X6X-series LED backlight conversion kit howtos
jaspen-meyer
Re: X6X-series LED backlight conversion kit howtos
#301 Post by jaspen-meyer » Sun Mar 19, 2017 4:29 am
pkiff wrote:(or is easily cuttable with an Xacto knife)
Yes, easily cut. You may need to sandwich it between layers of stick-resistant 'paper'.
Click This
#302 Post by Click This » Mon Apr 10, 2017 5:21 pm
Hi there.
I've ordered a 4th batch X62 and I intend to do an LED backlit conversion on it when I receive it. Looking at Monty's guide and the few images available online of the X62 screen assembly thus far however, I'm a bit intimidated by the whole project. Are there any specific steps or precautions needed particular to the X62?
I found the potential to accidentally invert the inverter cable a bit frightening and the provided image in the guide didn't make sense to me. Could somebody clarify on that?
Thanks.
xiphmont
#303 Post by xiphmont » Mon Apr 10, 2017 5:24 pm
Click This wrote:Hi there.
Not really, it's just like an X61.
Although the connector is not keyed, the way the cable fits in the lid makes it ~ impossible to plug in the inverter backwards accidentally. It's only an issue on the tablets as the cable is different and easy to reverse without noticing.
