Windows XP end of support
Puppy
Re: Windows XP end of support
Note, if you use Microsoft Security Essentials on Windows XP you might experience system lock-up after login screen since today, more here
http://www.windows-noob.com/forums/inde ... s-with-xp/
http://social.technet.microsoft.com/For ... 0x80004005
Norway Pad
I have experienced this error a couple of times after I started using MSE, even years back. I think it usually happened after a Windows update, so don't think it has anything to do with XP EOL. In my cases it made the computers bluescreen at bootup; luckily it specified the MpMsEng file in the error text. So booting into Safe Mode and deleting that file fixed it. I have vague recollections of MSE not working afterwards, so I think I had to uninstall and reinstall it.
Bjorn
Removed MSE a couple of days ago that was on one of my T23 systems and replaced it with AVG 2014. Got tried of the popup saying that my computer was vulnerable to malware. Well I know that. I'm running Windows after all
Puppy
The machine runs MSE for ages and it has never occured before. Also some posts indicates there will be a fix for it.Norway Pad wrote:I think it usually happened after a Windows update, so don't think it has anything to do with XP EOL.
I have learned not to install MSE on Pentium 4 or older computers, because it slows them down big time. Avast is far more appropriate for these machines.rkawakami wrote:Removed MSE a couple of days ago that was on one of my T23 systems and replaced it with AVG 2014.
Norway Pad
Consider yourself as lucky. It has happened on both T42 and T43 machines here, maybe as much as 2-3 years ago. Don't remember if it has happened to any other machines than T4x genereation ones, but specifically remember the file name MpMsEng. Very confused the first time it happened, as I rarely experience bluescreens.Puppy wrote:The machine runs MSE for ages and it has never occured before. Also some posts indicates there will be a fix for it.
I have been looking into this for the T23, does Avast seem to be less resource demanding than MSE?pianowizard wrote:I have learned not to install MSE on Pentium 4 or older computers, because it slows them down big time. Avast is far more appropriate for these machines.
Bjorn
Puppy
“Operation Clandestine Fox” Now Attacking Windows XP Using Recently Discovered IE Vulnerability
http://www.fireeye.com/blog/technical/t ... ility.html
On Windows XP, disabling the VGX.DLL is the only workaround since there will not be any patch
http://blogs.technet.com/b/srd/archive/ ... -0day.aspx
Not sure if this is the same exploit but I just installed a patch for IE8 (on my WinXP system) that was released today: http://support.microsoft.com/kb/2964358
Despite their previous statements about not supporting bug fixes for Windows XP systems, this latest flaw was serious enough that they had to do sometime about it. Obviously, no guarantees that any future fixes will warrant this same kind of action.
To stop the warnings from Security Essentials, uninstall it and replace with version 4.5.216. Don't allow Windows to update it.
Work: T42p (XP, UXGA IPS); T60p (XP, UXGA IPS); T60/61 FPad (Win 7, UXGA IPS).
Play: X1 (first gen, Win 7); T450s (Win 7).
Or just use another AV. There's loads of 'em out there.exTPfan wrote:To stop the warnings from Security Essentials, uninstall it and replace with version 4.5.216. Don't allow Windows to update it.
Past: IBM ThinkPad A31, R40
cadillacmike68
I still use XP on all my T30s and T61s. The T30s will keep it, but I'm trying to migrate the T61s to w7, as I have noted elsewhere. If you are even somewhat careful with your browsing and have a good AV & spyware blocker, it's a non-issue.
I have a problem with svchost that I still have to correct before winblows updates will work on the computers (it hangs searching for updates). I might as well fix that, update to the latest possible and then turn off winblows updates for good on the XP machines. I haven't noticed any ill effects from not getting the update of the day from ms for several months.
I almost never use the internet extorter, so lack of updates does not concern me much, if at all. Firefox works well for me, although as other have noted, it is a resource hog.
760LD 9547 FUBARd
T500 2
T500 2
LF: Top-end X61 motherboard
- 529 Views
Last post by wujstefan
Sun Mar 19, 2017 1:52 pm
Models that support two ultrabays
by Whitieiii » Sat Jan 21, 2017 6:49 am » in GENERAL ThinkPad News/Comments & Questions - 5 Replies
- 544 Views
Last post by Whitieiii
Sat Jan 21, 2017 4:34 pm
Thinkpad E570 - seem to have dropped OneLink dock support.
by bblake » Mon Feb 20, 2017 7:09 am » in ThinkPad Edge - 1 Replies
- 1270 Views
Last post by Ibthink
Mon Feb 20, 2017 7:32 am
Apt-X and BT LE/SMART support by Bluetooth v4.0 daughter cards
by dandreye » Fri Feb 24, 2017 8:30 am » in Thinkpad X6x Series incl. X6x Tablet - 0 Replies
- 1695 Views
Last post by dandreye
