X220 FHD Upgrade?
systema
Re: X220 FHD Upgrade?
#301 Post by systema » Wed Dec 21, 2016 8:32 am
RealBlackStuff wrote:My LCD from China arrived, took only 11 days!
In your instruction manual it says:
3. Apply insulation tape to the back side of the adapter board. Make sure to make holes for docking
connector pins and the nearby components.
4. Install and solder the adapter board to the motherboard.
Can you perhaps mark which docking pins on Figure 3?
Are there only those 7 brass holes to be soldered, as seen on Figure 7 and the 7 soldered points above X230_U on Figure 10?
What are the dimensions of your PCB?
When it says "make holes" is it to poke holes through the black protective film? I have little experience with soldering..the 7 brass hole connections- do I need to remove the solder on each connector before re-soldering them on again?
X41T [Pentium M 758 1.5 GHz] + OCZ 2GB RAM + Lenovo 60GB SSD + 8-cell BAT @ WIN7
X230 FHD [i7-3520M 2.9 GHz] + 16GB RAM + Crucial 750GB SSD + 9-cell BAT @ WIN8.1
nitrocaster
#302 Post by nitrocaster » Wed Dec 21, 2016 8:45 am
systema wrote:When it says "make holes" is it to poke holes through the black protective film?
No, you poke holes through the polyamide tape that you stick on the adapter board.
systema wrote:the 7 brass hole connections- do I need to remove the solder on each connector before re-soldering them on again?
No. Just place the adapter board over it and solder 7 plated though holes.
I'd love to make a video on how to do that, but that would require unmodded motherboard and some assistance with the camera. I'll be installing this mod for some local buyers. We'll see.
prime07
#303 Post by prime07 » Wed Dec 21, 2016 9:16 am
nitrocaster wrote: I'd love to make a video on how to do that, but that would require unmodded motherboard and some assistance with the camera. I'll be installing this mod for some local buyers. We'll see.
That would be awesome. I'd love to install the kit by myself, but i'm a bit scared on how small the pads on the mainboard are :D A video would help a lot.
systema
#304 Post by systema » Wed Dec 21, 2016 9:49 am
Video would be fantastic, too bad you are not in NYC, I would be able to help with the camera.
Thank you for that information. Is this the photo for the 7 pins (better for me to confirm)? So I will apply Kapton to the back, poke 7 holes, solder the 7 connections + sense wire + auxilary wire and that will be all the soldering necessary?
nitrocaster
#305 Post by nitrocaster » Wed Dec 21, 2016 10:55 am
systema wrote:Video would be fantastic, too bad you are not in NYC, I would be able to help with the camera.
Well, if you pay my flight, we could do that :D On a serious note, I guess I'm gonna grab my friend for assistance.
systema wrote:Is this the photo for the 7 pins (better for me to confirm)? So I will apply Kapton to the back, poke 7 holes, solder the 7 connections + sense wire + auxilary wire and that will be all the soldering necessary?
Almost correct. You poke every single hole in the adapter board. Otherwise you won't be able to install it.
systema
#306 Post by systema » Wed Dec 21, 2016 11:02 am
Haha well, I can offer to buy you a drink next time you're here! :)
#307 Post by RealBlackStuff » Wed Dec 21, 2016 12:10 pm
The above picture is from the X220.
For the X230 that soldering point is on the left of the LCD-connector you see at the top on that picture (see also Instructions-PDF, Figure 6 (right hand picture).
systema
#308 Post by systema » Wed Dec 21, 2016 3:27 pm
RealBlackStuff wrote:The above picture is from the X220.
That part I understood; it was the 'obvious' part I wasn't clear on - the 7 brass connections that the adapter board is connected to, as I now understand are on the same place on both the x220/x230 :)
The removal of the resistor (for the USB3 LED) on the i7 x220 series - this doesn't apply to x230 i7 series correct?
nitrocaster
#309 Post by nitrocaster » Wed Dec 21, 2016 3:52 pm
systema wrote:The removal of the resistor (for the USB3 LED) on the i7 x220 series - this doesn't apply to x230 i7 series correct?
The manual literally says that it applies to i7 X220 only, so yes.
systema
#310 Post by systema » Wed Dec 21, 2016 9:38 pm
Roger that, just ordered the LP125WF2 SPB4 from win0win!
Another Q for the pedantic; is the generic intel HD4000 driver working OK for this panel? Or is the Ivydrive one recommended?
nitrocaster
#311 Post by nitrocaster » Thu Dec 22, 2016 5:24 am
systema wrote:is the generic intel HD4000 driver working OK for this panel? Or is the Ivydrive one recommended?
Generic driver works fine.
cpt.ramius
#312 Post by cpt.ramius » Fri Dec 23, 2016 9:10 am
Any chance this would work in a T420/T430?
Cheers and biog thanks for your work and dedication!
seasonshu
#313 Post by seasonshu » Fri Dec 23, 2016 9:18 am
cpt.ramius wrote:Any chance this would work in a T420/T430?
No (Not yet), but see: https://www.reddit.com/r/thinkpad/comme ... available/
acooc
#314 Post by acooc » Sun Dec 25, 2016 2:04 am
nitrocaster wrote:
acooc wrote:Will this mod work with the sharp 12.5" WDHQ 2560 x 1440 IPS monitor?
https://world.taobao.com/item/436005468 ... mSite=main
WQHD is not supported.
nitrocaster, do you have plans to support higher resolution?
I'm taking interest in the dell xps 13's impressive display.
ThinkPad X220
i7-2640M CPU
nitrocaster
#315 Post by nitrocaster » Sun Dec 25, 2016 4:34 am
acooc wrote:nitrocaster, do you have plans to support higher resolution? I'm taking interest in the dell xps 13's impressive display.
I do, but I'd recommend you to abstain from 13" thing. There's no way one can properly mount 13" panel into X220/X230 lid.
x3o2
#316 Post by x3o2 » Mon Dec 26, 2016 5:57 am
nitrocaster wrote:There's no way one can properly mount 13" panel into X220/X230 lid.
Isn't the 13'' panel in the X330 from the XPS 13?
nitrocaster
#317 Post by nitrocaster » Mon Dec 26, 2016 6:06 am
x3o2 wrote:Isn't the 13'' panel in the X330 from the XPS 13?
It is: https://imgur.com/a/mdexA
nitrocaster
#318 Post by nitrocaster » Mon Dec 26, 2016 6:13 am
boutch55555 wrote:So, nitro, what would be your thoughts on open sourcing your designs ?
This project has been done more than 6 times in the past, but was never widely distributed. Publishing the designs could allow people to mod it for 40 pins connectors (yes, the HD3000 supports my 3440x1440 monitor @60hz), write custom drivers / bios mod for backlight for windows...
I'd give good money for that to happen.
Releasing the project would take a significant effort (collect and put in order component libraries, cleanup the sources, write lots of readmes and so on) that I don't feel like I want to do just to make it public. Given the feedback I got I'm gonna make WQHD version anyway (and probably tablet one too). As for custom drivers/BIOS mods - you can do that right now, the FHD mod does not interfere with it.
x3o2
#319 Post by x3o2 » Mon Dec 26, 2016 8:37 am
So I don't get your hint: 'There's no way one can properly mount 13" panel into X220/X230 lid.'
It is possible. But it means a lot of work and adjustments to be done, right?
#320 Post by RealBlackStuff » Mon Dec 26, 2016 8:50 am
@x3o2:
Which part of properly do you not understand?
x3o2
#321 Post by x3o2 » Mon Dec 26, 2016 9:43 am
RealBlackStuff wrote:@x3o2:
The first syllable caused some confusion...
Thanks, now I got it.
seasonshu
#322 Post by seasonshu » Fri Dec 30, 2016 8:48 am
Ok, this only becomes interesting when nitrocaster creates a 4-lane eDP version of the board (for resolution > FHD).
I have been trying to check the LCDs that would be suitable. I am looking get a panel which has a ratio of 16:10 or 3:2... so 2560x1440 (16:9) is not really a favourable option.
Going through panellook.com, there isn't really much of a choice. I identified a couple of candidates:
LTL123YL01-001, LQ123P1JX31, LSL122DL01-001
The first two have glare surface (the third is not specified), so that's alone a let down (Matte would be really preferred)
Then, there's the question of mounting and the dimensions (too narrow/too high?) So, not sure if this will be a viable option?
Also, do one need to worry about panel type? - Must it be 'LCM' or Cell/Assembly also acceptable? (not sure if these have different usage purposes)
In all honesty, I would be happy with a 1920x1200 display but those look extinct. If so, I'll just have to go with 1080p (which is admittedly still MILES better than "HD").
nitrocaster
#323 Post by nitrocaster » Fri Dec 30, 2016 9:13 am
seasonshu wrote:Ok, this only becomes interesting when nitrocaster creates a 4-lane eDP version of the board (for resolution > FHD).
You can not fit 16:10 or 3:2 panel in X220/X230 without designing a custom bezel which is not really possible.
The valid options (16:9 screens which you can buy) include these models:
LQ125D1JW31 (4K) http://www.ebay.com/itm/12-5-LCD-screen ... 1778930708
LQ125D1JW33 (4K) http://www.ebay.com/itm/12-5inch-Sharp- ... 1237736299
LQ125T1JW02/A01 (2K) http://www.ebay.com/itm/LCD-Display-Scr ... 1102880739
Given these prices, a complete kit with shipping would cost about $180-200.
timsydney
#324 Post by timsydney » Fri Dec 30, 2016 10:42 am
nitrocaster wrote:not really possible.
I'm assuming you'd have to lose the webcam and wifi antennas at least.
boutch55555
#325 Post by boutch55555 » Fri Dec 30, 2016 11:49 am
BTW don't even think about that sweet sweet LP129QE1-SPA1 (12.9 3:2)
http://imgur.com/EdIKY7w
Even this one falls short of filling horizontally, missing 1-1.5mm
timsydney
#326 Post by timsydney » Fri Dec 30, 2016 11:54 am
boutch55555 wrote:BTW don't even think about that sweet sweet LP129QE1-SPA1 (12.9 3:2)
Where does the LCD PCB even fit?!
seasonshu
#327 Post by seasonshu » Fri Dec 30, 2016 1:04 pm
Is the LCD... taped on top of the existing bezel..? Probably making it impossible to close the lid? Oucho.
Anyways, how have you plugged in a 40 pin eDP and drive the LCD?
boutch55555
#328 Post by boutch55555 » Fri Dec 30, 2016 5:26 pm
seasonshu wrote: Is the LCD... taped on top of the existing bezel..?
No, just placed the unplugged screen on the laptop for a size compare.
timsydney wrote: Where does the LCD PCB even fit?!
It's very narrow at the bottom http://imgur.com/pAHqVAh
I could put it on the back to save the last 5mm over the leds. But it would still require custom hinges. I'll probably go the 13.3" way instead.
I don't have a 40 pin yet, waiting for nitro ;)
x3o2
#329 Post by x3o2 » Sat Dec 31, 2016 8:17 am
I'd like to upgrade my X230 with a 13'' non-touch FHD panel from the XPS 13.
There is many versions of panels over the years and as some sites say, the non-touch FHD panel in the XPS 13 2016 (9350) is close to perfect.
But there is no info on the producer or the model.
The X330 comes with the Sharp LQ133M1JW03, working in the XPS 13 as well. Is this the model I am looking for?
Or would you prefer another XPS 13 panel?
acooc
#330 Post by acooc » Sun Jan 01, 2017 1:23 pm
The LQ125D1JW33 UHD 3840X2160 sounds amazing.
Please inform me when kit is available. I'd be interested.
ThinkPad X220
i7-2640M CPU
Users browsing this forum: asgaard and 5 guests
