I removed the kapton tape and readjusted the position of the LED strip. The dark areas were fixed but the yellowing persists. It is only in a fuzzy band about one inch wide just to the right of the LCD cable. Any ideas?xiphmont wrote:Not bad LEDs-- that would cause left-to-right unevenness along the bottom. I think your LED strip has simply rotated out of position. The yellow tint is because of the kapton tape on the strip-- peel it off. It serves no useful purpose and gets in the way.85101 wrote:I just installed a modded fancyboost in my X61s with the IDTech N121X5-L06 display (42T0343). About a vertical third of my screen is darker than the rest and tinted yellowish. It's not a sharp transition (no "lines"). Could this be bad LEDs on the strip or another problem?
Also, the ctrl and alt keys on my keyboard no longer work together after reinstalling my keyboard. They only produce a beep sound and have no effect. This is the third keyboard that I have managed to break in a similar way (simply removing and reinstalling), and I have no idea why.
