Telemetry (spying) now introduced in W7 and W8.x through WU
Windows 8 on ThinkPads
MikalE
Re: Telemetry (spying) now introduced in W7 and W8.x through WU
#31 Post by MikalE » Thu Nov 10, 2016 12:33 pm
Having illegal downloads or morally questionable data on you system is not the point.
Snooping around in your personal and private computer files and folders is the point.
Thanks for the info too.
T510 i5, T510 i7 4349-A64 - T520 i7 4242-4UU, technically a CTO now.
T520: i7-2760QM(2.40GHz),16GB RAM, 500GB SSD/500GB 7200 RPM Drive, 15.6in 1600x900 LCD, 1GB NVIDIA, DVDRW, Smartcard reader, media card reader, FPR, Win7 Pro64, whitelist BIOS, Ultimate-N 6300 AGN, German KB, Bluetooth 4.0.
kfzhu1229
#32 Post by kfzhu1229 » Thu Nov 10, 2016 2:18 pm
And if you really want it to be confidential disconnect the internet or just use Windows 2000
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
Flexview UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10
micrex22
#33 Post by micrex22 » Mon Nov 14, 2016 9:23 am
kfzhu1229 wrote:And if you really want it to be confidential disconnect the internet or just use Windows 2000
That's not going to be a feasible solution for most people which need: modern application support + internet + an OS that isn't so chatty constantly sending data; and confidentiality is just one of the many problems of Windows 10 :banana:
mh9162013
#34 Post by mh9162013 » Mon Dec 12, 2016 11:29 am
jdhurst wrote:Microsoft is using this method to determine faults and errors and fix them. This never happened with Windows 8 originally and it was the lowest quality system Microsoft ever introduced.
They are using telemetry with Windows 10 and the last two builds (.351 is the latest several days ago) have become very reliable.
I doubt they are spying on you (I am sure they could care less about you and the rest of us) but they are improving quality.
What a load of crap.
#35 Post by dr_st » Mon Dec 12, 2016 11:41 am
Telemetry is used to try to improve the quality of the product. Whether it's successful or not is another story.
Puppy
#36 Post by Puppy » Mon Dec 12, 2016 7:20 pm
Google is spying because they have to, Microsoft don't.
kfzhu1229
#37 Post by kfzhu1229 » Tue Dec 13, 2016 12:26 am
Somehow Telemetry should not be on laptops. I have Windows 10 on my T43 with P M 780 2.26 w/2gb ram and Dell OptiPlex GX520 with P4 650 3.4 w/3gb RAM. Telemetry takes up CPU power but also usually have a low priority so that not as much slowdowns occur (your tasks will still be able to take full CPU usages while that service takes the freed parts and perhaps HT as well in the case of my P4). That is completely fine with my Dell desktop as its stock cooler passes the stress tests with ease before and after my P4 650 upgrade with fresh AS5. However it is NOT acceptable to my T43. Despite the 2.26ghz 780 is the faster one than that P4, the fan is barely good enough to keep the temperature down and lots of heat + noise comes out.
I don't mind if they send information as there isn't really anything on my computer that they would even care, I mind that lots of heat and sound comes out of my laptop.
Flexview UXGA:
#38 Post by dr_st » Tue Dec 13, 2016 7:13 am
How do you know that your high CPU usage has anything to do with telemetry? You just assume?
kfzhu1229
#39 Post by kfzhu1229 » Tue Dec 13, 2016 10:59 am
Windows 10's task manager tells you the description and process name which is not the case for Windows 7 in case you don't know.
Flexview UXGA:
#40 Post by dr_st » Wed Dec 14, 2016 2:28 am
So which telemetry-related process is eating your CPU cycles, and how much of them? Can you post a screeenshot?
TPFanatic
#41 Post by TPFanatic » Wed Dec 14, 2016 12:15 pm
kfzhu1229 wrote:Windows 10's task manager tells you the description and process name which is not the case for Windows 7 in case you don't know.
My Windows 7 task manager does tell me these things, Vista as well. You are probably thinking about Windows XP's task manager.
My concern with 10 can be found in a 37 page thread on Microsoft Forums with no real solution:
https://answers.microsoft.com/en-us/win ... e2?page=37
It's like some hidden process is taking my disk resources. And by hidden, I mean the numbers make no sense in Task Manager. It makes me want to ditch 10 when it takes 3 minutes to have a responsive desktop. Meanwhile the Start Menu is never responsive.
Home theater: lenovo T420
kfzhu1229
#42 Post by kfzhu1229 » Wed Dec 14, 2016 3:34 pm
As for it takes 3 minutes for desktop to load, I have NEVER encountered that on the newest version of W10 in my T43 even with fast boot disabled (of course with ATI utility event disabled as that process will start up by default and freeze) Try factory reset your copy.
Flexview UXGA:
TPFanatic
#43 Post by TPFanatic » Wed Dec 14, 2016 3:37 pm
That's a good idea, I suspect there may be some leftover win7 aspects or conflicts with Lenovo drivers slowing down my installs. I will try that on a machine soon. Thanks.
kfzhu1229
#44 Post by kfzhu1229 » Wed Dec 14, 2016 6:26 pm
oh if you actually went from Windows 7 to Windows 10 factory reset does bring some advantages. Anyhow it is completely abnormal for a machine to take 3 minutes to start Windows 10 unless you are in the very other situation where your hard drive is about to fail or something.
However, some Windows 7 stuff like Windows Image Preview may disappear and you have to do some homework to bring it back.
Go to Settings --> Update & Security --> Recovery --> Reset This PC to do so. You needn't worry about your license as it will return as soon as you connect to the internet once again. If your Windows 10 copy is activated the SN of your motherboard will be recorded on Microsoft's database therefore no matter how many times you reinstall Windows 10 its license will stay permenantly until you click change license
Flexview UXGA:
Return to “Windows 8”
