Windows 10
Re: Windows 10
So how about switchable graphics (dream!) ?
W500x3 with T9900, , T400 highnit 1280x800 with P9600, X61sx3, X61Tx3.
Re: Windows 10
I ran the file g6u432ww in win7-mode
Hans-Henrik
T440 20B7S0HN00 - before this T60's fan with 3 in the family (daughter, son-in-law), T60p for one grandchild and an Ideapad U330 Touch for one more grandchild. All now running Win10 - no issues
Norway Pad
Re: Windows 10
Not Win10 related, but need to verify the information given above: I made another attempt on upgrading to Win8.1 last night. After the first reboot it appeared to be acting up this time too, but not as bad. When it finally came back, I got an error message telling me that one of the ATI components was incompatible, so I uninstalled all the ATI components and let it go to the generic Microsoft driver. After that Win8.1 worked just fine, including the Power Manager. Graphics doesn't work properly, though, so I'll see what the ATI-modder can do for me.Norway Pad wrote:I run Power Manager just fine on a T60 with Win8, but I ran into issues when I upgraded to Win8.1. It took 5 minutes to boot up, froze randomly and became unusable. I uninstalled as much as I could of system software and applications in an attempt to find the conflicting software, but it didn't work out. I can't say for sure it was Power Manager that caused it, but I couldn't remove Power Manager, as the uninstall file didn't work. Judging from your experience, it probably wasn't Power Manager, so maybe I'll create an image and attempt this upgrade one more time.
Bjorn
Norway Pad
Re: Windows 10
Just updated to what is described as "Windows 10 Pro Technical Preview Build 10049", which is an interesting experience. There is now finally something called "Tablet Mode" which maximises the Metro screen. In non-tablet mode, the Metro screen is what you see on the right hand side of the Start Menu, and it can be maximized and minimized back and forth. I remember some users here on the forum wished for something just like this when Win8 initially came out. So I think Microsoft is definitely onto something here, and I'm looking forward to Win10 comes out.
Bjorn
Re: Windows 10
I just installed the latest version on a W500. Went very smooth. Every device is recognized in device manager.
I had it in discrete graphics mode in BIOS when I upgraded.
Andrew Wolfe
Re: Windows 10
Have been using the windows 10 preview for a while now on a T500. All the drivers are now provided by microsoft and they work. The only nagging problem is the T500 has switchable graphics so every time there is a new build, the bios settings go back to switchable and I get a black screen but the thinkpad is running. I have to power off get to bios and set it back to discrete graphics and everything works fine.
On build 10159 microsoft has finally "fixed" this and no longer changes the bios settings. Will see if this breaks again in a new build. Just finished downloading 10162...... three builds in three days.
Owner of T500, T60P, T23
Re: Windows 10
Well, I'm on build 10240 and only 2 days off the launch date of july 29. It is running beautifully.
But in the "Get Windows App" suddenly it appears, that the T60 is not compatible and will not receive the much awaited update, because of the Radeon X1300 graphics.
So what does one do now? A possible workaround is simply to remove the display adapter in device manager. Surprice, the screen does not go black but some pnp-driver is there instead and there is still a functioning screen. And now the T60 is compatible!
Strange enough, the default "Microsoft basic display driver" is not compatible.
Hans-Henrik
- 1351 Views
Last post by ThinkPad560X
Fri May 19, 2017 1:57 am
x1 4th Generation with Windows 7 or 5th generation with Windows 10 - which to buy?
by mirc » Wed Apr 19, 2017 11:50 am » in ThinkPad X1/X1C - 5 Replies
- 553 Views
Last post by wpyh
Sat Apr 29, 2017 10:32 pm
- 563 Views
Last post by KingBubba
Sat May 13, 2017 11:26 am
x200T and Windows 7 update
by Billaboard » Sun Jan 01, 2017 2:57 pm » in ThinkPad X200/201/220 and X300/301 Series - 10 Replies
- 1719 Views
Last post by Bob_II
Wed Feb 15, 2017 7:42 pm
