Looks like a new W7xx (edit: 17" P70, and P50 replacing W541) is coming out? (small pics)
Re: Looks like a new W7xx (edit: 17" P70, and P50 replacing W541) is coming out? (small pics)
I'm not sure that's a middle scroll button - on the Dells that I support, the one for the pointing stick is for scrolling, the one for the trackpad is for middle-clicking, and you use two-finger scrolling (like a Mac) on the trackpad.
I can't speak to the software for the Dells, but the Synaptics hardware used in HP workstations have software to assign them either way. My preferred configuration is to disable the touchpad while retaining the use of the lower button set, thus getting left, right, middle, and scroll buttons. When I started using CAD software on a daily basis on it, middle click became a necessity for panning/zooming (combined with right click) if I didn't have my trackball and 3D mouse with me.bhtooefr wrote:I'm not sure that's a middle scroll button - on the Dells that I support, the one for the pointing stick is for scrolling, the one for the trackpad is for middle-clicking, and you use two-finger scrolling (like a Mac) on the trackpad.
HP EliteBook 8460w/Scientific Linux 6.5
I'd have to get an M4800 in front of me to verify what options are available, but you can definitely disable the pad independently of the buttons.
In other news, there's some conflicting images.
This is apparently a P70 motherboard: http://www.notebookcheck.net/fileadmin/ ... 18a87d.jpg
Note the rather weak cooling solution, and what looks like a soldered GPU.
However, this shows a much beefier cooling solution (under Reliability), and what's very clearly a MXM-B GPU (under Performance): https://www.thinkworkstations.com/thinkpad/
Also, two long M.2 slots are shown on that 3D tour.
fb1996
No, that's the motherboard of the P50 (you can identify it easily because there is only one Thunderbolt 3 port and the ExpressCard slot isn't located between two USB ports).bhtooefr wrote:This is apparently a P70 motherboard
10 (1st Gen), T420s, T440 FrankenPad, X1 Tablet (1st Gen)
Ah, right. Now it makes sense.
That cooling solution still isn't particularly beefy, but at least it makes a lot more sense.
https://forums.lenovo.com/t5/Lenovo-IFA ... -p/2164261
A short hands-on review by me, since I got a chance to briefly try out the P-series on IFA last week.
Saucey
P50 and P70 look great!
Happy to see a 17" ThinkPad happening again.
Thanks a lotIbthink wrote:https://forums.lenovo.com/t5/Lenovo-IFA ... -p/2164261
At least,according to your PRECIOUS review, a 2280 is avaliable
- IBM T60p/1,83 M/RAM:3 Gb/15' SXGA+ IPS Ati Fire GL V5250 256Mo /SSD Intel X25 E 32 GB /XP Pro
- HP 8740w - Core i5 540M 2.53 GHz - 17" LED WVA TFT 1920 x 1200 ( WUXGA ) NVIDIA Quadro FX 2800M 1 GB GDDR3 SDRAM- Samsung 850 Pro 500 GB SSD
My pleasureRochefort wrote:Thanks a lot
More pictures of the P70 inside here: http://www.thinkscopes.com/2015/09/ibc- ... on-review/
As for the P50: http://www.thinkscopes.com/2015/09/ibc- ... on-review/
I've read'n print them, the P70 or an eventual T70 without the GPU but the fast PCIe storage will be my next baby.
Wait for the thermal specs .
I watched the video on Thinkscopes... the power brick was briefly visible but I couldn't get a good look. Does anyone know the size/weight of the 170W adapter that will come with these? Is it the same as the current 170W supply (4X20E50574: 1.8x3.0x6.1", 1.32lbs)? Would be nice if one could use a smaller power adapter, although the i7-6700HQ has a TDP of 45W, M2000M is supposed to be 65W, the panel is probably 10-15W, need some power for charging... I guess 170W is about right.
Are you sure those are power bricks (in the picture)? I thought that was some kind of stackable peripheral system (or maybe a whole stackable PC)... they're sitting in front of a box that appears to show them stacking on top of each other.
fb1996
Yes, that's the ThinkPad Stack.jayk wrote:I thought that was some kind of stackable peripheral system
PandorasThinkpad
Yeah....looks very interesting...
and for me....the biggest advantage...of the P70...ultrabay....and....quite like the P50, too, ethernet port and power port on the backside...this is simply GREAT!
I don't even like any machines with this ports on the right or left side...so i did my decision and chose T410s and T420s..to be my actual machines.
My favorite Thinkpad:
T23 with 1,2 GHz PIII-M, CCFL SXGA+ (LG, 46L2495) (will now get LED Mod),
X200s, SL9400, 8GB Ram, AFFS (HV121WX4-120)
R500 with ATI Graphics, P8400, 8GB Ram and WSXGA+ (LP164W02(TL)(10))[if it once will get WUXGA?!]
T430s with I7, 16GB Ram and FHD Mod
You can find them HERE
Not in four years.
Should be able to pick one up for what you pay for a used W520 today. Or maybe even a T520.
With the island keyboard though, I won't be buying one. Too bad they don't give you an upgrade choice of which keyboard you want.
T510 i5, T510 i7 4349-A64 - T520 i7 4242-4UU, technically a CTO now.
T520: i7-2760QM(2.40GHz),16GB RAM, 500GB SSD/500GB 7200 RPM Drive, 15.6in 1600x900 LCD, 1GB NVIDIA, DVDRW, Smartcard reader, media card reader, FPR, Win7 Pro64, whitelist BIOS, Ultimate-N 6300 AGN, German KB, Bluetooth 4.0.
Puppy
Nice hardware.
Why is it that OEM's cannot curve the front edge of the laptop anymore? My T410 has a nice curve on the front lower edge by the trackpad buttons which allows my wrists to rest comfortably on the machine. Every Dell I have used since the D630 has had square edges and they hurt your (my) wrists after about 20 minutes. It looks like there is "slight" curving on the P50/70 chassis but from the photo's it still looks mostly square to me.
Comparable Precision 15 5510 has 4K available and a smaller footprint and thickness (although thickness measurements given by manufacturers are always questionable). And already available.Puppy wrote:ThinkPad P50s http://www.notebookcheck.net/Lenovo-unv ... 136.0.html
No 4K resolution option
Current Thinkpads:
PandorasThinkpad
Temetka wrote:Nice hardware.
So it is and this won't come back again....perhaps with the "Retro" Thinkpad...when it will ever going to be launched...so do what everyone is going to do....go til T420s/ T420/ X220/ W520 and hope that there will be once again a real usable and trusty, powerful.....real business machine.....manufactured and sold by lenovo...
Puppy
Puppy
Is P70 pricing insane https://forums.lenovo.com/t5/ThinkPad-P ... -p/2225882 ?
Puppy
Yep, the "P70" name is used for two different Lenovo products
Puppy
The pricing is insane. Highest P70 configuration here is for $7500 (converted from local currency to USD)
I find the pricing fair. The quality on these machines is exceptional. They even put the T60p to shame.
Daily: T440s
High-end Quadros are always ridiculous -- unless you really need them.
Quadro M5000M is a $2500 upgrade over the base model; i.e. costs more than the base model itself.
64GB memory is $840 (or for comparison with previous post, 32GB is $360), Xeon CPU is $440, and 4k screen is $510.
Roughly equivalent Precision 7710 is a lot cheaper though; M5000M is only $1200, 4k IGZO is only $170. Xeon upgrade is a bit more than Lenovo though since base model CPU is weaker. Dell's memory upgrades are also a lot less. Really need to see a review comparing equivalent configurations. (HP's ZBook 17 G3 doesn't seem to be available yet.)
Current Thinkpads:
Puppy
Well, another model: P50 - 4K, M2000M, 32 GB RAM, 512 GB SSD, i7 6820HQ = $4000.
I really do wish Lenovo would come out with another dual screen model like the W70*ds. But with such emphasis on thinness in todays electronics market and the availability of 4k displays, I highly doubt it.
WTB Thinkpad p50 p70 SATA cable and caddy for 2nd or 3rd drive
by jedisurfer1 » Sun Feb 12, 2017 11:37 pm » in Marketplace - Forum Members only - 0 Replies
- 259 Views
Last post by jedisurfer1
P70 - need (34mm) ExpressCard reader (board) 'Device description' & 'Hardware ID' in Win 10 Pro 64-bit OS
by Frankenstien » Thu Feb 02, 2017 9:35 pm » in Windows 10 - 0 Replies
- 600 Views
Last post by Frankenstien
My P50 impressions and setup experience
by furball4 » Sat Jan 07, 2017 3:55 am » in ThinkPad W530 and later Series - 8 Replies
- 1119 Views
Last post by Tim-ANC
Fri Jan 27, 2017 11:44 am
WTB: W540 w/ 32GB RAM or a decenty priced P50 w 64GB
by Farro » Wed Jan 25, 2017 10:58 am » in Marketplace - Forum Members only - 0 Replies
- 273 Views
Last post by Farro
