Hello, if you'd like a windows 10 start menu with tiles within classic shell, please support my thread here:
http://classicshell.net/forum/viewtopic.php?f=13&t=5277
Here's a picture of what it'd look like:
http://oi58.tinypic.com/wm0yeq.jpg
If you need a windows task manager that works in windows 10 classic mode ( and maybe 8 ) here it is:
http://winaero.com/blog/get-classic-old ... indows-10/
windows.nt.win32 wrote:bugmn wrote:Update: I tried the windows classic theme enabler ibmpad made, and came across a few bugs. It doesn't change the color of the taskbar. What color it does change is only a little bit. Image here:
http://i61.tinypic.com/o70ba1.png
Yeah that's a bug that we're currently trying to fix. It's pretty annoying, yes.
bugmn wrote:The windows 10 start button is missing, and right clicking on the taskbar produces a blank selection. Image here:
http://i61.tinypic.com/262abls.png The start button issue can bne fixed using a custom start button however.
I think the start button is dependent on Aero, so that's why it won't work without a custom button. I normally use Classic Shell with a custom button, so to me that's not the biggest issue. I'm not sure why right-clicking on the taskbar shows up blank though. Again, it is pretty annoying.
I think I read somewhere that ibmpad made a registry fix somewhere in these posts, but I didn't find it.
bugmn wrote:
Another bug is making the taskbar bigger, right clicking on the taskbar & selecting one of the blank options crashes explorer/the taskbar, which you can't fix by restarting explorer. You get a black screen after it crashes. The only fix I've found for this is uninstalling the theme enabler and re-installing the theme.
Interesting, I've never had this happen to me.
Yeah, I don't know why it's not working. I'll have to try it again and see if it works now?
bugmn wrote:As for desktop architect while the classic theme is installed , loading a windows 98 theme doesn't change anything except for the color of the active titlebar.
I haven't messed around with Desktop Architect too much, but I noticed that loading schemes from it seemed to be messed up for some reason. Hopefully there's a way to fix this; it does look like a nice program.
It hasn't had any problems so far with me. It doesn't work like it did on windows 7 though.
bugmn wrote:
Also, kudo's on the 'configure theme' menu bringing up a windows 98-esk display properties menu to edit your theme.
If you can combine a custom theme using UxStyle ( UxTheme didn't work for me ) and the display properties theme editor to change colors and etc on the fly, that'd be great! ^_^
When you say custom theme, do you mean visual style? If that's the case, that could bring its own set problems. Mainly, Windows visual styles basically just overlay bitmaps over the classic theme, and then DWM will create desktop composition effects such as transparency, Aero colorization, and other effects. Plus, custom visual styles are a bit more limited than they were in the days of Windows XP. So I don't think this method would work out too well.
Oh, I didn't mean when the classic theme was installed, but rather to do it without it installed. If we could make a theme that looks exactly like the windows 98 theme, then we wouldn't need this program to enable the windows classic theme. Also, we could make a program to edit the colors and etc on the fly just like if we had the classic theme default from microsoft.
