Interest in upgrade your T420/T420s/T430/T430s to FHD 1080p
Locked
Interest in upgrading T420s/T430s to FHD 1080p
Poll ended at Sun Jun 14, 2015 10:43 pm
I'll pay full $50 for such board
71
72%
I'll pay a deposit and wait
4
4%
I'd rather pay a bit more for the kit to be shipped directly to me
14
14%
I'm not interested, the original IPS is good enough
5
5%
Other
4
4%
Total votes: 98
Tasurinchi
Re: Interest in upgrade your T420/T420s/T430/T430s to FHD 1080p
#451 Post by Tasurinchi » Sun Mar 06, 2016 4:54 pm
Sure, I'll try that tomorrow
javauma
#452 Post by javauma » Mon Mar 07, 2016 3:19 am
Nugen wrote:I couldn't get the upgrade kit to work. I have the B140HAN01.2 screen and all I can get is the backlight to work but nothing else appears on the screen. I've checked the fittings and connections are snug and tight. When I remove the upgrade kit and reconnect the original screen everything works as normal.
Is there any trick I should know about or is the kit or screen defective?
Edit: I have a T430s with the latest BIOS version.
I have exactly the same problem on my T430s, waiting for a replacement.
T430s with intel HD4000 graphics
B140HAN01.2
crashnburn
#453 Post by crashnburn » Mon Mar 07, 2016 6:29 am
For this part we can see the TP HMM but for the Kit related stuff, what tutorial with pics did you follow - cause there are several out there.
Tasurinchi wrote:Well, the standard procedure actually... Removed battery, keyboard, palmrest, LCD bezel and the old awful panel.
Then plugged the cable from the kit in the new panel, the other cable end in the adapter, installed the new panel and plugged the adapter in the motherboard. E voila!
In a T430 is easier than the T420, in the latter you have to snap a small piece of the mg frame to make room for the adapter.
Is there a with pics tutorial for the kit?
Tasurinchi
#454 Post by Tasurinchi » Mon Mar 07, 2016 7:41 am
crashnburn wrote:Is there a with pics tutorial for the kit?
Yes, this one (I think there may be more in the previous pages of this thread).
There's also a good tutorial for the T420s/T430s in the German forum, the pictures are quite self explanatory but you may need to use Google translator if you want more details => link
SaskFellow
#455 Post by SaskFellow » Mon Mar 07, 2016 4:29 pm
crashnburn wrote:
SaskFellow wrote:Lenovo's spec sheets are a little awkward...
T420/T520 maximum external display resolution: 2560x1600 (DisplayPort)@60Hz
T420s maximum external display resolution: 1600x900@60hz(DVI SingleLink mode) {3840x2160@30hz unofficial}
But we know from the 4K display thread, we know the T420s can drive 4K@30hz but not 60hz. So I'd think the external DP port on the T420s would be able to drive the same 2560x1600@60hz. Also, from that link we know the external DisplayPort connection is at least DP1.2, so that's good news.
I'd not push over 2K for a display, but then again, I can't stand a 30hz display. :mrgreen:
Thanks for the insights. Where do the X220/T stand on a similar note. And what about the next gen i.e. X230/T & T4/530 series?
PS: Which 4K display thread? I tried search but forum search ignores 4k even if I put "4k display"
This is the thread I was referencing: http://forum.thinkpads.com/viewtopic.php?f=18&t=120427
T61 14.1 WXGA+ 220nit, T9300, Owl blade fan cooler, 8GB PC2-6400, 2010 revised NVS140M, Samsung 840Pro 240GB, AR9390 N, BT4.1, NMB keyboard, T400 palm-rest, 33++ battery.
T420s 14.0 HD+, i7-2460M, 16GB PC3L-12800, NVS4200M, Samsung 850Pro 512GB, Intel 7260AC, BT4.1, Chicony KB, 81+ battery
Tasurinchi
#456 Post by Tasurinchi » Mon Mar 07, 2016 4:54 pm
Niklas wrote: This will tell you what frequencies your cores are operating at, and you'll be able to tell if tb is in use.
Terminal says
root@T430:/home/xxx# grep MHz /proc/cpuinfo
cpu MHz		: 3099.992
cpu MHz		: 3100.093
cpu MHz		: 3123.046
cpu MHz		: 3127.820
The CPU is rated at 2.60MHz it looks like those higher frequencies are due to turbo boost, am I wrong?
bepposax
#457 Post by bepposax » Tue Mar 08, 2016 5:46 am
B140HAN01.2
Same problem, waiting too.
T430s. Core i7, 8GB RAM, Intel SSD 520 180GB, Samsung 850 EVO mSATA SSD 250GB, Intel HD Graphics 4000
Niklas
#458 Post by Niklas » Tue Mar 08, 2016 9:38 am
Terminal says
cpu MHz		: 3099.992
cpu MHz		: 3100.093
cpu MHz		: 3123.046
cpu MHz		: 3127.820
Yep. Cool, now we know for sure that it works with turboboost! Would be great if someone with a quad core would report the same success!
peca89
#459 Post by peca89 » Tue Mar 08, 2016 9:49 am
I'm really glad it works with i5-3320M with Turbo Boost as this is exactly the CPU I've got in my T430 (non-s). I'm still looking forward for new batch of adapters to upgrade my screen.
Wardenclyffe
#460 Post by Wardenclyffe » Tue Mar 08, 2016 12:01 pm
I'll take a kit for the T420s!!
I just got a T420s in sad shape for really cheap to restore, and it's coming along nicely. Parts are very cheap.
zarpanzur
#461 Post by zarpanzur » Fri Mar 11, 2016 7:44 am
Wardenclyffe wrote:I'll take a kit for the T420s!!
If you need some parts, hit me up. I was going to restore my T420s and ordered many new parts but then I found a brand new, sealed, mint in box T420s so I don't need the parts anymore.
I have the top cover lid, LCD bezel, logo strip, brand new genuine Lenovo battery, genuine AC adapter and probably a few more parts.
zarpanzur
#462 Post by zarpanzur » Fri Mar 11, 2016 7:45 am
Just checking in, RMSMajestic, how are things looking? Are you still predicting more kits for late march/early april?
zarpanzur
#463 Post by zarpanzur » Fri Mar 11, 2016 7:48 am
B140HAN01.2
I had the same problem. Probably a defective chip.
csgrmb
#464 Post by csgrmb » Sat Mar 12, 2016 4:26 pm
For those of us with T420 (non s) integrated graphics, it looks like there is some room where the dGPU would be. Has anyone tried placing the pcb there instead?
VanZan
#465 Post by VanZan » Sun Mar 13, 2016 1:31 pm
Interested in this but I have the regular T420 not the S model. If you suss out how to stop the flickering then I'll be all over this like a fly on sh*t.
RMSMajestic
#466 Post by RMSMajestic » Mon Mar 14, 2016 2:12 am
zarpanzur wrote:Just checking in, RMSMajestic, how are things looking? Are you still predicting more kits for late march/early april?
perhaps mid April. Started my part time internship now, it's really hard to make time while pursuing a master's degree. >_<
Also, that batch will be the last of this year presumably.
If the non-s kits come out or the 2K version come out I might do another batch or two for tasters though.
Wardenclyffe
#467 Post by Wardenclyffe » Mon Mar 14, 2016 10:32 am
Is there anywhere else to aquire the converter board for the S? I haven't had any luck on eBay or otherwise.
Wardenclyffe
#468 Post by Wardenclyffe » Mon Mar 14, 2016 10:35 am
Interested, sent you a PM
teleshoes
#469 Post by teleshoes » Tue Mar 15, 2016 2:24 am
RMSMajestic wrote: If the non-s kits come out
max_power
#470 Post by max_power » Wed Mar 16, 2016 3:02 pm
While searching on the internet for a replacement for my X200s, I found this forum and this thread here. This mod is so awesome! My next Thinkpad will definitely be a T420s.
I will take a kit for the T420s!
tomekck
#471 Post by tomekck » Wed Mar 16, 2016 3:50 pm
I will pay for upgrade for my T420 (non-s)
zarpanzur
#472 Post by zarpanzur » Thu Mar 17, 2016 3:16 am
Just for any new visitors, this mod is 100% legit and super easy to do if you're comfortable with taking apart electronics.
SchiefesFenster
#473 Post by SchiefesFenster » Fri Mar 18, 2016 6:35 am
Hi guys,
just registered because I want to buy the kit for T420 (non s).
Thanks Majestic for putting effort in this. Good luck with your studies and internship as well :)
Czenkov
#474 Post by Czenkov » Fri Mar 18, 2016 11:00 am
Registered some time ago to buy the kit for my T420s.
Is the ETA mid April or will it likely change ?
Regards,
turomini
#475 Post by turomini » Fri Mar 18, 2016 12:16 pm
Czenkov wrote:Hi,
Regards,
RMSMajestic wrote:perhaps mid April. Started my part time internship now, it's really hard to make time while pursuing a master's degree. >_<
He posted the mid April ETA four (4) days ago. I don't think his plans have changed in 4 days.
Hopefully he'll have enough of them, I want to grab one before it gets too late.
lightproof
#476 Post by lightproof » Fri Mar 18, 2016 3:12 pm
Will absolutely get the kit for my T430s. Can't do any of graphics work while on the go, so an IPS screen would be a dream come true!
Don't know why everybody started checking in all of a sudden, but, on the other hand, why not? Hope it helps RMSMajestic gauge the demand for the upcoming batch(es) ;)
ThinkPad T430s — i7, HD 4000, 16GB RAM, 128GB mSata + 320GB HDD
SaskFellow
#477 Post by SaskFellow » Fri Mar 18, 2016 8:17 pm
turomini wrote:
Czenkov wrote:Hi,
Regards,
Hey hey,
Back of the line, my T420s needs some love!
I'm sure he'll have enough to appease the rabid forum goers...
If not...
Cage matches! :banana:
RMSMajestic
#478 Post by RMSMajestic » Fri Mar 18, 2016 8:48 pm
As I've mentioned in the listing please be aware of the chinese sellers (including those from HK) selling refurbished screen or EDID modified screens.... :/
It really cost a little for those sellers to print a B140HAN01.2 label, and most laptops will work regradless of the true screen model as long as the screen is 30 pin edp, however unfortunately this kit doesn't support that many screens.
And yesterday I purchased a B140HAN01.2 (******From a USA seller********), but received a LP140WF3-SPL1 as compatible screen instead.
Guess from the next batch onwards I might have to assign certain seller for the source of screens.
turomini
#479 Post by turomini » Fri Mar 18, 2016 8:52 pm
RMSMajestic wrote:As I've mentioned in the listing please be aware of the chinese sellers (including those from HK) selling refurbished screen or EDID modified screens.... :/
It would be great if you did. I have been looking around at screens, and a lot of the listings either are lacking information, not clear, or just not trustworthy. Mostly not trustworthy in my opinion.
zarpanzur
#480 Post by zarpanzur » Sat Mar 19, 2016 4:36 am
For what it's worth, I bought my screen from here: hxxp://www.aliexpress.com/item/Original-new-B1 ... 92594.html
I made sure to tell them that I want an exact model with no defects, dead/stuck pixels, white spots or scratches.
The screen is working beautifully. What I did notice though is that battery life is terrible after the IPS screen was installed, and I'm using two batteries in my T420s. I don't mind though because I use the laptop plugged in most of the time but this may be a problem for more mobile users.
Locked
