T60
tiorapatea
Re: T60
Not sure if this is relevant here, but I am running Windows 7 32-bit on a T60 with an ATI X1300, and my driver version is 8.561.0.0, driver date 01/12/2008 (UK locale so DD/MM). This appears to be a little newer than the Vista driver available on the Lenovo support site. I'm pretty sure this driver was just picked up by Windows update on a clean install.
T30 2366-92G, T60 2007-W63, T520 4239-CTO
Re: T60
Anybody with an answer??klausp wrote:Hi Lindsay,
How did you jump over the hurdle that GWX or the ISO image installation tells you that an upgrade is not possible?
With my system (T60, X1300) this is everytime the case...
Until now I did not find any way to go through the installation.
Would you please explain the steps you did?
Best wishes, Klaus
I've got the same problem. Been searching the forums for a couple of hours and haven't found a solution yet.
Re: T60
I have a similar T60 and had been getting two error messages from GWX, unsupported CPU and no suitable driver for your graphics card.klausp wrote:Hi Lindsay,
good to hear about your success.
Best wishes, Klaus
I downloaded the microsoft media creation tool to make a bootable usb installer. https://community.amd.com/external-link ... Fwindows10
Made the installer in windows then rebooted with the bootable USB installer in. I selected upgrade and download updates & it went some way through the setup program before marking the drive and telling me to reboot and run it from windows.
When I ran it in windows it halted and told me that my CPU (2400) did not have NX. I know that it does from running intel's CoreCPU. So I went into the BIOS > Security> switched Data Execution Prevention (or similar) to disabled. f10 to save and exit.
That solved the unsupported CPU problem and after a warning about no supported graphics driver it is currently running the installer. I hope that helps.
T60 2007 CTO 80Gb HD, T2400, ATI 128Mb Radeon Mobility X1300, Intel 3945ABG Wireless, Pro1000PL ethernet.
T42 2373 F1G; 40Gb HD, ATI 32Mb Radeon Mobility M7 LW, Intel 2200BG Wireless, Pro1000MT ethernet
- 982 Views
Mon Feb 06, 2017 12:11 am
- 667 Views
Last post by Muse
Mon Apr 24, 2017 7:22 pm
- 7 Replies
- 1374 Views
Last post by moosport2
Thu Dec 29, 2016 11:53 am
FS T60 - $100 + shipping
by moosport2 » Thu Dec 29, 2016 11:50 am » in Marketplace - Forum Members only - 5 Replies
- 700 Views
Last post by paul d
Mon Jan 23, 2017 1:43 pm
