Except for a hardware solution I think the only way is to hack bios. Fortunately with T60 it is easy to hack bios and set custom rpm values, detailed instructions are posted in this forum if you search older threads. Also T61 rpm values can be set using a similar bios hack.zoltan87 wrote: Is there a way to somehow change these rpm numbers? Or trick the controller into reading higher numbers than the actual fan speed? I really want to make a quiet first level for the fan where it slightly cools but is inaudible.
[GUIDE] Make your T60 with ATI run *cool* (and quiet)
Re: [GUIDE] Make your T60 with ATI run *cool* (and quiet)
zoltan87
Oh that's good news! Will do some more searching then. Strange, as I googled quite a lot, but couldn't find anything apart from some german forums.
In this thread you find instructions (post #12 and also some posts written by me later in the thread):zoltan87 wrote:Oh that's good news! Will do some more searching then. Strange, as I googled quite a lot, but couldn't find anything apart from some german forums.
viewtopic.php?p=678419#p678419
zoltan87
Very interesting thread. Unfortunately those things are way above my skill set ( especially post no.12, it's like reading chinese). Maybe I will come back to it later. It's a shame there is no simple solution to this "fixed rpm" problem.
How can I find out if I can run Win10 or Win 7 on this T60?
by Muse » Sat Jan 07, 2017 10:29 am » in ThinkPad T6x Series - 15 Replies
- 2224 Views
Last post by sebileis2017
Thu Mar 09, 2017 11:24 am
x230 compatible fans (want to upgrade and make it quieter)
by blueredcat123 » Sun Jan 01, 2017 5:41 pm » in ThinkPad X200/201/220 and X300/301 Series - 4 Replies
- 972 Views
Last post by mj0
Wed Jan 04, 2017 4:52 pm
Oldest Thinkpad you'd run Windows 7 on?
by Whitieiii » Sat Jan 21, 2017 4:40 pm » in GENERAL ThinkPad News/Comments & Questions - 26 Replies
- 1515 Views
Tue Jan 31, 2017 1:54 pm
P50 won't run on AC without a battery
by blgaarder » Wed Feb 01, 2017 9:03 am » in ThinkPad W530 and later Series - 3 Replies
- 1065 Views
Last post by blgaarder
Tue Feb 14, 2017 5:05 pm
