T410 on ebay minus the OS and HDD.
Hans Gruber
Re: T410 on ebay minus the OS and HDD.
Compressing your SSD or HDD is a Windows 7 operation. It has nothing to do with the CPU. Right click on your hard drive and look under the general tab. There is a compress your hard drive check box.
Compressing data in a file to reduce the amount of disk space it takes up does use CPU cycles, regardless if it appears as a Windows "feature". I don't think that there's a separate processor built into a hard drive that does this compression. The CPU is tasked to compress when writing and expand when reading files to/from the disk, as part of the normal system calls that perform disk I/O. Note that this file compression will not make any previously compressed files smaller. I would equate it to automatically running PKZIP or 7-ZIP on each and very file as it's being used.
Hans Gruber
I fixed the fan disk error computer. The fan works again but I still ordered a backup fan from China just in case. My next task is disconnecting the LCD as suggested and reconnecting it to make certain the wires are connected correctly.
I use a toothbrush to clean off the fan blades. I have a solution to canned air but it's more exotic. When I get my workbench up and running and my solution to canned air. I will post pictures. It will take me another month to have my garage retooled.
Any recommended battery sellers on ebay or other for the T410?
by Houndz » Tue Apr 25, 2017 6:00 am » in ThinkPad T400/410/420 and T500/510/520 Series - 3 Replies
- 768 Views
Last post by w0qj
Tue Apr 25, 2017 8:31 am
Ebay Link: T61p and X201 and others. (for parts)
by Thinkpad4by3 » Tue Jun 13, 2017 12:56 pm » in Marketplace - Forum Members only - 0 Replies
- 136 Views
eBay buy: T400s with 'seized fan' and possible supervisor password
by bob_brisket » Thu Apr 27, 2017 8:45 am » in ThinkPad T400/410/420 and T500/510/520 Series - 6 Replies
- 976 Views
Last post by bob_brisket
Tue May 16, 2017 5:24 am
eSATA power on both T410 and T420.
by thinkpadcollection » Thu Apr 27, 2017 2:59 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 5 Replies
- 758 Views
Last post by bit_twiddler
Sun Apr 30, 2017 11:11 am
