Battery woes on my new (used) machine.... :(
I just got a new T42 that's about a year old, and I thought the battery power was going to be a little better. Right now, it lasts about 2 hours off the hook, and that's just not cutting it for me.
What is the weight of both the 6-cell and the 9-cell? How much larger is the 9cell? Can a different charger charge the battery faster/better?
How long does a brand new 6-cell last and how long does it take for it to go sour? ...how much is it typically?
How long does a brand new 9-cell last and how long does it take for it to go sour? ...how much is it typically?
What are my battery addons besides that? Can I remove the CD-ROM and put a battery in it's place? How long would that battery last and how much?
I know my questions are all the same, but I have no idea :-/.
Bob Collins
Not sure about the 6 vs 9 cell battery weights, but would say the 2 hours is good on an old battery. Check the battery stats and see how many charge cycles etc. Again, for a used battery, very good at 2 hours. I think the concensus is that a battery is good for about a year with typical charge cycles, before you notice true loss of capacity.
Bob
701C, 600X, T22, G4 Powerbook
How do I see how many charge cycles it's gone through?Bob Collins wrote:Not sure about the 6 vs 9 cell battery weights, but would say the 2 hours is good on an old battery. Check the battery stats and see how many charge cycles etc. Again, for a used battery, very good at 2 hours. I think the concensus is that a battery is good for about a year with typical charge cycles, before you notice true loss of capacity.
Right click on the battery monitor, and then select status and information or something like that.
But has tou T42 an flexview pannel? (15" SXGA or UXGA) Since my brand new T42 (who is for sale
) only gets max 3:40 out of 1 6Cell battery.
Own:
X61t
Owned:
X41, X31, T41, T42, X40, X61s
Yes... I love the X-series.
X61t
Owned:
dr. zoidberg
i get about 2.5-3 hours of continuous use with a 6 cell battery, depending on what im doing. this is while running the cpu and video card at the slowest settings.
i also thought i would get better battery life. after all, ibm claimed 4 hours on a 6 cell battery
IBM T42 2373-3uu
Dothan 1.7Ghz @ 1.9GHz
120Gb Samsung HM121HC 5400rpm
1.5GB DDR333
14.1" SXGA+
Radeon 9600 64mb
1.5GB DDR333
14.1" SXGA+
Radeon 9600 64mb
Got a nice IPS x220t from ebay, realize I have Computrace woes now
by Digitalhorizons » Sun Jan 08, 2017 7:29 am » in ThinkPad X200/201/220 and X300/301 Series - 39 Replies
- 3928 Views
Last post by asgaard
Tue Jun 27, 2017 10:21 am
Do the T430 and T440 have the old 7 digit machine types?
by serpico » Thu Apr 06, 2017 1:42 pm » in ThinkPad T430/T530 and later Series - 4 Replies
- 380 Views
Last post by serpico
Thu Apr 06, 2017 2:36 pm
How to look up specs for newer style machine type numbers?
by serpico » Fri Apr 07, 2017 10:27 am » in ThinkPad T430/T530 and later Series - 2 Replies
- 341 Views
Sun Apr 09, 2017 9:10 pm
- 13 Replies
- 1819 Views
Last post by cadillacmike68
Sun Feb 19, 2017 9:45 pm
