X220 FHD Upgrade?
Re: X220 FHD Upgrade?
Thanks to all who are helping.
When originally soldering the PCB I applied no-clean flux.
Just in case, this morning I resoldered (actually just heated up with my soldering iron until solder became liquid again) all 7 PCB dots and the power wire (but not the sense wire, too 'sensitive' a location).
I rechecked again with my multimeter that there are no false contacts.
Next question:
in BIOS LCD settings there are 5 options:
- Thinkpad LCD
- Analog (VGA)
- Digital on Thinkpad
- Digital 1 on dock
- Digital 2 on dock
I tried them all, but which one should I use?
PS: I have plenty of soldering experience after having done nearly 100 SATA-mods and over 100 LED-mods.
Next question:
- Thinkpad LCD
- Analog (VGA)
- Digital 1 on dock
- Digital 2 on dock
nitrocaster
FHD display corresponds to Digital 2 on dock, but there's no point selecting it until you get the image on it.RealBlackStuff wrote:I tried them all, but which one should I use?
Thanks.
Using Lenovo Diagnostics on that X230, when I do the LCD test I get this:
- Manufacture ID: LGD
- Model: unknown
- EDID Version: 1.4
- Max resolution: 1920x1080
- Max image size: 28 x 16 cm
- Display type: RGB 4:4:4
So the FHD screen is recognized somewhere!
I'm doing this LCD-test using the attached external monitor (a 15" XGA NEC, 1024x768, got there with Fn/F7), while the backlight/screen of the FHD are OFF. Huh????
Should I already set the Dock 2 option?
- Model: unknown
- EDID Version: 1.4
nitrocaster
Dock 2 option should be used to choose new FHD display as primary display. That means when FHD is connected and you connect external monitor, you won't get image on external monitor when booting. By default, external monitor is used instead of internal. So, there's no point to change that right now.
Which OS do you use right now? I suggest we stick with Windows so that I can understand what are you doing.
OK, I've set the BIOS display back to Thinkpad-LCD.
When I boot without HDD, the X230 goes automatically into the Boot Menu/Application Menu.
The above Lenovo display test is part of the: Application/Menu/Lenovo Diagnostics.
I am using a HDD with W7Pro/SP1 in 32-bit.
If I boot into W7, the Fn/F7 no longer functions and the FHD stays off.
carcuevas
RealBlackStuff wrote:OK, I've set the BIOS display back to Thinkpad-LCD.
Weird, can you see if the image is shown in the FHD when the backlight is off (you can see it with very clear ambient light)... It's that W7 working when you connect the old PANEL?
Running Debian on x230 (i5-3320m-12GB-250GB Samsung 850EVO-FHD mod by Nitrocaster + LP125WF2SPB4)
nitrocaster
On which screen did you read that?RealBlackStuff wrote:Using Lenovo Diagnostics on that X230, when I do the LCD test I get this:
- Model: unknown
- EDID Version: 1.4
Go to Control Panel\Appearance and Personalization\Display\Screen Resolution and see what displays you have.RealBlackStuff wrote:If I boot into W7, the Fn/F7 no longer functions and the FHD stays off.
@carcuevas:
The old IPS screen (and W7) still works fine if I connect it instead of FHD.
@nitrocaster:
The Lenovo LCD-test is part of the X230 BIOS.
As I already mentioned, the "1920x1080 test-result" was displayed on the external monitor, while the FHD was off.
(Can't have both on at the same time).
In the meantime I have installed the Intel GPU 4000 drivers from Lenovo (g1d556ww.exe).
(The drive with 32-bit W7 just had generic Windows drivers installed)
Makes no difference (yet).
In Control Panel I have no Appearance, only Personalization (also accessible in W7 by rightclicking the desktop).
When I go into Display it shows THREE displays:
1. Dummy display
2. Display device on: Mobile PC display (presumably the FHD)
3. FPD1975W (External display with 1440x900, swapped against the XGA)
3. is the big one.
It also has a field:
Multiple displays: Extend desktop to this display.
Both 1. and 2. have greyed out Resolution/Orientation, and
Multiple displays: Disconnect this display.
@nitrocaster:
1. Dummy display
3. is the big one.
nitrocaster
So, it is recognized.RealBlackStuff wrote:2. Display device on: Mobile PC display (presumably the FHD)
Your display configuration should look like this ('Dummy display' and 'Mobile PC display' are duplicated): http://imgur.com/WXqEtWY
But you should have got an image right after the first start. Something is wrong. Let's troubleshoot it this way.
0. Disconnect all power!
1. Disconnect old display and reconnect new FHD display
2. Connect external monitor
3. Power up without hard drive
4. Wait until you see an image on external monitor
5. Using Fn+F7 try to get a backlight on FHD display
6. Check if you can adjust the brightness
both .5 (backlight) and .6 (adjust) work
nitrocaster
That means there is no video signal going to FHD panel (on the motherboard side). Or, that could also mean that you choose fake LVDS display and not FHD.RealBlackStuff wrote:both .5 (backlight) and .6 (adjust) work
If you boot with FHD and external monitor, does Windows allow you to use 'Extend these displays' option over 'Mobile PC display' and external monitor?
These are the options in the Display: http://imgur.com/a/TkyFy
On Dummy (1) and Mobile-FHD (2) the Resolution and Orientation are greyed out.
nitrocaster
They are grayed out because they are disconnected.
Choose 'Duplicate desktop on 2 and 3' here: http://i.imgur.com/DcbZRHT.jpg
If I select Mobile display and Choose 'Duplicate desktop on 2 and 3', the upper Display field changes to: "2/3 Multiple Monitors"
And when I try to Apply it (or save anything) it says"Unable to save display settings".
While I'm trying any of this this, the FHD backlight stays on all the time!
nitrocaster
I got similar results with isolated data lines (DOCKB_DP0 and DOCKB_DP1), but without backlight on FHD display. Windows does recognize it but can not save display settings.
Check continuity between 4 solder points corresponding to DP0/DP1 and display side connector on the eDP cable.
I'm lost here, sorry.
boutch55555
DOCKB_DP0 and DOCKB_DP1 = those 4 pins http://imgur.com/daeIVNwRealBlackStuff wrote:I'm lost here, sorry.
Both upper-left and bottom-left in that circle do not even connect to the LCD-connector on the PCB!
All other 5 7 solder-points do.
boutch55555
They should go to pins 6-7, 1 being top left. Do those pins look correctly soldered on the connector ?
Correction:
All 7 solder-points do connect to the LCD connector.
But both upper-left and bottom-left in that circle do NOT connect through to the LCD-connector on the LCD-side.
Then I checked the LCD-cable itself.
That has the same problem, so I think the LCD-cable may be to blame.
nitrocaster
Pinouts are slightly different between two ends. Are you absolutely sure?RealBlackStuff wrote:Correction:
carcuevas
Well actually it can be the EDP cable, because if it would be the LVDS at least you would be able to see the screen images without the Backlight as it happened to me...RealBlackStuff wrote:Correction:
Those 2 pins 6 and 7 do NOT feed through the cable from PCB to LCD.
I have the LCD-pinout but not the PCB-pinout.
So what goes where in that cable?
nitrocaster
I guess you measure that with FHD LCD connected to the adapter board, right?RealBlackStuff wrote:Those 2 pins 6 and 7 do NOT feed through the cable from PCB to LCD.
First 11 pins match on both ends, so pins 3,4 on the board side must be connected to pins 3,4 on LCD side. Similarly, pins 6,7 and 9,10 on the board side must be connected to pins 6,7 and 9,10 on the LCD side.RealBlackStuff wrote:So what goes where in that cable?
After trying everything, in every direction, with or without LCD-cable, pins 6 and 7 do NOT connect to the LCD.
So it's definitely a bad LCD-cable.
nitrocaster
OK, I'm going to send you a replacement cable.
That's great, thanks ever so much!
After getting backlight working on the stock display, there's still no backlight at all on the FHD display. It seems to work otherwise, it shows a picture. I managed to destroy the pad on the adapter board that goes to DOCKB_HPD. Could that be the cause?
nitrocaster
Are you getting no backlight in the OS only or in the BIOS too? Might be fried MCU on the adapter board - it happened to another user when he hot plugged one of the LCD cables.
No backlight in bios.
- 3314 Views
Last post by jaspen-meyer
Fri Apr 14, 2017 9:34 am
T420s/430s FHD/2k upgrade
by tomatohat » Sun Feb 05, 2017 1:31 pm » in ThinkPad T430/T530 and later Series - 18 Replies
- 1955 Views
Last post by llemon
Wed May 24, 2017 6:05 pm
SOLD: Lenovo Thinkpad T440, 256gb SSD, 12GB, i5 4300U, 2.5ghz, FHD 1920x1080
by nizmoz » Sat Dec 31, 2016 7:27 pm » in Marketplace - Forum Members only - 4 Replies
- 680 Views
Last post by nizmoz
Fri Jan 13, 2017 6:17 pm
[FS] T440p i7 4700mq, dGPU, FHD, 16GB RAM, 256SSD, 256 SSD (ultrabay)
by suchness » Mon Feb 06, 2017 3:40 pm » in Marketplace - Forum Members only - 2 Replies
- 515 Views
Last post by Johan
Thu Feb 09, 2017 11:02 am
Users browsing this forum: ethink and 6 guests
