vade
#361
Post
by vade » Thu Jan 05, 2017 3:16 pm
nitrocaster wrote:A reasonable way to go is to replace the PMH. Which CPU do you have on your board: i5 or i7?
Indeed, replacing the PMH would be less wasteful. The CPU is an i5-2520M.
I wonder, can such a factory-mounted component be replaced using nothing but a modest soldering iron?
nitrocaster
#362
Post
by nitrocaster » Thu Jan 05, 2017 3:24 pm
vade wrote:nitrocaster wrote:A reasonable way to go is to replace the PMH. Which CPU do you have on your board: i5 or i7?
You can carefully cut each terminal and remove the chip itself, leaving the stumps soldered to the pads. Then use a blob of leaded solder to remove the stumps, clean the pads with a wick, cover them with flux, place new PMH and solder any two opposite pins while holding the chip flat on the board. Next, solder the rest of pins, clear the junk with alcohol and you're all set.
nitrocaster on Thu Jan 05, 2017 3:50 pm, edited 1 time in total.
vade
#363
Post
by vade » Thu Jan 05, 2017 3:41 pm
PMH replacement sounds doable with that technique. Now just need to find a working PMH and a replacement for F1 fuse.
I very much appreciate the effort you (and others) put into diagnosing the consequence of my mistake. Learned quite a lot. Thank you.
nitrocaster
#365
Post
by nitrocaster » Thu Jan 05, 2017 3:55 pm
vade wrote:PMH replacement sounds doable with that technique. Now just need to find a working PMH and a replacement for F1 fuse.
You can buy both on eBay or AliExpress. If you were using X230, I could send you a replacement PMH (bought 6 of them during diagnosing my dead X230 board).
nitrocaster
#366
Post
by nitrocaster » Thu Jan 05, 2017 3:58 pm
RealBlackStuff wrote:Excuse my dumb question, but what is PMH/PHM?
'PHM' was a typo. PMH = Power Management Hub or so called 'Think Engine', which drives power mosfets, monitors voltages and temperatures.
vade
#367
Post
by vade » Fri Jan 06, 2017 5:55 am
nitrocaster wrote:You can buy both on eBay or AliExpress.
Shopping for parts now. X220 schematic says the PMH is a BU77700KVT-GP. However, I looked at the chip and it says only BU77700KVT without the -GP suffix. Is it relevant?
nitrocaster
#368
Post
by nitrocaster » Fri Jan 06, 2017 5:59 am
vade wrote:nitrocaster wrote:You can buy both on eBay or AliExpress.
'GP' is just some generic siffux used in their part library, ignore it.
nitrocaster
#370
Post
by nitrocaster » Sat Jan 07, 2017 8:33 am
At least you guys can learn from other's mistakes while waiting, decreasing the chance of winning the fried motherboard lottery.
Tasurinchi
#371
Post
by Tasurinchi » Sat Jan 07, 2017 12:11 pm
Got my package today!
Very nicely packed, good job! Now I need to practice soldering on guinea-pig stuff I have around before messing up any board!
Smradek
#372
Post
by Smradek » Mon Jan 09, 2017 5:08 am
Hi nitrocaster.
I can get LQ133M1JW03 on taobao for 350 RMB plus shipping. The eDP connector is located on the right side of the panel. Is Your eDP cable long enough to reach the connector on the panel?
nitrocaster
#373
Post
by nitrocaster » Mon Jan 09, 2017 5:22 am
Smradek wrote:Hi nitrocaster.
The connector has to be located on the left side. Otherwise the cable would not be long enough.
boutch55555
#374
Post
by boutch55555 » Tue Jan 10, 2017 6:15 am
Ok, so now we need a side switcher flat ribbon (I can only find 40 pins), an extension or a new longer cable.
Tracking says I'll get the screen today, I'll start test fitting tonight. I did some cutting tests yesterday on an old T61 bezel with my desktop mill (Shapeoko 2) and it looks quite nice. I might be willing to cut some for people if needed.
I won't be able to test the screen though, my mod kit is awaiting departure from Russia since Dec 30... They now offer me to send a search request for lost mail !
nitrocaster
#375
Post
by nitrocaster » Tue Jan 10, 2017 6:38 am
All packets to US and Canada seem to have the same status. I ordered case parts for my X230 on eBay from China on December 23 and the last status update is 'Awaiting for departure from China' on December 24. So, that is kinda common problem. Holidays
Smradek
#376
Post
by Smradek » Tue Jan 10, 2017 7:04 am
nitrocaster wrote:Smradek wrote:Hi nitrocaster.
OK, I gave up on 13.3" and ordered two LG LP125WF2-SPB4
from win0win's AliExpress shop. Cheaper then eBay
When the kits arrived I've seen how small this things really are, so ordered this too
http://www.ebay.co.uk/itm/0-3ML-Disposa ... 1442147392
Has anyone experience with this Paint-Instead-of-Solder-Thingy?
Post
by RealBlackStuff » Tue Jan 10, 2017 7:08 am
I wonder if Putain has ordered USA shipments to be "held" as punishment for the 35 embassy staff who were thrown out by Obama...
nitrocaster
#378
Post
by nitrocaster » Tue Jan 10, 2017 7:17 am
RealBlackStuff wrote:I wonder if Putain has ordered USA shipments to be "held" as punishment for the 35 embassy staff who were thrown out by Obama...
Yeah, while riding a bear topless
nitrocaster
#379
Post
by nitrocaster » Tue Jan 10, 2017 7:23 am
I have. It contracts very much after curing and does not fill plated through holes, so the adapter board would fall off easily. One could use it for attaching the sense wire though. But if you can solder PTHs, why not solder the sense wire as well?
Smradek
#380
Post
by Smradek » Tue Jan 10, 2017 7:42 am
Yeah, I was worried about filling the holes.
nitrocaster
#381
Post
by nitrocaster » Tue Jan 10, 2017 9:38 am
Smradek wrote:ordered two LG LP125WF2-SPB4 from win0win's AliExpress shop. Cheaper then eBay
I couldn't find win0win on AliExpress. A link would be helpful.
Smradek
#382
Post
by Smradek » Tue Jan 10, 2017 10:06 am
nitrocaster wrote:Smradek wrote:ordered two LG LP125WF2-SPB4 from win0win's AliExpress shop. Cheaper then eBay
https://www.aliexpress.com/item/B125HAN ... 29067.html
I was searching for LP125WF2-SPB4 on Taobao and found the Taobao seller win0win.
Asked for the price for LP125WF2-SPB4 the seller gave this link and confirmed it is his AliExpress shop.
nitrocaster
#383
Post
by nitrocaster » Tue Jan 10, 2017 10:16 am
Nice. Let's wait until you get your panels and see if they are really good.
boutch55555
#384
Post
by boutch55555 » Tue Jan 10, 2017 7:08 pm
So, yeah... the LQ133M1JW03 is wider than casing, no fit.
dogeitrade
#385
Post
by dogeitrade » Tue Jan 10, 2017 11:18 pm
Received the LCD today from win0win, now just waiting on the kit
x3o2
#386
Post
by x3o2 » Wed Jan 11, 2017 4:26 am
boutch55555 wrote:the LQ133M1JW03 is wider than casing, no fit.
Agree. It doesn't fit ootb. But...
it is part of the X330. To make it fit, you have to adapt the casing big time. If you want one of the best 13'' panels around in a 12'' machine, go this way.
But keep in mind, the eDP-connector of the LQ133 is on the 'wrong' side, so you'd need a longer eDP cable.
boutch55555
#387
Post
by boutch55555 » Wed Jan 11, 2017 5:59 am
x3o2 wrote:To make it fit, you have to adapt the casing big time. If you want one of the best 13'' panels around in a 12'' machine, go this way.
No, I mean the screen is 0.5 - 1mm wider than the exterior of the casing. It just can't physically fit.
nitrocaster
#390
Post
by nitrocaster » Wed Jan 11, 2017 8:28 am
You seem to get it now. They remove the frame from the LCD.
- 22 Replies
- 3314 Views
Last post by jaspen-meyer
Fri Apr 14, 2017 9:34 am
T420s/430s FHD/2k upgrade
A while back rmsmajestic was selling a few FHD upgrade boards for the t420/t430/t420s/t430s. JJ is still working on a revision to fix the flickering...
- 18 Replies
- 1955 Views
Last post by llemon
Wed May 24, 2017 6:05 pm
- 4 Replies
- 680 Views
Last post by nizmoz
Fri Jan 13, 2017 6:17 pm
- 2 Replies
- 515 Views
Last post by Johan
Thu Feb 09, 2017 11:02 am
Users browsing this forum: ethink and 6 guests
