Clean Windows 7 install on Thinkpad T420 with recovery disks
Windows 7 on ThinkPads
cadillacmike68
Re: Clean Windows 7 install on Thinkpad T420 with recovery disks
#31 Post by cadillacmike68 » Fri Jul 15, 2016 8:16 pm
Tentpole wrote:All sorted. The new SSD took a while to arrive but installation on my X230 and activation was clean and easy:
1. Downloaded Win7 iso file, plus "Windows7-USB-DVD-Download-Tool-Installer-en-US.exe" from Microsoft
2. Copied ISO to blank USB drive with the MS tool to create a bootable drive (could have made a disk but why bother and the X230 would need an external optical drive) & insert into X230
3. Start up X230 - the boot process allows you to interrupt booting and select a different boot drive, no need to change BIOS settings
4. Install Windows (nice and fast with SSD), type in COA from under battery and be told that I have 3 days to activate
5. Find and install Ethernet driver, go through a few Windows Update cycles, download drivers package from Lenovo - could have manually installed drivers at this point but instead:
6. Download, install and run Lenovo System Update and let it update all drivers etc
7. Activate Windows: Computer-Properties-Windows activation, dialled the automated phone service, told it I have a volume license agreement, gave it my mobile number and received a link by SMS, went through activation codes as instructed and success :)
No need for recovery disks or original Lenovo Win7 CD - it all worked with a vanilla iso and the OEM COA under the battery. Thanks for the tips RBS and other guys.
Who's automated phone service, Microsoft's or Lenovo's? I have 4 T61s and the factory W7 recovery disks.
I finally got my test machine to weork properly without giving me 2 or 3 BSDs every day.
Code invalid, etc.
Then, I backed up the test / gunea pig machine and restored it to the other three T61s HDDs, but windoze says not activated. This is probably because I backed it up from one T61 and restored it to another T61. They all have the Lenovo volume license.
760LD 9547 FUBARd
T500 2
#32 Post by RealBlackStuff » Sat Jul 16, 2016 12:53 am
With Middleton's BIOS the T61 shouldn't have any problems with a recovery process.
http://ali.dj/blog/sata-ii-support-for- ... 61-x61-r61
Tentpole
#33 Post by Tentpole » Sun Jul 17, 2016 6:01 pm
cadillacmike68
"Who's automated phone service, Microsoft's or Lenovo's? "
Microsoft - I did not know Lenovo provided a license activation service. This was 3 months ago and I cannot remember all details but finding the MS number to call should not be difficult.
Yes as I said after the clean installation (no backing up or copying from other machines required) I was "told that I have 3 days to activate". You did the backup & restore route, which you may be able to get to work but that was not what I did, which was a single clean installation with a Win7 Pro 64 volume licence COA. By all means keep trying but I found the clean install using the ISO which I think was linked to by a previous poster, worked nicely. So long as you have the unique Win7 licence IDs for each machine that should be OK. I strongly doubt that re-using the one licence will work. You say you have 3 T61s, these were discontinued before Win7 came out, so your volume licences are for XP, I presume.
Good luck getting it sorted.
#34 Post by RealBlackStuff » Mon Jul 18, 2016 5:39 am
As long as all those [T61] machines have a BIOS with Slic2.1 (Middleton's BIOS in this case), one recovery set will do for any number of them.
I have installed T420 W7-recovery on anything between T43 and X1, all those machines had Slic2.1.
Tentpole
#35 Post by Tentpole » Mon Jul 18, 2016 7:28 am
OK thanks RBS, that's news to me. I have an aged X61 with XP and might give that a go as it's gathering dust.
cadillacmike68
#36 Post by cadillacmike68 » Thu Jul 28, 2016 4:46 pm
Yeah, I had BIOS issues. Middleton was on them but the embedded controller was out of whack. I had to put lenovo's latest and Then Middleton on over that. Seems to be ok now.
Good thing too because ms and lenovo were of NO help.
760LD 9547 FUBARd
T500 2
Return to “Windows 7”
