My t42p 15" is not stable at 600Mhz@0.700V : it often fails to come back from suspend2ram mode -- even if it was rock solid with NHC tests and prime95.LRoy wrote:My T42p (Dothian 1800) and R50p (Banias? 1700 I think) are both working with no issues set to 600Mhz @ 0.700v Not extensively tested but both have 30-45 minutes of prime95 and the NHC full test under their belt.
Managing Pentium-M Speed/Voltage with software (temp sticky)
x300 - 8GB RAM - w7pro64
I've noticed that my T43 would occasionally just randomly reboot when running on battery @ 0.700v. I've since increased the voltage to 0.716v and the problem went away. FWIW, I've run my T43 basically 24/7/365 on AC power @ 2.0ghz (1.084v) since July '05 and it's only off maybe a couple hours a week when being transported.
The efficiency of electrical components does decrease ever so slightly over time (capacitors especially) and this may have just been enough to cause the voltage to prematurely drop below 0.700v for the cpu.
christopher_wolf
- Special Member
What is un-ecological about it? It makes little difference in the end; plus, you have to worry about getting of a very old battery to begin with anyway. Whilst charging, you draw enough to power the Thinkpad and charge the battery; you doun't get something for nothing by charging up the battery and then using it later instead of AC.Zed wrote:JHaislet - isn't that a bit unecologicalI've run my T43 basically 24/7/365 on AC power @ 2.0ghz (1.084v) since July '05![]()
Regards Zed
~o/
She does the things you do.
But she is an IBM.
~o/
But she is an IBM.
That might be your take on the situation. However, my puny little T43 did replace a DUAL Athlon MPX machine, with 2GB of ram, 3 15,000rpm SCSI drives, 4-7200rpm SATA drives (now in external enclosures I can turn on as needed) high end Radon graphics, plus a bunch of other crap that I needed running 24/7. That machine easily pulled 600w.Zed wrote:JHaislet - isn't that a bit unecologicalI've run my T43 basically 24/7/365 on AC power @ 2.0ghz (1.084v) since July '05![]()
Regards Zed
With the display turned off & PowerPlay enabled, my T43 pulls maybe 45w (probably less).
Unecological? You be the judge
noob back in action with two dumb questions
Alright guys... does this program have to boot at startup to keep these settings in effect?? If so is there anyway for it to boot, load the settings and then shut off to preserve memory and battery life?
Also, Im checking out my free RAM and I only have about 120 megs when Im just sitting here idling, which is like 21% free, this seems rather low... what are others set at, and is there anything I can do to free up more???
FWIW, my install is rather clean, and I try and keep the registry pretty clean and only booting the essentials through msconfig
Re: noob back in action with two dumb questions
Yes. This program has to run in the background. It actively monitors system load and applies the proper setting accordingly.
Don't get too worried about your ram. windows xp is aggresive on using the ram to speed up the system response.
rcrooks wrote:Alright guys... does this program have to boot at startup to keep these settings in effect?? If so is there anyway for it to boot, load the settings and then shut off to preserve memory and battery life?
techflavor
Strange problem.
My computer has been working perfectly since my last fresh install of Windows. Earlier today, I had to restart my computer 2 times because of misc things but everything started up just fine.
After I installed Prime95 and NHC, I followed this threads directions on the process of setting the multiplier/voltage then stress testing with Prime95. Everything was fine until the 2nd test. My system ended up crashing so I let it rest for a second then powered it back on.
Whenever it came back on, I noticed all sorts of problems: wireless not working, bluetooth acting wierd, my virus scanner was disabled, client security services wasn't initializing (couldn't swipe finger to login, only put in password), and many other things.
When looking through my services, I noticed that somehow at least 15 (if not more) services had been disabled (TrendMicro, ThinkPad PM service, TSS Core Services, TVT, Protector Suite Virtual Token, IBM KCU/PSA, etc). I know for a fact all of these services were running just fine before the Prime95/NHC installation.
Luckily a system restore from yesterday got me working just fine but anyone know what may have caused this? I've seen Windows crash a million times but not cause these problems.
Re: Strange problem.
It's probably not about number of crashes. It's about when it crashes.
techflavor wrote:My computer has been working perfectly since my last fresh install of Windows. Earlier today, I had to restart my computer 2 times because of misc things but everything started up just fine.
2378-FVU, 1.7G Dothan, 768M, 40GB,Radeon 9600 64M, 14.1" SXGA+ .
DIGITALgimpus
gunston
it seems like when you are using CHC 1.10 beta version, you are unable to choose the Scheme option under Power Manager,
each time you reboot your thinkpad, the Scheme option will remain blank/not choosing anything although you have choosen one of the Power Scheme option before rebooting.
2. X60s 1703-CA3 powerful
That is the same issue i faced. In the end, i let power manager take control.gunston wrote:it seems like when you are using CHC 1.10 beta version, you are unable to choose the Scheme option under Power Manager,
gunston
no undervoltage?huntzer wrote:That is the same issue i faced. In the end, i let power manager take control.gunston wrote:it seems like when you are using CHC 1.10 beta version, you are unable to choose the Scheme option under Power Manager,
Well I'm currently testing my T41 with it's new Dothan 755 upgrade from the 1.6ghz Banias.
2.0ghz now runs at 1.164v 12h prime stable.
600mhz now runs @ 0.700v 10h prime stable.
Looking good. Full load at 2Ghz hits about 55C (when I replaced the CPU I used AS5) and 600mhz loads at 38C.
Hopefully this should extend my battery life by a fair bit. Almost 3W are saved at 600mhz at that voltage and 2W saved at 2.0Ghz. Very nice. I tried 1.120v at 2ghz but it failed prime after 11minutes so I went up 2 notches to act as a buffer.
Next stop, the ATi Mobility Radeon 7500 32MB
IBM Thinkpad T41: 2373 8RG 14.1" XGA - PLUS Intel Pentium-M 755 Dothan 2.0GHz/ 2MB L2/400FSB, 512MB RAM, IBM Thinkpad 802.11a/b/g/ mini-PCI II.
thibouille27
thibouille27
thibouille27
ouch, a couple characters didn't get into my original post, sorry for that it should have been:
Using NHC, it seems I cannot go lower than 0.9xxx volts on my X60.
I often see people talking about 0.7Volts... For me 0.9 is the minimum
BTW, is 1GHz the minimum frequency for a T2400? no way I could go lower ?
wiresounds
Yes, it would use more powersimms wrote: Now my question is, can I always run mine at a minimum 9x? Everything from 7x-9x uses 0.700 so would it use more power at 9x even though the voltage is the same?
T41 23733JG,14.1''xga,ATI9000,CDR/DVD,BT,GigaLAN
upgraded:Dothan 2.1 undervolted,2GBram,120GB@5400 Seagate Momentus,Intel 2915,Ultrabay battery,DockII, BT GPS
PCMCIA cards:firewire,AverMedia AVerTV Hybrid (DVD-T&Analogue TV-FM radio-Svideo in)
600mhz how?
how did you get yours to 600? I can't see less than ~780mhz (6x 0.796)
Thanks!!
Thanks!!
smids wrote:Well I'm currently testing my T41 with it's new Dothan 755 upgrade from the 1.6ghz Banias.
rscosworth
does anyone have the best settings i can use for NHC?
Im looking for basically three profiles
1. on AC - full performance, full steam ahead
2. on batter - some performance, but enough to be able to keep me working for at least 2 hours
3. on battery - please god dont let this laptop die, im in the middle of somthing
i have a t42 with 1.8dothan and 1gb ram.
cheers
cheers
DIGITALgimpus
It changed it's name:
http://www.pbus-167.com/nhc/nhc.htm
agarza
I've been having this doubt for quite some time:
People who have applied Arctic Silver 5 on the CPU & GPU that report to reduce some degrees off the cores:
Did you use the NHC before and after the AS5 application?
Because I'm still using my Dothan 1.8GHz at full speed, without any utility (like NHC or TP Fan Control) and after applying AS5 I see the same temperatures on both CPU & GPU than before.
My question is:
Fiddling with the correct values on NHC to reduce the voltage on my processor, could it run below the 40C degrees?
Also, NHC allows you to lower the GPU processing power?? (I have POWERPLAY disabled in the Windows ATi Control Panel, but in NHC its grayed out the option to use PowerPlay in NHC)
My question is:
Current
T440p: Core i7-4710MQ|8GB RAM|Intel SSD S3700 200GB | 14.1" IPS FHD | Windows 7 Pro, T450 Trackpad, Backlit keyboard, 2nd Caddy
Low voltage v Normal RAM (Mixing?)
by blink » Thu Dec 29, 2016 8:17 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 3 Replies
- 1614 Views
Last post by Kasm279
Fri Dec 30, 2016 11:39 am
- 11 Replies
- 2148 Views
Mon Jan 09, 2017 2:20 am
- 2 Replies
- 774 Views
Last post by Kaviar
Sat Apr 01, 2017 6:10 pm
IBM Thinkpad T42 windows 98 temp measuring and heatsink upgrade
by wasilii » Mon Apr 10, 2017 10:36 am » in ThinkPad T4x Series - 3 Replies
- 779 Views
Last post by shawross
Tue Apr 11, 2017 5:33 am
