Anyone still use a CRT monitor?
Re: Anyone still use a CRT monitor?
My 3 LCD monitors all have decent scalers in them and only one was a high end product. Two are XGA and do VGA and SVGA quite nicely. The best one is a Cornea 17" SXGA model is from around 2002 and can handle 15khz horizontal frequencies and goes down to 48hz vertical and can handle native Atari and Amiga display frequencies as well as 50hz PAL on the VGA input. You don't have to spend a lot of money to get an LCD monitor that scales nicely. Monitors with built in TV tuners and video inputs are the best bet since they have to deal with a wider range of signal frequencies. I need the HDMI scaler because the Cornea's DVI input doesn't support DHCP. My newer XGA TV/Monitor has component and HDMI input and can handle both NTSC and PAL video from both the video inputs and VGA port. It wasn't a particularly expensive monitor when it was new and is one of the few 4:3 LCD monitors I could find that had an HDMI input. My preference for 4:3 extends to external monitors as well.
Currently using: A W500, a W520, an X201T, an X220T, an X61T, a 14" T60P,a 15" UXGA T60P and a W700.
Currently idle: A spare W500, a spare X61T, a spare W700, a 14" T61, a 15" SXGA+ T60, a 14" T60, and my first Thinkpad, a 770X.
What an excellent find! That monitor is pretty much the non widescreen version of mine. Will you purchase the DVI to BNC connectors for it?Adda wrote:I just bought a Sony Multiscan GDM-F520!
T60p 2007-CT0 15" UXGA, ATI V5250, INTEL T7600, 3GB RAM, NMB Keyboard, HP Broadcom 4322AGN 802.11n Wireless Card, Sierra Wireless MC8775 WWAN, 250GB Momentus XT Hybrid drive
Yeah I was very surprised to find one, they are pretty much unobtanium.Worzyl wrote:What an excellent find! That monitor is pretty much the non widescreen version of mine. Will you purchase the DVI to BNC connectors for it?Adda wrote:I just bought a Sony Multiscan GDM-F520!
It's quite different from the FW900 though, it has much higher horizontal refresh rate (137kHz, 2048x1536@85Hz!) and finer dot pitch (0.22mm) witch is uniform across the entire screen (most Trinitron monitors have finer dot pitch at the center compared to the edges).
Not the largest, but the most high end monitor Sony ever made 30$
I have a VGA to BNC cable I used for my IBM POWERdisplay 20 (IBM branded mid 90's 20" Sony GDM model) so I'm all set.
ThinkPad A30
Pentium III-M 933MHz
Crucial 2x256MB 133MHz CL2
Mobility Radeon 16MB
15" UXGA FlexView
Zheino Classic A 32GB
Samsung SpinPoint M5S 160GB
NEC DVD+-RW ND-6650A
AKE BC168 USB 2.0
26P8287 203 "Malaysia"
46L4697
02K6898
02K6753
Aahh - I was hoping you was going for the DVI as I wanted to know the results as my current (very old) graphics card doesn't have DVI.
Also - that monitor doesn't seem to overly heavy for it's specs:
http://www.manualslib.com/manual/230552 ... e=2#manual
unlike mine
http://www.manualslib.com/manual/321698 ... e=2#manual
Be sure to report back when you get it.
unlike mine
Ah so you can get DVI-I to BNC cables after all, I gotta' get one sometime, not that I have any use of it at this time.Worzyl wrote:Aahh - I was hoping you was going for the DVI as I wanted to know the results as my current (very old) graphics card doesn't have DVI.
unlike mine
It'll probably be a while before I get it, it's not located near by.
ThinkPad A30
15" UXGA FlexView
AKE BC168 USB 2.0
46L4697
02K6898
02K6753
I had a 26" CRT HDTV until late last year. People would come over and be amazed by it. I only had my Wii hooked to it cause Mario was meant to be played on a tube TV. It had excellent PQ, but when I got the Wii U and wanted to use Netflix, things didn't come together well, so I gave it away to a friend for her kid's room and got a 32" LCD. The LCD has a nice picture and all, but it's not the same. Nothing lasts forever I guess.
E7440
raket
I use a CRT monitor on daily basis. It's a Samsung SyncMaster 959nr connected to my Thinkpad X61.
Mostly running i 1280x1024@85hz (browsing the web etc) and 640x480@160hz in gaming
Soon getting another one!
Thinkpad X61 T7100, 4gb ram, 160 gb hdd
Thinkpad X60 T7200, 2gb ram, 60 gb ssd
The Sony Multiscan GDM-F520 has arrived, and it is a monster!
1600x1200@107Hz, I may be able to push a bit higher though, I just started testing it.
I'll use it for a few days, as I know from experience, that such an old monitor (2003) that haven't been used for a while, will improve quite a bit over time, if used often.
Then I'll recalibrate it using WinDAS, convergence needs some work, but the monitor is in good working condition.
Edit: 1920x1440@90Hz!
ThinkPad A30
15" UXGA FlexView
AKE BC168 USB 2.0
46L4697
02K6898
02K6753
T60 BAD Bios flash (Still in Windows, havent rebooted)
by Sokre2000 » Mon Feb 06, 2017 5:25 am » in ThinkPad T6x Series - 8 Replies
- 1238 Views
Last post by Sokre2000
Sat Feb 11, 2017 2:16 pm
- 28 Replies
- 4657 Views
Last post by nforce4max
Sat Jun 10, 2017 10:52 pm
Still get a "Fan error" after replacing fan
by thinkpac » Sun Apr 02, 2017 12:44 am » in ThinkPad T6x Series - 7 Replies
- 1206 Views
Last post by thinkpac
Sun Apr 02, 2017 11:17 am
- 3 Replies
- 1150 Views
Last post by Kasm279
Thu Jan 12, 2017 4:29 am
