Thanks for sharing the results about your new speedy T42p, upgraded with a SATA SSD!
Interesting! I had not before heard about SATA-to-PATA/IDE adapters for NGFF/M.2 SSD's but you got me Google'ing and I discovered e.g. M.2 NGFF (SATA) SSD to 2.5" IDE/PATA adapter with case (however using the somewhat "troublesome" conversion chip JM20330) which is probably (?) made by Sintech. Other similar (or the same, sold under a different name?) adapters includes the SLNX1016 NGFF M.2 to 44-Pin IDE Adapter and M-ware® Adapter NGFF M.2 b+m Key SSD to Mini-IDE 44pin ST5113 ID14977. Also, if I search for "NGFF SSD" on Newegg I find a product described as "Akust IDE 44pin to M.2 SSD Adapter with 2.5" Housing" but if following the product-link (Model # ZO05-0021-AKS, Item # 9SIA3TR2AR2551), Newegg report "Sorry, We can't find this Item." ?!? I also can't find it on Akust.com own homepage... spooky?MisterB wrote:I've been looking at ngff ssds with a 2.5 PATA adapter.
Anyway, before going with one of these JM20330-based adapters, I would encourage you to read about the not-so-few users who have had various problems with this chip... you'll find links to various threads in the sticky GUIDE: Make your T4x *FAST* by replacing the HDD with a SSD!
Johan
