduct 8575 and save the Info.plist solved the problem after reboot! Don't forget to rebuild kext cache
Bluetooth on/off with x220 hackintosh on mavericks now works
dis someone succeed with Yosemite?
pack with dstl and config would be great
Upgrading X220/X230 to WQHD 1440p
by nitrocaster » Mon Dec 26, 2016 6:45 am » in ThinkPad X200/201/220 and X300/301 Series - 18 Replies
- 3725 Views
Last post by crashnburn
Wed Mar 29, 2017 3:10 am
WTB: Dead X220/X230 motherboards
by nitrocaster » Mon Dec 26, 2016 5:37 pm » in Marketplace - Forum Members only - 0 Replies
- 336 Views
Last post by nitrocaster
Thu Jan 05, 2017 7:27 am
Recase a X220 into an X220i?
by T3f4l » Thu Jan 05, 2017 10:22 am » in ThinkPad X200/201/220 and X300/301 Series - 4 Replies
- 855 Views
Last post by T3f4l
Sat Jan 07, 2017 8:43 am
Replacement for X220: X260 or E470? Or something else?
by awebber » Sat Jan 07, 2017 11:48 am » in ThinkPad X230 and later Series - 13 Replies
- 1296 Views
Last post by mj0
Thu Jan 12, 2017 7:20 pm
