51nb's X62: latest update
nitrocaster
Re: 51nb's X62: latest update
Does X62 motherboard support X61 fingerprint reader?
fatpolomanjr
It does. My fingerprint reader works just fine for logging in to Windows 10. In fact the connection for it on the X62 motherboard is visible in photos.
As for Bluetooth: that is a very good question. I seem to not have it working in Windows 10, but I'll check it out in Xubuntu. e: neither does it work in Xubuntu. Bluetooth is working fine in Windows 10 now after either an update or a restart. Turning the physical wireless button off and on brings back Bluetooth in Linux. It has been working consistently in Windows.
T60/61 Frankenpad | 15" UXGA LED | T9300 | Intel X3100 | 8GB RAM | 256GB SSD | Manjaro i3 / Windows 7
X62 | 12.1" SXGA+ Xiphmont LED | i7-5500U | 8GB RAM | 256GB SSD | Xubuntu / Windows 10
Thinkpad 10 Tablet | Atom Baytrail | 128GB eMMC | 4GB RAM | Windows 10
Sorry if this has already been answered, but does anyone know where i can find windows 7 compatible drivers?
My WWLAN led is always on - is this the same for anyone else?
x220, w520, x201 (WXGA+), x61t (SXGA+)
Also having some trouble with the battery. On a fresh install of windows 7 and my brand new 8 cell battery refuses to charge. Anyone know of a possible solution?
I started a thread to organize known issues and fixes: http://forum.thinkpads.com/viewtopic.ph ... 2&p=790750
One covered is the "won't charge" issue. It looks like it won't report the rate, but is in fact charging for me.
Hi everybody!
I think this forum is better place to discuss about X62 than https://www.reddit.com/r/thinkpad/ since threads won't go down that fast. I hope everybody who have gotten their laptop or motherboard are satisfied with it. For others, I hope that you can receive yours before Christmas and you can always contact me in Reddit if you are in doubt.
Here's my review in Reddit and in the end there are few things you should do after receiving your laptop:
Installation were pretty easy, and I was surprised that I didn't have a lot of troubles. Just throwed in my HDD (mSata SSD is still on the way), Scandinavian layout keyboard instead of US one and installed Windows via USB Stick to it. After installation was complete, all drivers (excl. audio and sd card reader) were installed to it automatically. Those two missing drivers I found here: http://forum.thinkpads.com/viewtopic.php?f=30&t=122432. I had also problems with Scandinavian keyboard layout, ' and < keys weren't working. Fortunately, there was a bios update which fixes that problem (and also adds a Fn/Ctrl swap). The bios is available here: http://forum.51nb.com/thread-1716835-1-1.html (You can download it in the end of this post).
The performance of X62 is amazing compared to older thinkpads. Everything is running pretty smooth (not all, still waiting that SSD...) and no heat on palmrest at all. There has been a mistake in motherboard design, Wificard emits a small heat to the palmrest. That was gone, when I switched a energysaving mode on for the wificard. And for those, who want to take full potential out of wifi - the palmrest heat isn't very bad IMO.
For it's size, the screen has the ultimately good space for working and it is sharp and bright. That is the thing, I enjoy the most with this laptop. Unfortunately my laptop's screen had one stuck pixel on the far right and for now, no rubbing or Jscreenfix have made it alive. Well, I can't blame Jacky or the X62 builders about that - just a bad luck and it's not very annoying.
Audio card isn't very high quality, headphone jack isn't very good and the sound from the speakers is very "metallic". But this is not a Netflix laptop, and it doesn't try to be a one. Also fan noise is pretty annoying, it reacts too easily to the temp raises. The temps itself are low enough, between 40-75 degrees in normal use. I'm going to try out X200 fan, it should be more quiet with that.
I ran Passmark test and results were as expected from i7 Broadwell. CPU Score was about 4000 and 3D Score was over 300. Graphics score was a little too low for HD 5500, but games ran well. I made small test with Portal 2 as native resolution and medium graphic settings + 2xMSAA. Action scenes dropped fps near 30, but usually fps was between 40-50fps. The average fps in the 5 min test was 38 fps with 28fps as minium and 60fps (vsync on) as maximium. X62 should run lighter and games with good details and resolution and more demanding games with low graphics and resolution.
My first thoughts from this device were quite positive. 51nb.com community has made great work with the product and the result is amazing! There is some downsides with the product though and that is why it is laptop for the enthusiasts and old-school Thinkpad lovers. Linux has still problems with audio drivers, but I hope that those will be fixed in the future. After that I'm going to dualboot Windows and Linux and I think this laptop will handle well enough it's job as my main laptop.
Pros:
Performance seems to be good
Everything works (incl uk layout (scandinavian) keyboard, shortcut keys, fingerprint, Bluetooth, wifi, sdcard reader etc)
Screen is almost perfect! (had one stuck pixel in the left side, I'll try to fix it)
It was pretty out-of-the-box installation
No palm rest heat anymore (wificard delivered little heat to left side, but when it is in the energysaving mode - no heat at all!)
Cons:
Audio quality (this is not an Netflix laptop though)
Fan control sucks (temps are good, between 35-75, will try x200 fan to it, should make it quiet)
Links:
For those who assemble their own X62 - remember to trim chassis' USB3 port hole to prevent unwanted pressure to the port and the board (3 pics): http://forum.51nb.com/data/attachment/f ... memmmt.jpg http://forum.51nb.com/data/attachment/f ... i5bzpv.jpg http://forum.51nb.com/data/attachment/f ... g623uy.jpg
Bios update to enable Fn/Ctrl swap and support for non-US layouts (extract files from C117 to DOS bootable disk drive, boot from the drive and run upec to flash new bios): http://forum.51nb.com/forum.php?mod=att ... gzNQ%3D%3D
evening_hunger
In passing, you've summarized entire 2010s internet.nkwsky wrote:I think this forum is better place to discuss about X62 than /r/thinkpad since threads won't go down that fast.
x220/i7-2620M/8GB/256gb.ssd/ips/debian (main driver)
x230/i5/8GB/500gb.hdd+256gb.m2ssd/tn/debian+win7 (better half)
The fan thing is preventing me from getting one.
X220 i7-2640M | FHD IPS 12.5" | 16GB @ 1866 | 256GB mSATA | 2TB 5400 HDD
dmdsoftware
Do you think the X61s will fit into a X60s case?
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
"Think" Ultrabook i7
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
X60/X60s, X61, T61, T420, X30
past:
X24, X23, X22, X21, X20, 390X
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Yup, see this: http://forum.thinkpads.com/viewtopic.ph ... 02#p791402
dmdsoftware
Thanks a million.RealBlackStuff wrote:Yup, see this: http://forum.thinkpads.com/viewtopic.ph ... 02#p791402
It is time to make old new again. Was going to do this X62s mod. I have a slightly used X60s in storage and a fairly battered X61s. Was hoping I could take the base of the X60s + X62s motherboard + X61s screen
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Out of curiosity, does anyone know what Wifi antenna FRUs are / can be used with the X62 case? I broke my antenna cables, and the seller isn't responding to my emails any more.
Please check our Facebook page out and give us a like, we give latest updates about X62/T70/etc there! https://www.facebook.com/lcdfans/
And creshal, I'll ask it Jacky by myself. He is sometimes very difficult to contact... It is possible that he doesn't know about Wifi antenna FRU's, but in 51nb.com forums there are lot of people, who help. And usually HOPE (the guy behind this project) answer within a day. You should use google translate for better readability and making the registeration possible, but you can write your messages in English there. Here's link for X62 section: http://forum.51nb.com/forum-x62-1.html
-nkwsky
-nkwsky
dmdsoftware
Aren't they just the normal ones that come with X60/X61? Checked the hardware manual for the FRU?creshal wrote:Out of curiosity, does anyone know what Wifi antenna FRUs are / can be used with the X62 case? I broke my antenna cables, and the seller isn't responding to my emails any more.
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
dmdsoftware
What do you have to do for the CMOS battery? Does it take the X60/X61 CMOS battery?
Also, for the fan, can we use the same X60/X61 fan or is there a different power interface driving the fan?
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
There's five different antenna FRUs which seem to do different things (MIMO vs… something else), that's why I'm asking.dmdsoftware wrote:Aren't they just the normal ones that come with X60/X61? Checked the hardware manual for the FRU?creshal wrote:Out of curiosity, does anyone know what Wifi antenna FRUs are / can be used with the X62 case? I broke my antenna cables, and the seller isn't responding to my emails any more.
@CMOS battery: Ought to be exchangeable, I think there's one model for all Thinkpads made in the past ~15 years.
@Fan: I wouldn't replace it, if I had the choice again. No matter which fan you install, it's too loud because of the broken fan control.
dmdsoftware
I ordered a X62 motherboard package only, not a whole X62 system.creshal wrote:There's five different antenna FRUs which seem to do different things (MIMO vs… something else), that's why I'm asking.dmdsoftware wrote: Aren't they just the normal ones that come with X60/X61? Checked the hardware manual for the FRU?
Boards alone don't come with CMOS battery, so as long as it uses a proper Thinkpad battery, ought to be ok
Fan may or may not fit because X6* series had three different fan sizes (all with common fan plug) -- t, s, regular. I'm wondering if there was something different about the X62 fan to make it "different" then a typical X6* fan other then size placement.
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
dmdsoftware
Thanks for "trying" to answer the questions. Can someone who has a board share answers?creshal wrote:There's five different antenna FRUs which seem to do different things (MIMO vs… something else), that's why I'm asking.dmdsoftware wrote: Aren't they just the normal ones that come with X60/X61? Checked the hardware manual for the FRU?
I proceeded with the install today. The CMOS battery IS NOT THE SAME. The connector from the X60s battery is completely different. Can someone advise what kind of CMOS battery this is so that I may order one.
The fan is completely different too. The fan that I ordered fits nice and is quiet. I can't hear it when it is running, but I can feel the air blowing out, so I know it is working. Maybe I lucked out with the fan or it is a revised fan, since most X62 folks report noisy fans.
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Someone told on reddit that the X62 is able to accept a m.2 SSD.
Is it really m.2 or msata?
What form factor is compatible, 2242?
No need for being an [censored]. You realize I typed out that answer on an X62…?Thanks for "trying" to answer the questions. Can someone who has a board share answers?
Slot is mPCIe, with screw holes for half and full size as far as I can tell. Haven't yet tested whether mSATA works.Someone told on reddit that the X62 is able to accept a m.2 SSD.
dmdsoftware
The m.2 slot is a bit different and the motherboard doesn't have the correct slot. I haven't tested the WWAN slot with a mSATA. I can confirm th WWAN slot doesn't work with a wifi or wifi combo card.binbash wrote:Someone told on reddit that the X62 is able to accept a m.2 SSD.
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Hope msata works like on my X230, it's really cool, you can use one with GTP/UEFI and the other with bios/msdos.dmdsoftware wrote: The m.2 slot is a bit different and the motherboard doesn't have the correct slot. I haven't tested the WWAN slot with a mSATA. I can confirm th WWAN slot doesn't work with a wifi or wifi combo card.
Heard about Qubes OS? It's a really secure OS using Xen (security by compartmentalization), but only a few laptops can run it without issues. Thinkpads are relatively well supported, I really hope the x62 board could run it! It needs VT-x and VT-d.
https://www.qubes-os.org/hcl/
I can confirm that msata will work on X62. I have 250gb samsung 850 evo msata SSD + 2.5" 1tb HDD combo myself.binbash wrote:Hope msata works like on my X230, it's really cool, you can use one with GTP/UEFI and the other with bios/msdos.dmdsoftware wrote: The m.2 slot is a bit different and the motherboard doesn't have the correct slot. I haven't tested the WWAN slot with a mSATA. I can confirm th WWAN slot doesn't work with a wifi or wifi combo card.
-Joni "nkwsky" Niinikoski
Thanks scrfce/nkwsky for the confirmation!
My X62 will be overkill! With 1TB Samsung Evo pro SSD + 512 GB msata samsung evo ssd and 32 GB Crucial RAM kit
Anyone could confirm that Crucial 32 GB kit (CT2KIT204864BF160B) will work fine with the X62?
dmdsoftware
Crucial ram is the one to get for this, from what I read. I bought the 8GB DDR3L Crucial and works great. CT2KIT204864BF160B will work it looks, from the specs. Got a good price for it? Can't find it < $500 up here in Canada.binbash wrote:Thanks scrfce/nkwsky for the confirmation!
My X62 will be overkill! With 1TB Samsung Evo pro SSD + 512 GB msata samsung evo ssd and 32 GB Crucial RAM kit![]()
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Cool! Yes, here in Switzerland I can get the 32GB kit for ~320 USD
I think they will deliver to Canada too.
Here is the link:
http://www.pc-ostschweiz.ch/fr/product- ... r=12833201
Here is the link:
According to their general business terms, they only deliver to Switzerland and Liechtenstein.
They also charge everybody 2.49% commission for credit card or PayPal use, NOT nice...
But perhaps binbash could act as your go-between?
Of course, I will help with pleasure.
dmdsoftware
Perhaps that bundle is being replaced with another? I notice the reason why it is so expensive here is the supply of them is low. Only available from two major retailers, and "out of stock" everywhere else.
Lucky, I don't need more RAM urgently. If I see it at the right price, I'll pick it up.
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
How many of you have already got the X62? And any new interest?
by RMSMajestic » Thu Jan 26, 2017 6:10 pm » in Thinkpad X6x Series incl. X6x Tablet - 35 Replies
- 4355 Views
Last post by xsixt
Mon May 15, 2017 5:42 am
Possible 4th batch of x62's
by jaspen-meyer » Wed Feb 15, 2017 3:14 pm » in Thinkpad X6x Series incl. X6x Tablet - 10 Replies
- 1918 Views
Last post by wujstefan
Fri Mar 31, 2017 4:53 am
Coreboot on X62?
by flyingfishfinger » Tue Feb 21, 2017 4:10 pm » in Thinkpad X6x Series incl. X6x Tablet - 0 Replies
- 1359 Views
Last post by flyingfishfinger
X62 review by NotebookCheck
by Puppy » Mon Apr 10, 2017 6:03 am » in Thinkpad X6x Series incl. X6x Tablet - 2 Replies
- 966 Views
Last post by brchan
Wed Apr 12, 2017 10:00 am
