Question about routers...
Re: Question about routers...
No idea. Everything I know about CAT5 cabling is how to crimp on a new RJ45 connector, don't run it over 300 feet (well, okay, 100m if you want to get technical) and not to use it with GigE equipment. I suppose it shouldn't hurt as it's non-conductive and could prevent moisture from penetrating the connections. The downside to it is if/when you DO discover that something is wrong with the connection at the coupler, you might end up having to cut both RJ45 connectors off and crimp on new ones.
If you're running the LAN cable outside, either make a conduit for it or get a cable that's designed for outdoor use.
RIP: 760XD 9546-U9E
RIP: 760XD 9546-U9E
It's not going but maybe 30 to 40 feet.
When they built their office, they already have cable run from that outside area into the wall and inside where their computers are the cable leads to a ethernet wall outlet.
So, that cable cannot be changed.
I figured I'd just splice it for now to this cable that runs inside and if it becomes a problem later, I'll get a new cable and run it thru a hole in the wall to the inside area and tack it along the baseboard to their computer area.
He wants something quick, easy, and right now... so that's what I'll do for now and if it becomes a problem later I'll go with running a new cable and in that event I'll use one that is rated for outdoor use.
Stargate199
You probably have already installed a new router already, but i'm throwing in my 2 cents anyway for anyone else looking to do the same thing. In my office I have installed a couple of Ubiquiti UniFi access points. Depending on the configuration on the network, they may be a good solution. I have mine configured with two separate ssids linked to separate vlans. I like these in my office because they are pretty cheap for enterprise grade access points and they work very well.
Now if you are looking for router, I would go with the recommended Netgear AC router. Most of the high end routers are going to have guest modes. I had an older Netgear N router that had that. It worked okay, but nothing I have used has surpassed the reliability and performance of my trusty 10 year old Linksys WRT54g.
770X Aftermarket Battery? (*And quick PIII linux question)
by Choram » Wed Jan 04, 2017 6:52 am » in ThinkPad Legacy Hardware - 1 Replies
- 928 Views
Last post by Dekks
Thu Jan 05, 2017 12:43 am
Question about an X301
by mazzinia » Tue Jan 10, 2017 9:19 am » in ThinkPad X200/201/220 and X300/301 Series - 28 Replies
- 2923 Views
Last post by Temetka
Sun Mar 05, 2017 9:38 pm
X60 tablet activation or Linux question
by Billaboard » Thu Jan 12, 2017 8:00 pm » in Thinkpad X6x Series incl. X6x Tablet - 12 Replies
- 1860 Views
Last post by Billaboard
Fri Jan 20, 2017 6:18 pm
X201 hard drive cover screw question
by TPFanatic » Fri Jan 20, 2017 11:37 am » in ThinkPad X200/201/220 and X300/301 Series - 2 Replies
- 876 Views
Last post by TPFanatic
Thu Jan 26, 2017 5:54 pm
