nitrocaster
#211
Post
by nitrocaster » Sun Nov 20, 2016 3:10 am
jp776 wrote:
Is it right, that I can bridge the both aux power pads to have more space to solder the wire?
And any hints how to cut out the space on the lid? I have a Dremel. Or would a sharp heavy knife do the same job?
Yes, you can. See
updated manual.
Regarding the cutouts, see
this album.
jacobtc
#212
Post
by jacobtc » Sun Nov 20, 2016 4:58 am
I'm so ready, I have my X230 sitting on standby!
StefanKo
#213
Post
by StefanKo » Sun Nov 20, 2016 5:18 am
I think I have asked this before:
What does this sense wire do?
using an X220 (i3->i5->i7, hopefully soon FHD IPS), an X41 (SSD via (m)sata-Mod, IPS, ~100Wh custom battery);
playing with an T430u(buntu), storing a T22, X41t, T42, R61, T61p;
and taking care of the T420s (FHD IPS) of my wife
prime07
#214
Post
by prime07 » Sun Nov 20, 2016 6:39 am
That thing with the resistor on i7 motherboards scares me a little bit
Is it really safe to remove it? Do i have to solder it out, or just rip it of?
jp776
#215
Post
by jp776 » Sun Nov 20, 2016 8:25 am
this album.
Ty - this looks now really great.
I can't see any cutouts at the LCD Front Bezel - does it means this is not necessary?
dogeitrade
#216
Post
by dogeitrade » Sun Nov 20, 2016 7:20 pm
this album.
The active area of the display should be the same size as the stock one, only the increase from 1366x768 to 1920x1080 in
resolution. So, i don't think you need to cut the screen bezel, if you get the recommanded panel for this mod.
jabavox
#217
Post
by jabavox » Sun Nov 20, 2016 11:51 pm
@nitrocaster really great job! am looking for your progresssive.
How did you cut out top cover like that, I mean what's equipment?
carcuevas
#218
Post
by carcuevas » Wed Nov 23, 2016 12:03 pm
And today I got my screen
looking forward
Running Debian on x230 (i5-3320m-12GB-250GB Samsung 850EVO-FHD mod by Nitrocaster + LP125WF2SPB4)
nitrocaster
#219
Post
by nitrocaster » Wed Nov 23, 2016 6:00 pm
StefanKo wrote:I think I have asked this before:
It detects video signal presence.
jabavox wrote:How did you cut out top cover like that, I mean what's equipment?
I used some sort of scriber to cut incisions and then applied brute force to break the pieces off. File works good for precise adjustment and sharp edge smoothing. One of early buyers used a dremel with a diamond cutter - that should do the job just fine.
StefanKo wrote:That thing with the resistor on i7 motherboards scares me a little bit
You can remove it with a solder blob, or you can use a very sharp and thin blade to shave if off the board.
peregrinus
#220
Post
by peregrinus » Thu Nov 24, 2016 2:39 am
any rough plan when the kits will be ready?
nitrocaster
#221
Post
by nitrocaster » Thu Nov 24, 2016 6:04 am
peregrinus wrote:any rough plan when the kits will be ready?
Customs clearance will take about 10-15 days.
Post
by RealBlackStuff » Thu Nov 24, 2016 7:58 am
My LCD from China arrived, took only 11 days!
In your instruction manual it says:
3. Apply insulation tape to the back side of the adapter board. Make sure to make holes for docking
connector pins and the nearby components.
4. Install and solder the adapter board to the motherboard.
Can you perhaps mark which docking pins on Figure 3?
Are there only those
7 brass holes to be soldered, as seen on Figure 7 and the
7 soldered points above
X230_U on Figure 10?
What are the dimensions of your PCB?
prime07
#223
Post
by prime07 » Thu Nov 24, 2016 8:26 am
Thank you, i removed it with a blade, it seems that everything is still working without problems.
But i'm curious, what is this resistor exactly for? Why is it just on i7 motherboards?
nitrocaster
#224
Post
by nitrocaster » Thu Nov 24, 2016 9:04 am
It's connects -USB_30_LED signal from dock to ground. Apparently some dock stations have LED that lights up when USB3 is supported. X220 with i3 and i5 CPUs don't have this resistor so that LED would not light up.
nitrocaster
#225
Post
by nitrocaster » Thu Nov 24, 2016 9:26 am
You'll have to punch each hole that has mating docking connector pin.
Are there only those 7 brass holes to be soldered, as seen on Figure 7 and the 7 soldered points above X230_U on Figure 10?
Above X230_U there's only 7 plated-through holes to be soldered.
PCB dimensions are 16.4x43.1 mm.
Post
by RealBlackStuff » Thu Nov 24, 2016 3:04 pm
Thanks, that's exactly what I wanted to know.
You may want to put that info in your PDF.
Tasurinchi
#227
Post
by Tasurinchi » Fri Nov 25, 2016 5:13 am
nitrocaster wrote:...
RealBlackStuff wrote:You may want to put that info in your PDF.
+1
And maybe some "tips and hints" for soldering newbies like me...
Edit: meaning tips for this specific mod...
Tasurinchi on Fri Nov 25, 2016 6:03 am, edited 1 time in total.
carcuevas
#228
Post
by carcuevas » Fri Nov 25, 2016 5:52 am
Tasurinchi wrote:nitrocaster wrote:...
+1
In internet there are many videos explaining how to do the soldering stuff but you can start with the OLD basics
https://www.youtube.com/watch?v=f9RiXMf3z7A
Tasurinchi
#229
Post
by Tasurinchi » Fri Nov 25, 2016 6:02 am
I don't mean generic stuff/videos, I agree there are plenty of them in youtube & co.
I mean more practical do's & don'ts regarding this specific mod, RBS question was a good example. In the PDF file, step 4, it just says "Install and solder the adapter board to the motherboard", while that maybe self explanatory for an experienced person, it wasn't clear to me exactly what to solder.
carcuevas
#230
Post
by carcuevas » Fri Nov 25, 2016 7:14 am
Tasurinchi wrote:I don't mean generic stuff/videos, I agree there are plenty of them in youtube & co.
I missunderstood you then, but Nitrocaster actually mentioned before :
Post
by RealBlackStuff » Fri Nov 25, 2016 7:56 am
For this mod we should
ignore the blatant mistake that the European Union made in 2003, when they introduced lead-free
RoHS.
http://www.hardwaresecrets.com/rohs-explained/
On this forum we all know too well the disasters that were caused, such as the
GPU and
Southbridge chips that became unstuck on
T4x motherboards.
And what about the
inductors of the
T23 that kept falling off?
(NO) Thanks RoHS...
For best results, I recommend to use old-style
rosin core 60/40 solder (60% tin / 40% lead) with a diameter of ca. .032"/0.8mm, together with a 30-40W soldering iron with fine tip.
Or get a Stahl SSVT soldering station, such as what I use:
Combine that with a solder tip cleaner like this:
and you're good to go.
Carthik
#232
Post
by Carthik » Sat Nov 26, 2016 3:07 am
Where do I send my money?
My X220 has been waiting years for this. I guess now thanks to your keyboard firmware I can now also dust off the X230.
It's going to be a good Christmas
Off to ebay to order my screen now.
Can't thank you enough for your contributions to the community!
ThinkPad X220
i7-2640M CPU
16GB Corsair Vengeance RAM
1TB Samsung 850 EVO mSATA SSD
2TB Samsung Sinpoint HDD
Option GTM671W WiFi/WWAN Card
LP125WH2-SLB3 LG IPS LCD
7.69Ah 9-Cell X230 44++ Battery
Windows 7 Ultimate 64 Bit
Leosleo
#233
Post
by Leosleo » Sat Nov 26, 2016 9:25 am
So, my Thinkpad is on his way to arrive and now I have to order my FHD screen.
I'll go for SPB4, mostly for bigger number of colors than SPB3.
Anyone in this thread that bought the screen from seller indicated from Nitrocaster (name is win0win)?
I would go to make an offer to the seller. Anyone that has made an offer and bought the screen in order to suggest me how much offer to the seller?
Thanks in advance.
P.S. Nitro, we are waiting to you all! Thanks always for your work!
Post
by RealBlackStuff » Sat Nov 26, 2016 9:51 am
I got my -SPB4 from winowin, who accepted my offer.
It would be unfair to seller to disclose my accepted price!
Try negotiating yourself, you have 3 chances.
prime07
#235
Post
by prime07 » Sat Nov 26, 2016 9:55 am
Nitrocaster should get comission from win0win. Because of this mod-kit, he will sell a whole bunch of these screens
theterminator93
#236
Post
by theterminator93 » Sat Nov 26, 2016 10:20 am
RealBlackStuff wrote:I got my -SPB4 from winowin, who accepted my offer.
Same here, though I got -SPB3 due to not specifying any real preference. I never go insultingly low on offers - I send in offers I myself would accept on similar products, and it works out to the advantage of both me and the seller.
seasonshu
#237
Post
by seasonshu » Sat Nov 26, 2016 11:03 am
I wanted to support a UK seller (as I live here too) and having the remote option of returning the screens. I was however, literally blocked of ANY kind of request (screen type, not price, mind you):
"I am sorry we do not participate in conversations like this, it is best you find an alternate supplier as I cannot promise any particular part number."
Oh really? Okay.
So, actually I was happy to pay the asking price of win0win who were kind enough to secure me two SPB4s.. the LCDs are en route! I did some reasonable haggling on the X230 but as mentioned, only offered what I would have accepted as seller.
Leosleo
#238
Post
by Leosleo » Sun Nov 27, 2016 8:45 am
Guys, thanks for the answers!
Obviously I wouldnt speculate on the seller's goodness. However I'm on budget and if i can save some money, it would be good. This is all.
I made an offer for SPB4 and I'm waiting for seller's answer. Finger crossed.
Nitro, do you think that within Christmas we will have our desired NitroPCB
nitrocaster
#239
Post
by nitrocaster » Sun Nov 27, 2016 8:51 am
Leosleo wrote:Nitro, do you think that within Christmas we will have our desired NitroPCB
I'm trying my best!
jacobtc
#240
Post
by jacobtc » Sun Nov 27, 2016 10:09 am
Guys, I suspect this is a waiting game, as customs has to be cleared, no need to ping Nitro too much
..but... I'm waiiiiting!
- 22 Replies
- 3372 Views
Last post by jaspen-meyer
Fri Apr 14, 2017 9:34 am
T420s/430s FHD/2k upgrade
A while back rmsmajestic was selling a few FHD upgrade boards for the t420/t430/t420s/t430s. JJ is still working on a revision to fix the flickering...
- 18 Replies
- 1972 Views
Last post by llemon
Wed May 24, 2017 6:05 pm
- 4 Replies
- 686 Views
Last post by nizmoz
Fri Jan 13, 2017 6:17 pm
- 2 Replies
- 522 Views
Last post by Johan
Thu Feb 09, 2017 11:02 am
