Thinkpad X61, stored disassembled for a couple years due to a broken fan. Recently I wanted to revive it, so I got a new fan and thermal paste to reinstall the heatsink. The parts apparently held up well, just a broken corner on the top case and a slightly bent pin in the battery connector which I straightened easily. I put everything back together, plugged the power in and... nothing. The leds blink and then nothing. Sometimes it keeps doing that in a loop. I tried the "power button CPR", I tried holding the power button for 30, 60 seconds. I tried removing the RAM banks, swapping them, putting them in one at a time. I tried removing the hard disk. I tried both with and without a battery. What I didn't do was blast the components with canned air or clean them with rubbing alcohol, I probably should have but I don't have either
The maintenance manual says it's either a loose connection or a dead system board. I think I can rule out the loose connection, as I had someone else disassemble it and put it back together. An X61 system board can be had for under $50, which for a ~$3000 laptop isn't a lot, so...
Theories on what it could be? I suspect either something shorted out, or I damaged something during reassembly (pushed down too hard when screwing the fansink back in maybe? no clue). Can I revive it somehow? Is a new system board worth it? It is a ~$3000 laptop (not counting the personal significance), but a 5 year old one too. On the other hand, the part that could save it is much cheaper that I thought
What can I do next?
X61 dead/comatose, leds blink, no beeps
T430s: Doesn't accept AC power, status leds aren't working
by AlexTP » Thu Feb 09, 2017 5:58 pm » in ThinkPad T430/T530 and later Series - 5 Replies
- 484 Views
Last post by tomatohat
Fri Feb 10, 2017 2:39 pm
X220 partially dead yellow USB port, dead SD card
by Fusion » Sun Apr 30, 2017 6:44 pm » in ThinkPad X200/201/220 and X300/301 Series - 5 Replies
- 647 Views
Tue May 02, 2017 11:50 pm
strange beeps when idle
by gene_s » Sat May 20, 2017 1:13 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 9 Replies
- 534 Views
Last post by gene_s
Sun Jun 11, 2017 11:25 am
WTB: Dead X220/X230 motherboards
by nitrocaster » Mon Dec 26, 2016 5:37 pm » in Marketplace - Forum Members only - 0 Replies
- 337 Views
Last post by nitrocaster
Thu Jan 05, 2017 7:27 am
