Classic theme on Windows 8
Re: Classic theme on Windows 8
Doesn't work on Windows 8.1.
Is it enough to run ClassicTheme.exe and select Install, then Enable classic theme now?
I got black screen instead of desktop -- no icons, no taskbar. And opened Explorer that just shows my files.
Strange. Work on second installation.
This is how I set up firefox, using the Firefox fix from this thread and the CSS style fixing the border:
crashnburn
Please do share what procedure you followed.IZh wrote:Strange. Work on second installation.
new methdo
http://i.imgur.com/VQj5Bsm.png
using this script
@echo off
FOR /F "delims=^T" %%G IN ('Handle ThemeSection') do set output=%%G
FOR /F "tokens=6" %%G IN ('echo %output%') DO set handleid=%%G
FOR /F "tokens=3" %%G IN ('echo %output%') DO set pid=%%G
echo %handleid%
echo %pid%
Handle -c %handleid% -p %pid% -y
with this program
https://technet.microsoft.com/en-us/sys ... 96655.aspx
source
http://www.msfn.org/board/topic/173367- ... and-8-too/
people test and feedback
using this script
@echo off
echo %handleid%
echo %pid%
with this program
source
Interesting! But they say it does not work with the taskbar...
I wonder what would happen if we
1. disable DWM
2. run the taskbar so it runs as if DWM disabled
3. enable DWM
4. Disable theming via handle.
1. disable DWM
3. enable DWM
windows.nt.win32
Not sure how well re-enabling DWM.exe after disabling it works. I really should test Windows 10 in a VM when I get the chance. If we get the classic theme to be fully functional with it, I'll definitely upgrade.
IbmPad: The Classic Theme patch doesn't work on Windows 10. It gives an error regarding not being able to find and ordnance in Explorer.exe.
windows.nt.win32
Just upgraded to Windows 10. I've noticed this too, but only when using it with the dwm_redir.dll and dwmapi.dll files. If launched from C:\Windows without these files also in that directory, it should launch just fine. That said, this means that the taskbar is messed up, and as previously mentioned, the context menus don't have any text. For me, this is the most annoying thing. I would love to see a fix for this.Zero3K wrote:IbmPad: The Classic Theme patch doesn't work on Windows 10. It gives an error regarding not being able to find and ordnance in Explorer.exe.
You can try to restore classic context menus using 7+ Taskbar Tweaker.windows.nt.win32 wrote:Just upgraded to Windows 10. I've noticed this too, but only when using it with the dwm_redir.dll and dwmapi.dll files. If launched from C:\Windows without these files also in that directory, it should launch just fine. That said, this means that the taskbar is messed up, and as previously mentioned, the context menus don't have any text. For me, this is the most annoying thing. I would love to see a fix for this.Zero3K wrote:IbmPad: The Classic Theme patch doesn't work on Windows 10. It gives an error regarding not being able to find and ordnance in Explorer.exe.
Unfortunately it seems there is no working version of 7+ TT for Win10 yet.
windows.nt.win32
No those context menus aren't the issue. I'm talking about folder context menus, like when you right-click on a file or folder (or inside a folder or on the desktop). Here is an image posted by roytam1 showing the issue: http://i.imgur.com/hRExha3.pngAnixx wrote:You can try to restore classic context menus using 7+ Taskbar Tweaker.
By the way, what happens if totally disable DWM on Win10? Does it boot at all?
Regarding context menus have you tried to uncheck UPMCalc, item 17?
windows.nt.win32
Haven't tested it yet, but I don't think it would be much different than Windows 8.Anixx wrote:By the way, what happens if totally disable DWM on Win10? Does it boot at all?
Yeah I tried that, and sadly it didn't work. Explorer context menus are weird in Windows 10.Anixx wrote:Regarding context menus have you tried to uncheck UPMCalc, item 17?
Last edited by windows.nt.win32 on Fri Aug 07, 2015 3:20 pm, edited 1 time in total.
What is the error message that you got before deleting those files?windows.nt.win32 wrote:Just upgraded to Windows 10. I've noticed this too, but only when using it with the dwm_redir.dll and dwmapi.dll files. If launched from C:\Windows without these files also in that directory, it should launch just fine. That said, this means that the taskbar is messed up, and as previously mentioned, the context menus don't have any text. For me, this is the most annoying thing. I would love to see a fix for this.Zero3K wrote:IbmPad: The Classic Theme patch doesn't work on Windows 10. It gives an error regarding not being able to find and ordnance in Explorer.exe.
windows.nt.win32
Here are the error messages I get:Zero3K wrote: What is the error message that you got before deleting those files?
andexplorer.exe - Ordinal Not Found
The ordinal 159 could not be located in the dynamic link library
C:\Windows\Shells\ClassicTheme\Explorer.exe.
Keep in mind that C:\Windows\Shells\ClassicTheme is where I was launching my copy of explorer.exe from (which really doesn't matter, and it should work the same as launching it from C:\Windows).explorer.exe - Ordinal Not Found
The ordinal 1 could not be located in the dynamic link library
C:\Windows\Shells\ClassicTheme\dwm_rdr.dll.
windows.nt.win32
Well I decided to try disabling DWM.exe on Windows 10, and here are the results:
First of all, the login screen is pretty much the same as in Windows 8 without DWM, except this time there is no network icon, and it's displayed as a blank grey box instead of a blank black box (this might be different based on your color settings). After logging in, it will be pretty much the same as Windows 8 without DWM. The start menu and the action center won't load, and the same goes for any metro-ish UI elements. I did however notice some differences with the classic theme. First of all, the right-click menus are still broken, meaning the issue with them isn't DWM related. Unfortunately the taskbar still seems to be broken. I've tried messing around with the settings to fix it, but unfortunately had no luck in doing so. I didn't find anything else, but I may have missed something.
Hello, sorry for not having replied for a long time. I just installed Win 10 in a VM to test it.
For the context menu problem, try to add this registry value (DWORD) :
Regarding the “Ordinal xxx missing” error, it is just a DLL export issue; it just needs to be compiled again using the Windows 10's dwmapi.dll file.
I will add this mod to the program and make some tests to try to fix other things when I will have some time…
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\FlightedFeatures\ImmersiveContextMenu = 0I will add this mod to the program and make some tests to try to fix other things when I will have some time…
Please excuse my bad English.
windows.nt.win32
Once again IBMPad, you are awesome! The registry tweak you posted does work, and now the classic theme is actually worth using in Windows 10 for me. Can't wait for future updates, especially for dwmapi.dll. If that fixes the taskbar, then I'd say that Windows 10's classic theme would be on-par with Windows 8's.
Also, one nice thing about the classic theme in Windows 10: the issue of 3 unknown programs sometimes appearing in Windows 8's alt+tab (usually after the computer is woken up) doesn't seem to exist in Windows 10.
windows.nt.win32
Has anyone figured out why some Control Panel pages fail to load yet? The biggest reason I ask is because I have a friend who would like to use the classic theme, but he frequently switches between Chinese and English on his computer, so he wouldn't be able to load the Languages page with the classic theme. Unless there is an alternative language UI available. I've found Winaero's Personalization Panel for Windows 10 to be an excellent alternative for the Personalization page.
On a slightly unrelated note, I guess there was an issue with scheduled tasks on my old Windows 8.1 installation. Since I upgraded to Windows 10, I've been using that to start ClassicThemeA.exe whenever I log in. So that fixes the issues I had with this program starting up!
Why one would need to use Control panel to switch languages?windows.nt.win32 wrote:Has anyone figured out why some Control Panel pages fail to load yet? The biggest reason I ask is because I have a friend who would like to use the classic theme, but he frequently switches between Chinese and English on his computer, so he wouldn't be able to load the Languages page with the classic theme.
windows.nt.win32
I don't know, I think he's more concerned about being able to manage the languages or something. I really only use English on my computer, so I'm not really experienced with using languages on my system. Is there another way to change/manage languages?Anixx wrote:Why one would need to use Control panel to switch languages?windows.nt.win32 wrote:Has anyone figured out why some Control Panel pages fail to load yet? The biggest reason I ask is because I have a friend who would like to use the classic theme, but he frequently switches between Chinese and English on his computer, so he wouldn't be able to load the Languages page with the classic theme.
Usually Alt+Shift or Ctrl+Shift.windows.nt.win32 wrote: I don't know, I think he's more concerned about being able to manage the languages or something. I really only use English on my computer, so I'm not really experienced with using languages on my system. Is there another way to change/manage languages?
windows.nt.win32
Ah ok. I've heard Windows Key+Space too.Anixx wrote:Usually Alt+Shift or Ctrl+Shift.
Anyway I've noticed that the the taskbar seems to ignore the ImmersiveContextMenu registry value, and will always have it enabled regardless of what the registry says. It's a little bit annoying, but I can live with it.
windows.nt.win32 wrote:Ah ok. I've heard Windows Key+Space too.Anixx wrote:Usually Alt+Shift or Ctrl+Shift.
Try 7+ Taskbar Tweaker.
windows.nt.win32
I mean empty areas on the taskbar. Luckily program context menus in the taskbar work just fine. That would be horrible if they didn't.Anixx wrote:Try 7+ Taskbar Tweaker.
Are you able to add those changes to it yet?IbmPad wrote:Hello, sorry for not having replied for a long time. I just installed Win 10 in a VM to test it.
For the context menu problem, try to add this registry value (DWORD) :Regarding the “Ordinal xxx missing” error, it is just a DLL export issue; it just needs to be compiled again using the Windows 10's dwmapi.dll file.Code: Select all
windows.nt.win32
I've noticed that deskn.cpl tends to freeze on Windows 10 when applying new scheme settings. Am I the only one with this issue, or are others getting it too?
7+ Taskbar Tweaker has got the Win10 support. I have just received the update.
FS: misc parts.... lightly used classic keyboard | 4GB DDR3 RAM | lightly used T500 palmrest, bezel
by tpdude4 » Sat Dec 31, 2016 9:06 am » in Marketplace - Forum Members only - 6 Replies
- 686 Views
Last post by tpdude4
Sun Jan 15, 2017 6:45 am
- 3037 Views
Last post by malmso
Sun May 28, 2017 11:49 am
Cheating to create a new "laptop" with a classic ThinkPad keyboard
by chx1975 » Fri Mar 10, 2017 1:28 am » in GENERAL ThinkPad News/Comments & Questions - 2 Replies
- 626 Views
Last post by chx1975
Fri Mar 10, 2017 6:44 pm
- 23 Replies
- 1302 Views
Tue May 02, 2017 8:18 am
