Portable monitors wouldn't work for you? For example, this 1.8-lb 15.6" 1920x1080 USB3.0 monitor: http://www.newegg.com/Product/Product.a ... -_-Productbrchan wrote:I really do wish Lenovo would come out with another dual screen model like the W70*ds.
Looks like a new W7xx (edit: 17" P70, and P50 replacing W541) is coming out? (small pics)
Re: Looks like a new W7xx (edit: 17" P70, and P50 replacing W541) is coming out? (small pics)
Bringing the extra cables, screen, and possibly nylon case for the screen would be too much trouble. The nice thing about the dual screen models was that it didn't require anything extra. Sure, their probably won't be as much screen space, but having the 'wow' factor of being able to quickly pop out the display is a nice engineering marvel.pianowizard wrote: Portable monitors wouldn't work for you? For example, this 1.8-lb 15.6" 1920x1080 USB3.0 monitor: http://www.newegg.com/Product/Product.a ... -_-Product
Puppy
https://forums.lenovo.com/t5/ThinkPad-P ... -p/2238700600X wrote:I find the pricing fair. The quality on these machines is exceptional.
Like I said, the quality is exceptional. The quality control on the other hand may not even exist.
Daily: T440s
Puppy
There is another report by a different user of similar issue (sudden 2100: Detection Error on SSD1)600X wrote:Like I said, the quality is exceptional. The quality control on the other hand may not even exist.
EDIT Lenovo at least confirmed that first customers are actually the QA
Puppy
P70 4K review http://www.notebookcheck.net/Lenovo-Thi ... 308.0.html
- annoying screen bleeding
- PWM below 95 % brightness
Puppy
Wanna be a betatester ?
Thinkpad P50 does not boot https://forums.lenovo.com/t5/ThinkPad-P ... rue#M55526
1. Take out the CMOS battery for some minutes (4-5)
2. Put it back
3. Start the device and update the BIOS to version 1.15
We - a reseller from Germany - found out about this problem and fixed a lot of devices - a LOT!! No fun at all, if you know the background.
2. Put it back
bit_twiddler
Obviously, Lenovo is having a problem in engineering getting all of this new technology to work together:
PCI-SSDs, hi-dpi displays, DDR4, etc.
I think that in general they are headed in the right direction, even if this generation is a little buggy.
Maybe it'll all be sorted out for Kaby Lake. I'm hoping that by then they come to their senses and
dump 16:9 screens for workstations.
bit_twiddler wrote: Maybe it'll all be sorted out for Kaby Lake. I'm hoping that by then they come to their senses and
Hopefully the rest of the skylake line is currently under some sort of testing ...
I'm more inclined to think they released it a bit too early (maybe due to pressure from management or market forces)... or they're really sloppy and their QA isn't as rigorous, missing more than a few bugs.bit_twiddler wrote:Obviously, Lenovo is having a problem in engineering getting all of this new technology to work together:
RIP: 760XD 9546-U9E
RIP: 760XD 9546-U9E
Puppy
Which is the case of Windows 10 as well. Whole PC industry seems to be nervous from decreasing sales that causes they are releasing even more buggy products as "final" one than beforeaxur-delmeria wrote:I'm more inclined to think they released it a bit too early (maybe due to pressure from management or market forces)
Puppy
P50s in PSREF http://psref.lenovo.com/Product/ThinkPad_P50s
There are too many thinkpad models now. The focus should be more on quality, well designed units, than sheer quantity.
Saucey
Yeah, strange that there's the X1 Yoga, regular Yoga, P40 Yoga, and then the 11e variant.brchan wrote:There are too many thinkpad models now. The focus should be more on quality, well designed units, than sheer quantity.
Sucks that they got rid of the W series all together. Oh well.
Puppy
P50 FHD review http://www.notebookcheck.net/Lenovo-Thi ... 713.0.html
Puppy
P70 keyboard/trackpoint issues https://forums.lenovo.com/t5/ThinkPad-P ... -p/2261333
Both of these issues make the machine essentially unusable in any professional software, either CAD or software development.
bit_twiddler
It does seem like Lenovo has lost their mojo of late in their product organization.Both of these issues make the machine essentially unusable in any professional software, either CAD or software development.
Whatever happened to the brilliant team that designed the keyboard on the T400s/T410/T420/W510/W520 ?
They've probably been exiled to the Gobi desert, or whatever the Chinese equivalent of Siberia is.
Already solved, an issue in Windows settings: https://forums.lenovo.com/t5/ThinkPad-P ... -p/2261333Puppy wrote:P70 keyboard/trackpoint issues https://forums.lenovo.com/t5/ThinkPad-P ... -p/2261333
Pros:Puppy wrote:P50 FHD review http://www.notebookcheck.net/Lenovo-Thi ... 713.0.html
* good fan/gooling review
Cons:
* sRGB coverage 58% !
* bad vertical viewing angles
The screen is worse than what you would find on some cheap consumer laptops today.
They've pulled that trick before I believe; forcing you to get the higher resolution screen if you want something with decent quality. On a premium machine like this even the entry-level components should be better than the average consumer laptop.hhhd1 wrote: Cons:
Current Thinkpads:
Puppy
It is time to change the default setting then.Ibthink wrote:Already solved, an issue in Windows settings: https://forums.lenovo.com/t5/ThinkPad-P ... -p/2261333
Actually not, the P70 4K panel has low PWM backlight control below 95% brightness setting that means "always". The E560 IPS panel is even better than the P50 one http://www.notebookcheck.net/Lenovo-Thi ... 741.0.htmljdrou wrote:They've pulled that trick before I believe; forcing you to get the higher resolution screen if you want something with decent quality.
I don't think this is on purpose. Lenovo just does not care about the screen quality as usually, it is just component having pixel resolution and size.
Meanwhile another interesting discussion, new Samsung PCI-e/NVMe SSD risk of overheating https://forums.lenovo.com/t5/ThinkPad-P ... -p/2262307
True.Puppy wrote:I don't think this is on purpose. Lenovo just does not care about the screen quality as usually, it is just component having pixel resolution and size.
Anyone buying either a P50 or an E560 might end up getting a totally random screen, not necessarily one from the early reviews.
Just 'resolution' and 'size' AND being IPS.
But apparently IPS here doesn't guarantee much, like sRGB coverage / PWM / response time / and some times view angles.
Actually, Lenovo pretty much states that the FHD IPS screen won´t cover sRGB in the PSREF:
15.6" (396mm) FHD (1920x1080), anti-glare, LED backlight, IPS, 250 nits,
16:9 aspect ratio, 600:1 contrast ratio, 45% gamut, 160° viewing angle
http://psref.lenovo.com/syspool/Sys/PDF ... ations.pdf
There are 3 different FHD screens used for the P50:
- 00HT919 (Samsung)
- 00HT920 (Boe Hydis)
- 00HT921 (LG Display)
The one Notebookcheck tested was the last one (LG).
- 00HT919 (Samsung)
Puppy
Thanks. The screen lottery is backIbthink wrote: There are 3 different FHD screens used for the P50:
- 00HT919 (Samsung)
Sorry, should have clarified: These are only non-Touch FRUs. Touch FRUs are different:
- 00NY503
- 00NY504
- 00NY503
- 00NY504
Puppy
P50 4K screen backlight "quality" https://forums.lenovo.com/t5/ThinkPad-P ... rue#M56791
All those troubles with a premium top of the line product for 4000 USD (or EUR).
Someone has really some fun with the paying customers.
Lophiomys
Actually, for me, 3K is a good thing for 15.6". I like its 211.8 DPI, which is just low enough that I can avoid scaling. Because of this, I am seriously considering getting a Thinkpad, for the first time in 6 years! Tell me, what's the difference between the P50s, T550, and W550s? They all have an 15.6" 2880x1620 option. Also, is the clickpad still as awful as the one on the T540p?Puppy wrote:P50s Lenovo specs https://www.thinkworkstations.com/products/p50s/
So the 3K only is official
For almost a year, I had a Sony P Series whose 8" 1600x768 screen was 221.9 DPI, and it worked fine without scaling.
P50s, T550, T560 and W550s are all based on the same chassis. T550 and W550s are both Broadwell based, T560 and P50s are the new Skylake replacements for those two models.pianowizard wrote:Tell me, what's the difference between the P50s, T550, and W550s? They all have an 15.6" 2880x1620 option. Also, is the clickpad still as awful as the one on the T540p?
Some of the differences:
- T550/W550s were available with FHD TN, 3K IPS and 3K IPS Touch displays. T560/P50s are available with FHD IPS, FHD IPS Touch and 3K IPS (same 3K displays as in T550/W550s)
- T550/W550s were equipped with VGA/mDP, T560/P50s switch to HDMI/mDP
- GPUs: T550 was available with the GeForce 940M, W550s with the Quadro K620M. T560 will be available with the GeForce 940MX, P50s is available with the Quadro M500M. All W550s/P50s models are equipped with dGPUs
- Some P50s/T560 models will be available with SATA Express PCIe x2 SSDs (T550/W550s = SATA III only)
These are most of the major changes, T560/P50s are small upgrades of T550/W550s.
The ClickPad is definitely different from T540p. The general consensus is that it is much better.
I don't do anything graphics-intensive, so I prefer integrated GPUs. What's the smallest AC adapter that I can safely use for a model with integrated GPU?Ibthink wrote:- GPUs: T550 was available with the GeForce 940M, W550s with the Quadro K620M. T560 will be available with the GeForce 940MX, P50s is available with the Quadro M500M. All W550s/P50s models are equipped with dGPUs
What's the new clickpad's travel distance? The main problem with the T540p's clickpad was that it sank too deep.Ibthink wrote:The ClickPad is definitely different from T540p. The general consensus is that it is much better.
Also, do you know if touchpads with proper buttons will ever return?
WTB Thinkpad p50 p70 SATA cable and caddy for 2nd or 3rd drive
by jedisurfer1 » Sun Feb 12, 2017 11:37 pm » in Marketplace - Forum Members only - 0 Replies
- 256 Views
Last post by jedisurfer1
P70 - need (34mm) ExpressCard reader (board) 'Device description' & 'Hardware ID' in Win 10 Pro 64-bit OS
by Frankenstien » Thu Feb 02, 2017 9:35 pm » in Windows 10 - 0 Replies
- 600 Views
Last post by Frankenstien
My P50 impressions and setup experience
by furball4 » Sat Jan 07, 2017 3:55 am » in ThinkPad W530 and later Series - 8 Replies
- 1118 Views
Last post by Tim-ANC
Fri Jan 27, 2017 11:44 am
WTB: W540 w/ 32GB RAM or a decenty priced P50 w 64GB
by Farro » Wed Jan 25, 2017 10:58 am » in Marketplace - Forum Members only - 0 Replies
- 270 Views
Last post by Farro
