T60P 15" WWAN antenna part numbers
RMSMajestic
Re: T60P 15" WWAN antenna part numbers
#31 Post by RMSMajestic » Thu Nov 27, 2014 10:45 pm
Peak2Peak wrote:The Huawei EM770 WWAN card is capable of PCM voice over USB with the correct firmware, utility software, the voice feature enabled on the EM770 and pin20 covered (for T60) ---> See post#1 EM770 + Mobile_Partner_11.302.09.01.539 = Voice Enabled
This enables voice calls through the T60's internal mic & speakers or via bluetooth headset (if your T60 is bluetooth enabled). The card also supports simultaneous Data & Voice providing your Sim & mobile network support it
Thanks for all the information
2 Questions:
1. Is your EM770 a lenovo module with FRU?
2. How would you use it for wifi hotspot?
Peak2Peak
#32 Post by Peak2Peak » Fri Nov 28, 2014 6:31 am
RMSMajestic wrote:Thanks for all the information
2 Questions:
1. The Huawei EM770 is a non-lenovo supplied card
2. Unable to comment as need to know how to set this up to prove
Thinkpad_enthusiast
Re: P/N: 41W4945 Location
#33 Post by Thinkpad_enthusiast » Sat Dec 13, 2014 3:41 am
Peak2Peak wrote:OK - I'm a little late to the party here as only just came across this posting
Sometime last year I stripped out a T60 15.0" with a factory fitted full WWAN kit and came across P/N: 41W4945 which was attached to the right hand hinge (see pix links) - I assume this could be some type of "mini WWAN" antenna to increase signal pick-up diversity(?)
The MAIN (Red cable) antenna P/N was 91P7027 & the AUX (Blue cable) antenna P/N was 39T9647 - I believe that this T60 was at one time connected to the Vodafone network as it had Vodafone sim card in the sim card slot/module and a Vodafone sticker on the base cover.
Thanks for the photos and information. Its really helpful to see where that mystery part goes. I am overseas at the moment and have only just got internet access thats worth anything at all hence the late reply.
