It's a 15in IPS model that runs Openbox on Arch, I've never run any Windows on it.kfzhu1229 wrote:The CPU goes up to 2.26Ghz (Pentium M 780)
I did not notice too much difference between a 1.86ghz 750 and 780 since they all have the same TDP.
720p is 100% fine for local file playback and can also handle youtube 720p but not 60fps.
I would say 720p utilization is around 30% to 60% depending on the video quality and codec (MPEG2 requires much less CPU power due to the GPU acceleration and lower quality but H264 would certainly take 60% CPU power for a Pentium M 780 but the image quality looks amazing)
The top 2.26ghz also handles some 1080p video playback while the common 750 simply cannot.
MPC is recommended because it outputs maximum efficiency even though the UI does not look too good.
Since my last post i was puzzled by the CPU/temps/fan speed & general performance post upgrade.
First some background I got it originally from ebay for 15GBP sans HD/memory & it was described as spares only. Since adding HD/caddy & memory I've used it for work doing standard ops and while the performance was OK & it never hit me as a great performer the IPS screen made up for that even if the fan was knackered. It never could keep up with my 2Ghz X32 doing the same arch upgrades which I put down to CPU difference & it being generally in poorer condition unmatched RAM etc etc.
However by yesterday evening it was clear the initial snappiness noted was an illusion and yes it played 720p video a tad better, the performance using my existing docs/web browsing showed little increase and the temps settled down to being +/- 1/2C as before depending on load.
After using powertop/inxi system utility i noticed the CPU wasn't doing anything at other than 800Mhz [RBS & ajkula66 can start laughing now - they probably know why instantly - took me a bit longer pouring thru the BIOS power management pages] Initially i thought the ebay CPU was locked in low speed mode as it as a reject. I've never looked at the T43 BIOS before and it had speedstep power AC settings set to Auto & balanced modes which i changed to Max Perf - lo and behold the CPU realised it's a 2.13Ghz and now most web pages load instantly. It gets hotter rapidly when utilized fully but the fan speeds up far quicker and peaks over 1000rpm higher than before and it cools quite rapidly down to its idle temp of 51C. Totally different system now
