T60 upgrade CPU Question
Re: T60 upgrade CPU Question
These claims make perfect sense and in fact have been known and verified for a long time.
The only reason you cannot utilize the full 4GB is the MMIO space for PCI/PCIe devices. If you are willing to sacrifice these devices, you can free more of the address space for memory. But there are some things you cannot go without (graphics, ATA controller), and as mentioned, there are alignment requirements.
For practical purposes, if you want to keep the system usable and useful (with USB, networking, etc.), you are unlikely to get anything over 3.5GB addressable RAM. Not that I did the math, but I see no point in it. A few hundred megs here or there would not make any difference.
Regardless of the firmware (Lenovo BIOS vs Coreboot), the root of the issue is the 32-bit address space of the 945 chipset.
Coreboot only has an advantage because it allows you to free up some RAM by disabling certain devices.
But trading functionality for usable RAM might not sit well with users who want to "max out" their T60s.
Coreboot sounds more interesting on the X60, where Expresscard and discrete graphics are nonexistent. With 224MB shared video RAM + 128MB for Cardbus, you're looking at a little over 3.7GB max.
RIP: 760XD 9546-U9E
RIP: 760XD 9546-U9E
Well, you'll still need space for other devices - Ethernet, WiFi, USB Controller, ATA Controller. Does CardBus alone really take a full 128MB chunk? Plus there are alignment requirement which I am not sure about. Some devices may not need much space, but due to alignment requirements may block out a bigger block...axur-delmeria wrote:Coreboot sounds more interesting on the X60, where Expresscard and discrete graphics are nonexistent. With 224MB shared video RAM + 128MB for Cardbus, you're looking at a little over 3.7GB max.
ThinkMac2003
So if I disable certain devices like cardbus, Wifi which I don't need anyway, I can get more usable memory out for programs?
Not with the existing BIOS.ThinkMac2003 wrote:So if I disable certain devices like cardbus, Wifi which I don't need anyway, I can get more usable memory out for programs?
You need to install Coreboot for something like that.
ThinkMac2003
It's fascinating to read all these.
Where can I get Coreboot and steps to install it?
Why would you want to? For the sake of experiment?
See libreboot.org/docs/hcl/index.html#supported_list and www.coreboot.org for further information. Be prepared for the unexpected, though.
Cpu upgrade what cpu to search
by radiator » Sun May 21, 2017 12:45 am » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 529 Views
Last post by my03
Sat May 27, 2017 6:22 pm
- 682 Views
Last post by Muse
Mon Apr 24, 2017 7:22 pm
T520 cpu upgrade and fan
by Deschanel » Sun Jan 01, 2017 4:36 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 10 Replies
- 1358 Views
Sat Jan 07, 2017 2:43 pm
T420 Upgrade Options for CPU/Memory
by Farro » Tue Jan 24, 2017 4:19 am » in ThinkPad T400/410/420 and T500/510/520 Series - 8 Replies
- 1868 Views
Last post by jaspen-meyer
Tue Feb 28, 2017 8:32 am
