Classic theme on Windows 8
Windows 8 on ThinkPads
Lebowsky
Re: Classic theme on Windows 8
#121 Post by Lebowsky » Wed Jan 14, 2015 9:43 am
First of all, merci beaucoup beaucoup IbmPad!!
I have read through this thread (and several other ones at Facepunch, eightoforums, guru3d, etc...) about this, and I was going to try to restore the classic theme on win8 but I have a couple questions, because I think I mixed up some of the informations:
- Is running the program in the first post of this thread + classicshell enough to restore more or less everything, or is something additional needed?
- Is the program ok to run on windows 8.1 Enterprise 64bit?
I just want to make sure I'm not going to break and spend hours reverting back my company pc :P
thanks!
windows.nt.win32
#122 Post by windows.nt.win32 » Sat Jan 24, 2015 5:03 am
Lebowsky wrote: - Is running the program in the first post of this thread + classicshell enough to restore more or less everything, or is something additional needed?
More or less, a few features will still be metro-ish, but it will be more like Windows 7 with the Classic Theme if you have Classic Shell.
Lebowsky wrote: - Is the program ok to run on windows 8.1 Enterprise 64bit?
I'm using Windows 8.1 Pro 64 bit, and it works just fine for me.
maur0
#123 Post by maur0 » Sun Jan 25, 2015 5:17 am
small bug in firefox the button to close disappears where it should appear on the right. only in firefox all another program show buttons
http://i.imgur.com/VvInLOj.png
Lebowsky
#124 Post by Lebowsky » Wed Feb 04, 2015 4:37 am
maur0 wrote:small bug in firefox the button to close disappears where it should appear on the right. only in firefox all another program show buttons
try to install firefox classic theme restorer?
Lebowsky
#125 Post by Lebowsky » Wed Feb 04, 2015 7:43 am
In Firefox with Classic theme Restorer you can choose the "Alternative Background Color" in the Toolbars(2) Option. This solves your issue when firefox is maxmiized. But I still get weird transparency/missing top right buttons when windowed.
maximized:
windowed:
Not sure if this is a w8classic or Firefox issue.
Other than that, w8classic is doing great!
Lebowsky
#126 Post by Lebowsky » Wed Feb 04, 2015 8:51 am
IbmPad wrote:— Programs that use DWM like Firefox can be made to think Composition is disabled by copying the files “C:\Windows\dwmapi.dll” and “C:\Windows\dwm_rdr.dll” in the same folder than the executable (eg. firefox.exe).
also tried this, but didn't work
maur0
#127 Post by maur0 » Wed Feb 04, 2015 7:23 pm
its work fine thanks IbmPad and Lebowsky
Lebowsky
#128 Post by Lebowsky » Thu Feb 05, 2015 3:44 am
maur0 wrote:its work fine thanks IbmPad and Lebowsky
did you get firefox looking good? both fullscreen AND windowed? how? :)
maur0
#129 Post by maur0 » Thu Feb 05, 2015 6:02 am
yes, now is perfect look
window
http://i.imgur.com/byEXynS.png
and fullscreen
http://i.imgur.com/A4RlEFd.png
Download my dll (unpack 2 dll to folder firefox.exe), restart firefox and enjoy (work?)
http://www61.zippyshare.com/v/BnZVl1gl/file.html
windows.nt.win32
#130 Post by windows.nt.win32 » Sun Feb 08, 2015 7:17 pm
Yeah, I'm not having any problems with Firefox.
Lebowsky
#131 Post by Lebowsky » Wed Feb 11, 2015 10:50 am
solved it with this Stylish code:
#navigator-toolbox {
  background: -moz-Dialog !important;
one more question: is anyone able to disable the drop shadow on the desktop icons label text? Unchecking "use drop shadows for icon labels on desktop" under System Properties -> Advanced -> Performance Settings had no effect.
roytam1
#132 Post by roytam1 » Thu Feb 12, 2015 10:09 am
how can I fix chrome border when using w8classic?
windows.nt.win32
#133 Post by windows.nt.win32 » Thu Feb 12, 2015 3:10 pm
I have a question regarding the startup of classictheme.exe. I was wondering if it would be possible to implement this without replacing the shell (explorer.exe). Perhaps it might be possible to implement it as a service? This would make restarting explorer a lot easier, as it wouldn't require opening every program that is set to run at startup.
IbmPad
#134 Post by IbmPad » Fri Feb 13, 2015 5:41 pm
I don't like the method of replacing the shell but I don't know how to do otherwise. I don't think it is possible to use a service. The issues are that :
— the program has to be run inside the user session (the service could spawn a process in the user session space, so that's not a problem) ;
— it must run before Explorer (otherwise Explorer will get the W8 theme) but after LogonUI (otherwise the logon screen is broken).
Perhaps a completely different method (User32 API hooking ?) that could decide what to do on a process basis could get rid of this and solve other issues, but honestly I haven't worked on the program for a long time and probably won't in the near future… :roll:
Regarding the other questions (from Lebowsky and roytam1), I am sorry but I don't know how to help you…
Please excuse my bad English.
Lebowsky
#135 Post by Lebowsky » Wed Feb 18, 2015 9:44 am
it was more of an open general question. To me your program reaches its goals perfectly. :)
windows.nt.win32
#136 Post by windows.nt.win32 » Thu Feb 19, 2015 12:18 am
IbmPad wrote:I don't like the method of replacing the shell but I don't know how to do otherwise. I don't think it is possible to use a service. The issues are that :
Ah ok. I know Malwarebytes' starts before the shell, as that still uses the Windows 8 aero theme until the program is restarted. When that happens, it will use a transparent classic theme. Also it seems to be running as the current user, but maybe it's started by another process (there are some MBAM related processes that are running as SYSTEM). I'm not sure though.
I can actually understand you not working on this in a while. If you have other things you are working on (weather they be in real life on on the computer) that's perfectly alright. :) I'm just glad you included the source code. Maybe I'll take a look at it once I get some programming experience (hopefully I'll be able to take a class in the near future). But if you decide to start working on this again sometime, that would be awesome too.
Honestly the program works pretty well, so I'll be happy with it the way it is for now. Thanks again.
windows.nt.win32
#137 Post by windows.nt.win32 » Mon Mar 23, 2015 8:52 pm
Hey IBMPad. If it's not too much to ask, could you write a version that doesn't replace the shell? You know, where the user must start it up manually. Maybe you could add a command-line switch to open the settings dialog? Again, I hope I'm not asking too much, but this would be nice to have.
Lebowsky
#138 Post by Lebowsky » Wed Mar 25, 2015 4:19 am
anyone else having problems since the latest firefox updates?
edit: I don't think it's a firefox update issue, maybe a windows update that screwed some registry entries? I had the same problem with IE, but doing "patch internet explorer" in w8classic fixed it. What does this function exactly do and can I reproduce it for Firefox?
IbmPad
#139 Post by IbmPad » Wed Mar 25, 2015 8:07 am
@windows.nt.win32 : I have modified the program so that you can run it manually by renaming the file to “ClassicThemeA.exe” (be sure to run it with admin rights).
@Lebowsky : I honestly don't know and cannot install the hundreds of Windows updates in my Win8 VM. Did you try to copy again the files “dwmapi.dll” and “dwm_rdr.dll” from the IE folder to the Firefox folder ? If it still doesn't work, you can try to edit the manifest in Firefox.exe using e.g. Resource Hacker and add the line “<file name="dwmapi.dll" />” before “</assembly>” (this is what “Patch IE” does, to force it to use the local dwmapi.dll file instead of the one located in System32)…
Lebowsky
#140 Post by Lebowsky » Wed Mar 25, 2015 9:13 am
IbmPad wrote:@Lebowsky : I honestly don't know and cannot install the hundreds of Windows updates in my Win8 VM. Did you try to copy again the files “dwmapi.dll” and “dwm_rdr.dll” from the IE folder to the Firefox folder ? If it still doesn't work, you can try to edit the manifest in Firefox.exe using e.g. Resource Hacker and add the line “<file name="dwmapi.dll" />” before “</assembly>” (this is what “Patch IE” does, to force it to use the local dwmapi.dll file instead of the one located in System32)…
Added it to the manifest file, no change. I tried to remove the files from the folder, and when I do that it gets much worse, so it looks like it is loading them correctly but something else is messing up the rendering of the title bar. I also tried installing Pale Moon (other Firefox-based browser), same result.
Funnily enough, this is the only application having this issue. I'd be interested to know if other w8classic users are having this issue, but it's not a big problem anyway...
maur0
#141 Post by maur0 » Wed Mar 25, 2015 9:41 am
work for x64 version of firefox for x86 not work :/
1- get firefox x64
http://sourceforge.net/projects/pcxfire ... /x64/sse2/
2- Download my dll (unpack 2 dll to folder firefox.exe), restart firefox and enjoy
IbmPad whats new in this version compiled day 23/03?
Lebowsky
#142 Post by Lebowsky » Wed Mar 25, 2015 10:12 am
maur0 wrote:work for x64 version of firefox for x86 not work :/
1- get firefox x64
oh that's great, thanks for the info!!
maur0 wrote:IbmPad whats new in this version compiled day 23/03?
he said it just above :) I have modified the program so that you can run it manually by renaming the file to “ClassicThemeA.exe” (be sure to run it with admin rights)
windows.nt.win32
#143 Post by windows.nt.win32 » Fri Mar 27, 2015 5:25 pm
IBMPad, I honestly can't thank you enough. Now I can have the classic theme on a per-user basis.
I have a batch file set to run at startup for my user account. It is a bit annoying, but I like having explorer.exe as the system shell.
@echo off
taskkill /f /im explorer.exe
start %SystemRoot%\ClassicThemeA.exe
start %SystemRoot%\Shells\ClassicTheme\explorer.exe
I've noticed that when ClassicThemeA.exe is run, the taskbar is not fixed. However, I managed to fix this problem by with this workaround:
1.) Copy Explorer.exe into a new folder (I copied mine to C:\Windows\Shells\ClassicTheme\explorer.exe).
2.) Do the same for explorer.exe.mui located in your language locale folder.
For example, my language is English, United States. So I ended up copying C:\Windows\en-US\explorer.exe.mui to C:\Windows\Shells\ClassicTheme\en-US\explorer.exe.mui. Just do the same for your system language.
3.) Download the dwmapi.dll and dwm_rdr.dll files posted by maur0, and put them in the new explorer folder.
4.) Now open up the regedit. Navigate to HKCU\Software\Microsoft\Windows NT\CurrentVersion\winlogon and create a new string value called 'Shell'.
5.) Edit this string value to point to your new explorer.exe file (again, for me it was C:\Windows\Shells\ClassicTheme\explorer.exe).
windows.nt.win32
#144 Post by windows.nt.win32 » Sat Mar 28, 2015 8:45 pm
You know, I think this could be implemented as a service. I did some testing, and ran ClassicTheme.exe on the login screen (using the old sticky keys Command Prompt exploit). I then killed the process LogonUI.exe (which will automatically restart when it's killed) and the login screen worked fine. And when I logged into my account, I was still using the classic theme. However, Aero seems to be enabled whenever I log off.
windows.nt.win32
#145 Post by windows.nt.win32 » Sat Apr 04, 2015 4:43 pm
Well, I can confirm that this can be implemented as a service. Using sc create, I added ClassicThemeA.exe as a service, and it does work. It will start up with the computer. However, there are a few issues with it in its current state. The first issue being that it will set itself as the shell at startup. This should be fixable. The second issue is that when you log off, it will no longer be in effect. I have an idea as how this could potentially be fixed, if anyone would like to try and fix it.
1.) The process starts up on the login screen as a service (it already does this with no problems).
2.) The process waits for the user's login credentials to be entered
3.) The process checks the registry to see if the current user logging in has the classic theme enabled. This would allow the classic theme to be used as a per-user basis.
-If the classic theme is enabled, the process enables the classic theme.
-This should all happen before the user's desktop/explorer.exe is loaded.
4.) The process runs in the background using very little memory. It will stay active when the user logs off, allowing it to be ready to start over at step 2 when a user logs back on.
I'm not sure if there would be any limitations preventing the program from executing this way. I'm not sure if IbmPad would be up for making it do this (if he is that's great, but if he's not that's alright), which is why I'm happy this is open source. I would do it if I knew how to program, but unfortunately I don't as of now. But I decided to throw this out there just in case anyone else wants to look into this.
Anixx
#146 Post by Anixx » Wed Apr 15, 2015 9:08 pm
Well, Windows 7 has failed to load after recent update so I had to re-install the system. So I decided to move to Win8.
So now on I use this program to its fullest extent.
maur0
#147 Post by maur0 » Thu Apr 16, 2015 8:32 am
Anixx wrote:Well, Windows 7 has failed to load after recent update so I had to re-install the system. So I decided to move to Win8.
work fine only small bug on colors "selected itens" color is black and white but in real is blue and white and task bar not up and down only disable classic theme work, just that anything that compromises the use normally.
http://i.imgur.com/Bt3CZNo.png
Anixx
#148 Post by Anixx » Thu Apr 16, 2015 8:46 am
maur0 wrote: work fine only small bug on colors "selected itens" color is black and white but in real is blue and white
You can edit the theme colors manually in the registry.
windows.nt.win32
#149 Post by windows.nt.win32 » Thu Apr 16, 2015 11:45 am
Like Anixx said, you can edit the colors in the registry. Look under HKCU\Control Panel\Colors and try modifying either the "Hilight" or "MenuHilight" values. I think this bug is present because Windows XP introduced a new highlight for flat menus, and this color scheme picker is from Windows NT 5.0 beta.
Anixx
#150 Post by Anixx » Fri Apr 17, 2015 10:33 am
This script fixes the 1 pixel off taskbar issue a little bit better, but still not perfectly.
#NoEnv
#NoTrayIcon
SetControlDelay, -1
Gui +LastFound
hWnd := WinExist()
Sleep, 5000
;WinGet, id,, ahk_class Shell_TrayWnd
WinGetPos,,,ww,wh, % "ahk_id " id
ControlMove, ReBarWindow321,,4,,,  % "ahk_id " id
ControlGetPos, ,y,,h,ReBarWindow321,  % "ahk_id " id
ControlMove, TrayNotifyWnd1,,4,,h-4,  % "ahk_id " id
WinSet, Redraw,,  % "ahk_id " id
DllCall( "RegisterShellHookWindow", UInt,hWnd )
MsgNum := DllCall( "RegisterWindowMessage", Str,"SHELLHOOK" )
OnMessage( MsgNum, "ShellMessage" )
Return
ShellMessage(wParam,lParam) {
   If (wParam = 1 or wParam = 2) ;  HSHELL_WINDOWCREATED := 1
;WinGetClass, WinClass, ahk_id %lParam%
WinGet, lParam,, ahk_class Shell_TrayWnd
WinGetPos,,,ww,wh, % "ahk_id " ahk_id %lParam%
ControlMove, ReBarWindow321,,4,,,  ahk_id %lParam%
ControlGetPos, ,y,,h,ReBarWindow321,  ahk_id %lParam%
ControlMove, TrayNotifyWnd1,,4,,h-2,  ahk_id %lParam%
WinSet, Redraw,,  ahk_id %lParam%
Return to “Windows 8”
