Interest in upgrade your T420/T420s/T430/T430s to FHD 1080p
Locked
Interest in upgrading T420s/T430s to FHD 1080p
Poll ended at Sun Jun 14, 2015 10:43 pm
I'll pay full $50 for such board
71
72%
I'll pay a deposit and wait
4
4%
I'd rather pay a bit more for the kit to be shipped directly to me
14
14%
I'm not interested, the original IPS is good enough
5
5%
Other
4
4%
Total votes: 98
kozukumi
Re: Interest in upgrade your T420/T420s/T430/T430s to FHD 1080p
#181 Post by kozukumi » Thu Sep 17, 2015 1:29 pm
Is there anywhere to get this in the UK?
How difficult is the mod? I am fine with build a computer but that is just pluging components together. Is this as simple as that? If it is more difficult is there anyone in London, UK willing to do the upgrade for a bit of cash? I am very interested in this!
plympton
#182 Post by plympton » Thu Sep 17, 2015 1:35 pm
kozukumi wrote:Is there anywhere to get this in the UK?
It's a bit harder than plugging in a PCIe graphics card - you have to unscrew .. A .. Lot.. Of screws and keep track of things, how they go together, etc. If you are methodical, there's not much more to it than screws, tape, and plugging things in. No soldering or anything complicated like that.
kozukumi
#183 Post by kozukumi » Thu Sep 17, 2015 2:18 pm
Thanks. I am fine with screws and cabling. Taken this 420s apart except for the display assembly which I guess I will have to learn to do this! So all I need is this board and a known compatible display? I want to get a good quality 1080p IPS. Will it run at 60Hz without issue? Is it possible to do any higher on the refresh if I can get a panel that does higher or is that a limitation that can't be worked around?
My T420s is the HD3000/4200M model but I set it in the bios to only use the HD3000 integratrated as I don't play games, etc. and the Intel is more than good enough for me. Will this board still work with my configuration or will I need to reenable the 4200M?
plympton
#184 Post by plympton » Thu Sep 17, 2015 2:22 pm
I have the same config, and use the HD3000 graphics exclusively (disabled optimus in BIOS). Works great. Yes, just need kit and display. No idea about refresh rate, but would assuming nothing other than stock rates are possible.
anonT430S
#185 Post by anonT430S » Thu Sep 17, 2015 3:40 pm
I just wanted to chime in that I was successful with this mod for a T430S. Very happy customer.
With that said I might offer a couple of suggestions for the kit:
1. Shorten the cable so that we don't have to bend it into an 'S-shape' to get it to plug in.
2. Provide some way to stabilize the converter board to the mobo mount location. I think it's probably stuck in there pretty good with the thermal pads on top of it but it was tricky plugging in the LCD cable without dislodging the converter cable.
3. Update the directions to exclude the scotch-tape step since that appears to already have been done for us.
4. Provide a reason to use the non-conductive tape. I cut it to length and applied it to both sides of the converter cable but then realized it was probably included to resecure the antenna cables. Still unsure about it.
pekmop1024
#186 Post by pekmop1024 » Sat Sep 19, 2015 4:51 am
I'm interested in working T420 converter too, will buy one when available.
Now my T420 equipped with X1 LCD, but those viewing angles ... :(
Thinkpad T420 Frankenpad Edition: Core i7 2720QM/16GB RAM/1TB Samsung 840 EVO/X1 Carbon LCD/Sierra MC7304/Intel 7260AC/Matshita UJ260AF/9 cell battery
hhhd1
#187 Post by hhhd1 » Sun Sep 20, 2015 12:08 pm
The link here says:
http://www.ebay.com/itm/231665072220
Q: Which screen do you recommend?
A: Personally, I'd recommend B140HAN01.2, B140HAN01.3, other screens are better used with color calibration.
is there a glossy option with high color gamut, that doesn't require calibration out of the box ?
does the B140HAN01.3 have high color gamut ? (no information available on panelook)
is the B140HAN01.3 glossy? (getting mixed info from googling)
or,
is the B140HAN01.0 good without calibration ?
fb1996
#188 Post by fb1996 » Sun Sep 20, 2015 1:51 pm
hhhd1 wrote:does the B140HAN01.3 have high color gamut ?
Well, my B140HAN01.3 covers 99.7% of sRGB and 77% of Adobe RGB according to my measurements with a Spyder4Pro... :roll:
10 (1st Gen), T420s, T440 FrankenPad, X1 Tablet (1st Gen)
hhhd1
#189 Post by hhhd1 » Sun Sep 20, 2015 2:59 pm
Thanks, That is very good to know :)
Is it glossy ?
Does it work good enough in your opinion without color calibration ?
fb1996
#190 Post by fb1996 » Mon Sep 21, 2015 12:26 am
No, mine is a matte one ;) It isn't that bad without calibration, but it had a blue tint.
hhhd1
#191 Post by hhhd1 » Mon Sep 21, 2015 11:33 am
Thanks. :)
That is strange, .... because I see here:
http://www.panelook.com/modelcompare.ph ... 3640,20494
panelook.com is saying that the B140HAN01.3 is glossy,
Goggling a bit more, i see datasheet pdf files saying that the B140HAN01.3 is indeed matte surface.
wonder if anyone know if this screen available with both surface types (unlikely)
or if panelook.com have the info wrong..
JamesPeters
#192 Post by JamesPeters » Thu Sep 24, 2015 3:25 pm
djammin16
#193 Post by djammin16 » Tue Sep 29, 2015 9:13 am
JamesPeters wrote:Is the next batch going to be more of the same kit as the current batch, or is that a new design hopefully with a bug fix for non-S models (T420)?
^This...and will the next batch work with a 2560x1440 display on the T420 without utilizing the displayport?
djammin16
#194 Post by djammin16 » Fri Oct 02, 2015 7:13 am
I just got my adapter yesterday and installed it in my wife's T420s. I used the adapter with a matte B140HAN01.2 screen. It works great! My wife was coming from the 1600x900 screen and was amazed at how bright, colorful, and crisp the graphics were and said she didn't even know she needed the upgrade. She dabbles in photography and photo editing and thought the difference was remarkable. Oh, and she said all this was BEFORE I calibrated the screen.:D
This is well worth the money and time (use patients) to install it. When a working version for the T420 comes out that works with a WQHD display I'll get one of those and post up about it too.
Thank you RMSMajestic this mod has and will breath new life into the T420 series!
Edit: Grammer.
pekmop1024
#195 Post by pekmop1024 » Fri Oct 02, 2015 2:01 pm
What about non-s kits for T420 in the next batch? Any chances?
XaS
#196 Post by XaS » Fri Oct 02, 2015 3:34 pm
Hi all!
I just found this thread and suffering from an original T420 AUO screen with door effect, poor colour and horrible viewing angle I am highly interested in a display upgrade (as long as the new screen is matte as well). So I would like to express my interest in one of your amazing kits. Is there any chance of getting one to Switzerland (postal adress in Germany also possible and maybe even preferable)?
Thank you all and greetings from Switzerland! :D
MfG XaS
kony
#197 Post by kony » Mon Oct 05, 2015 9:31 am
Could you help me out with buying this equipment? I want to order it within a country (that is China, as I'm living here now), but I'm not sure whom should I contact or where should I look to get this device.
My T430 with GTX 560 Ti (Now with GTX 670)
T430: i5-3320m, 8 GB, SSD + HDD, 1600x900.
#198 Post by RealBlackStuff » Mon Oct 05, 2015 10:44 am
kony wrote:... within a country (that is China, as I'm living here now)...
How about changing your User Control Panel with your new location?
meatjelly
#199 Post by meatjelly » Mon Oct 05, 2015 5:41 pm
XaS wrote:Hi all!
MfG XaS
I just bought a T420 as well and was really disappointed with the screen. Everything else about this laptop is fantastic, but I almost returned it just based on how horrible the screen was! Now that there's hope of replacing it with an FHD, I'm keeping it. :)
RMSMajestic
#200 Post by RMSMajestic » Tue Oct 06, 2015 12:35 pm
this batch of slim kits are officically out of stock. And I'll focus on job/intern hunting until maybe mid-November, however if there's any updates for the non-s kits I'll post here. I'll not respond to PMs regarding this matter from today onwards.
RMSMajestic
Exphy
#201 Post by Exphy » Mon Oct 12, 2015 12:33 pm
RMSMajestic wrote:this batch of slim kits are officically out of stock. And I'll focus on job/intern hunting until maybe mid-November, however if there's any updates for the non-s kits I'll post here. I'll not respond to PMs regarding this matter from today onwards.
RMSMajestic
Thank you for the update. Love the screen in my T420s. Would love T420 with a quadcore and this IPS screen
munzab
#202 Post by munzab » Mon Oct 12, 2015 1:14 pm
RMSMajestic
I am very interested in buying this kit for my t430s that badly needs some love. Please let us know when its available ill buy immediately for use in ireland
chx1975
#203 Post by chx1975 » Mon Oct 12, 2015 1:21 pm
We will wait patiently until you return -- we waited four years after all :) I have bought two little suction cups for LCDs so I am well prepared :)
djammin16
#204 Post by djammin16 » Tue Oct 13, 2015 7:55 am
I've not had a 1366x768 14" screen, I bought the laptop with the 1600x900 version. One of my friends has a 1366x768 screen, and I thought there wasn't enough space to be usable and the picture looked grainy. I can say that the text looks crisp and clear on the new 1080P screen; really, everything looks better. Additionally I haven't needed to do any scaling in Windows to make the text readable. At this point I think that a 1080P resolution on a 14" screen is the sweet spot. Once he releases a batch of boards that will allow for a 2560x1440 screen, I'm going to test that. It may be too much though. We'll see.
Tasurinchi
#205 Post by Tasurinchi » Tue Oct 13, 2015 2:52 pm
Another happy end! (for me at least)
I asked RMS to sell me a non-s kit, fully knowing that it may flicker. But my T420 had a damaged screen so I had little to lose.
I have to report that there is no single flicker in my setup (at least so far) :banana:
- I got a B140HAN01.0 panel this time (my two T420s have B140HAN01.2 models), it's a glossy one but I don't care. The colors and contrast are fantastic!
- I tested watching FHD YouTube trailers first, both without battery and battery only. No flicker! Watching trailers while charging the battery did not produce any flicker.
- I watched then a full 1080p movie, again with and without battery, and then again with battery while charging. No flicker!
This T420 is running Debian 8 (with no special software) booting out of a mSata SSD and a HDD for data. I have 8GB RAM. Intel graphics.
I'll keep the tests today and tomorrow, will report back if it starts flickering...
Flemingo
#206 Post by Flemingo » Wed Oct 14, 2015 10:44 am
Tasurinchi wrote:Another happy end! (for me at least)
I asked RMS to sell me a non-s kit, fully knowing that it may flicker. But my T420 had a damaged screen so I had little to loose.
Congrats! and hope it lasts without any issues for a long time!
Can you please share a photo of the glossy vs matte in the instances above? In an example photo and example text too please. I plan to upgrade my T430 as soon as the kits become available so just doing a little homework beforehand. TBH, a little skeptical about how the text size would appear under 1080p in 14 inch screen and whether or not it will require any zooming etc.
Thanks in advance!!! I know I am asking for a lot...
Tasurinchi
#207 Post by Tasurinchi » Wed Oct 14, 2015 2:21 pm
Flemingo wrote:Thanks in advance!!! I know I am asking for a lot...
No problem! I'll wanted to do a comparison anyway. I will get some pics done this weekend :wink:
shane1027
#208 Post by shane1027 » Wed Oct 14, 2015 8:32 pm
I second this!! The T420's and 430's are wonderful machines aside from the screen drawbacks, I'd order a few kits if your findings on flicker-free hold true :)
Thanks a lot for your work on this subject Tasurinchi!!! Also, I'd sacrifice my T430 for the sake of testing the flicker if you're interested. Heck, I'd buy the converter even if it did flicker if it meant 1080p IPS...
T430s: i7-3520M | 16G | B140HAN01.0 IPS | 2 x 120G SSD | Flashed EC for T420s UltraBay Battery | Arch Linux + Win 7 | CoreBoot Soon to Come :)
Uriel718
#209 Post by Uriel718 » Thu Oct 15, 2015 4:01 pm
Greetings!
Been using ThinkPads since the 1990's models. Just retired my old T400 and got a new (used) T430s. It's perfect in every other way, except the screen. This has to be the worst screen I've ever used. The colors and definition (HD+ 1600x900) are fine, but the screen door effect (or whatever it's called) is really a massive disappointment. I've read around the forums, and as far as I can tell, I got pretty much the worst screen option available.
Long story short. I'd really love to replace this screen with a better one. So when ever you are back in business, I'd definitely buy what you're selling.
ThinkPad T430s - 2356FS1
Screen - B140R102 V1
alexthefifth
#210 Post by alexthefifth » Thu Oct 15, 2015 11:16 pm
Can't believe I missed this. Please add me to the list if you ever do a batch for t430s again!
Locked
