Assuming enough stock when the last bits come in, send me info on where to send my money.
X220 FHD Upgrade?
theterminator93
Re: X220 FHD Upgrade?
That is a thing of beauty.
nitrocaster
Additional pictures and manuals are coming very soon along with the ordering form (and the new thread, I suppose).
Brilliant!!!
I know you will also be providing detailed instructions (many thanks!), at the same time I'd like to start buying the machine and any necessary components for this project.
[*] (Roughly) how many (and what type?) of soldering is required? I am trying to find a hardware repair shop that'd do the installation for me and want to be able to articulate what I expect from them.
[*] Any chance there would be support for WQHD? (2560x1440 .. or maybe 2160x1440). You mentioned that the board currently only has two lanes (for FHD) and depending on interest you'd look into it extending that to 4..
If it's not possible, I think I'd settle for FHD too...
[*] What LCD and more importantly, which LCD SELLER would you recommend? Are there any good sellers on Ebay/AliExpress?.. (I don't want to end up with a "compatible" model where screen brightness doesn't work).
- On reddit (https://www.reddit.com/r/thinkpad/comme ... 30/d7ytsth) you mentioned that these are B125HAN02.0, LP125WF2-SPB3 and B140HAN01.3 will all work with your kit.
- "Antiglare" means Matte screens, correct?
[*] And yes, I am very much interested in purchasing the kit... actually, thinking of getting two (though I need to do some cost analysis first..).
nitrocaster
11 solder points in total. You'll need a soldering iron with somewhat fine tip to install the adapter board and a dremel to remove magnesium protrusions from the lid to fit the display.seasonshu wrote: [*] (Roughly) how many (and what type?) of soldering is required? I am trying to find a hardware repair shop that'd do the installation for me and want to be able to articulate what I expect from them.
It is technically possible, but requires more complicated board design and more expensive cables. Another thing is that I'm not expecting any substantial interest in WQHD version, which means it's rather going to be a waste of time and money. Personally I'm more than happy with FHD.seasonshu wrote: [*] Any chance there would be support for WQHD? (2560x1440 .. or maybe 2160x1440). You mentioned that the board currently only has two lanes (for FHD) and depending on interest you'd look into it extending that to 4..
I haven't yet had a chance to try any other displays aside from B125HAN02.0 and LP125WF2-SPB3, which look pretty similar, but speaking of ease of installation I'd recommend the latter. It fits better and requires less lid material to remove.seasonshu wrote: [*] What LCD and more importantly, which LCD SELLER would you recommend? Are there any good sellers on Ebay/AliExpress?.. (I don't want to end up with a "compatible" model where screen brightness doesn't work).
True. Keep in mind that B140HAN01.3 is a 14-inch display that just happened to lie around, and since it has the same 30-pin eDP connector, I tested my board with it.seasonshu wrote: - On reddit (https://www.reddit.com/r/thinkpad/comme ... 30/d7ytsth) you mentioned that these are B125HAN02.0, LP125WF2-SPB3 and B140HAN01.3 will all work with your kit.
Correct.seasonshu wrote: - "Antiglare" means Matte screens, correct?
Finally the X220 will be usable
theterminator93
Thoughts on LP125WF2-SPB2 or LP125WF2-SPB1? According to first glances at Panelook, they have the same specs.nitrocaster wrote: I haven't yet had a chance to try any other displays aside from B125HAN02.0 and LP125WF2-SPB3, which look pretty similar, but speaking of ease of installation I'd recommend the latter. It fits better and requires less lid material to remove.
nitrocaster
LP125WF2-SPB1 suffers from burn-in effect, you don't want to get one of them. LP125WF2-SPB2 doesn't, but it also doesn't have mounting holes.theterminator93 wrote: Thoughts on LP125WF2-SPB2 or LP125WF2-SPB1? According to first glances at Panelook, they have the same specs.
First of all congratulations, I really appreciate your work.
I do have some questions however:
1) Do you have any experience setting the mod up using a linux OS especially regarding backlight control?
2) As far as I understood backlight control basically relies on the LVDS signal, so LVDS and eDP signals are mimicked and both active at the same time? How does this affect battery life? Did you do any tests?
3) Any chance one will encounter serious problems using coreboot and SeaBIOS?
Again thanks for your effort.
nitrocaster
Haven't tried Linux on my X230 yet, but I definitely will do that and let you know my experience.mollz wrote:1) Do you have any experience setting the mod up using a linux OS especially regarding backlight control?
That's right, LVDS output should be active in order to have brightness control. There's a kernel patch for Linux which disables LVDS output, but keeps its brightness control, which is most likely the perfect solution. Regarding the battery life tests - I didn't do any. Just because I finally assembled my X230 a few days ago. I'll let you know the results when I find out.mollz wrote:2) As far as I understood backlight control basically relies on the LVDS signal, so LVDS and eDP signals are mimicked and both active at the same time? How does this affect battery life? Did you do any tests?
I have no idea. But, as soon as coreboot and SeaBIOS support external monitors, I don't see any reason why it wouldn't work.mollz wrote:3) Any chance one will encounter serious problems using coreboot and SeaBIOS?
nitrocaster
I've just done quick tests and here are the results:
The brightness was set to maximum level so that it doesn't change between two tests. CPU power was limited to its minimum level using Windows power management. So after switching to single display mode the discharge rate falls from 10.16W to 8.55W, which means that 1.61W is wasted and disabling LVDS output does make sense.
Thanks for the heads up! I am literally going in circles though: sellers either list all versions (B1 to B3) in their adverts or just simply state you'll get a "100% compatible model". Yes, I could try to contacting them one by one but that is no guarantee either, whatsoever.nitrocaster wrote:LP125WF2-SPB1 suffers from burn-in effect, you don't want to get one of them. LP125WF2-SPB2 doesn't, but it also doesn't have mounting holes.
I also tried going down the x250 FRU numbers (00HM745 and 00HN899) - they both seem to be B2 panels (whereas in theory they really should be different ones..?). I found that a B4 panel also exists but wasn't really recommended (don't have the link).
So would installing a B2 be possible at all? I'd like it to be as easy as possible.. Needing a dremel already freaks me out a little..
In general though, I believe I don't need to worry about whitelisting..? (my reasons: 1 - AFAIK no LCD whitelist for x220/x230; 2 - the signal goes through the custom board, anyway..)
Please recommend a reliable LCD source preferably in the UK.. or wherever on Jupiter...
Many thanks for doing this test. Yes, I would primarily looking to use the machine away from a socket so power consumption is important. I have an X220, looks to be working. I also would like an X230, however I am not sure I really want that? I read the BIOS cannot be updated (only maybe with Raspberry PI which I don't have) thus there will be no chance for me to disable the LVDS output at BIOS.nitrocaster wrote:So after switching to single display mode the discharge rate falls from 10.16W to 8.55W, which means that 1.61W is wasted and disabling LVDS output does make sense.
I could install a Linux with the LVDS disabled patch, however I need to be in Windows and the extra VM layer might give unwanted side effects.. also, when I tried this, one of my programs simply refuses to work in a VM.. So, disabling LVDS in the BIOS would be the best solution for me -- (not sure if it's possible? also that might completely disable brightness adjustment, too, that way?)
nitrocaster
Not quite. Those may be different HW revisions, for example.seasonshu wrote:whereas in theory they really should be different ones..?
Installing B2 would be more tricky than B3/B4 since you'll have to put custom made spacers in the lid so that the panel would sit in place.seasonshu wrote: So would installing a B2 be possible at all? I'd like it to be as easy as possible..
I've just finished installing the mod for the first buyer. He managed to install the panel himself without a dremel. Pliers did the trick. I only soldered the adapter to the motherboard.seasonshu wrote: Needing a dremel already freaks me out a little..
X220/X230 have no whitelisting for LCDs. Even if they had, FHD panel is connected as external monitor, so it would work anyway.seasonshu wrote: In general though, I believe I don't need to worry about whitelisting..? (my reasons: 1 - AFAIK no LCD whitelist for x220/x230;
It does, but EDID is not faked.seasonshu wrote:2 - the signal goes through the custom board, anyway..)
I can't recommend any sources 'cause the only screen that I bought myself was bought here in Moscow. I'd try eBay or AliExpress.seasonshu wrote:Please recommend a reliable LCD source preferably in the UK.. or wherever on Jupiter...
nitrocaster
I suppose that power consumption could be reduced by reducing color depth and refresh rate for LVDS output. BIOS mod is possible (chinese thinkpadders did that), but I haven't attempted to do it myself.seasonshu wrote: I could install a Linux with the LVDS disabled patch, however I need to be in Windows and the extra VM layer might give unwanted side effects.. also, when I tried this, one of my programs simply refuses to work in a VM.. So, disabling LVDS in the BIOS would be the best solution for me -- (not sure if it's possible? also that might completely disable brightness adjustment, too, that way?)
carcuevas
Wow this is an amazing Project
it will bring more life to our small x220/x230, with this mod I would not retire my x230 easily
Thanks for such a nice addon... I would follow this one and if you will be selling the boards, here you will have one customer
heheh
Running Debian on x230 (i5-3320m-12GB-250GB Samsung 850EVO-FHD mod by Nitrocaster + LP125WF2SPB4)
nitrocaster
Chinese suppliers sent me knockoff eDP cables again, so I have to postpone the release for another week... or 2-3 weeks, I don't know yet. So far 20 adapter were assembled, flashed and tested, 3 kits were sold to local thinkpadders. Meanwhile, I'm preparing a second version of the user manual.
Bummer, I am eager to put my claws on thisnitrocaster wrote:I have to postpone the release for another week... or 2-3 weeks, I don't know yet.
Are you able to return the delivery? Can you make them at least pay for the shipping costs? Ordering something and getting something else makes distance buying really difficult. Rhetoric question: how do you even recognize the quality is inferior? (Well, for one you probably have way more experience than me).nitrocaster wrote:Chinese suppliers sent me knockoff eDP cables again
nitrocaster
And I'm eager to at least return my investments, which are approaching $1K. It's never gonna endseasonshu wrote:Bummer, I am eager to put my claws on this
Sure I can, but return shipping cost would be my expense. Some sellers offer fairly cheap expedited shipping which takes 7-14 days, they respond quickly and provide detailed information about the goods just as you want, but others are not.seasonshu wrote:Are you able to return the delivery? Can you make them at least pay for the shipping costs? Ordering something and getting something else makes distance buying really difficult.
Trust me, when you see a good cable and a knockoff cable, you'll know which one is knockoff.seasonshu wrote:Rhetoric question: how do you even recognize the quality is inferior? (Well, for one you probably have way more experience than me).
carcuevas
Those are bad and very good newsnitrocaster wrote:And I'm eager to at least return my investments, which are approaching $1K. It's never gonna endseasonshu wrote:Bummer, I am eager to put my claws on this
Sure I can, but return shipping cost would be my expense. Some sellers offer fairly cheap expedited shipping which takes 7-14 days, they respond quickly and provide detailed information about the goods just as you want, but others are not.seasonshu wrote:Are you able to return the delivery? Can you make them at least pay for the shipping costs? Ordering something and getting something else makes distance buying really difficult.Trust me, when you see a good cable and a knockoff cable, you'll know which one is knockoff.seasonshu wrote:Rhetoric question: how do you even recognize the quality is inferior? (Well, for one you probably have way more experience than me).
I hope you didn't buy them from WWW.PCHUB.COM in Singapore!
They nearly killed my LED-mod business, due to sending me inferior cable-extensions.
I am currently looking for some nice X220 with 2640m and IPS, but i am very interested in this mod. As far as i understand, there is some soldering needed between the adapter and the mobo, after that, the new screen fits in the place of the old, or is there some additional mod?
And when all of this is done, the new panel works exactly like the old one, or is there a need for some special driver etc?
nitrocaster
Some additional work is required. See preliminary manual: https://drive.google.com/open?id=0B2mH6 ... lIxOE5JQ00Easa wrote:after that, the new screen fits in the place of the old, or is there some additional mod?
True for Linux users, almost true for Windows users. You'll need to use a special utility to fix banding artifacts.Easa wrote:And when all of this is done, the new panel works exactly like the old one, or is there a need for some special driver etc?
carcuevas
nitrocaster wrote:Some additional work is required. See preliminary manual: https://drive.google.com/open?id=0B2mH6 ... lIxOE5JQ00Easa wrote:after that, the new screen fits in the place of the old, or is there some additional mod?True for Linux users, almost true for Windows users. You'll need to use a special utility to fix banding artifacts.Easa wrote:And when all of this is done, the new panel works exactly like the old one, or is there a need for some special driver etc?
Really pro manual
nitrocaster
That's 11 soldering points in total. Not quite a 'couple of pads', but nothing really tricky.
carcuevas
Just some more patiencenitrocaster wrote:That's 11 soldering points in total. Not quite a 'couple of pads', but nothing really tricky.
evening_hunger
Lovin the 3D drawing of sense wire solder. MSc level university report standardnitrocaster wrote: See preliminary manual: https://drive.google.com/open?id=0B2mH6 ... lIxOE5JQ00
x220/i7-2620M/8GB/256gb.ssd/ips/debian (main driver)
x230/i5/8GB/500gb.hdd+256gb.m2ssd/tn/debian+win7 (better half)
nitrocaster
I didn't have unmodded motherboard in that moment, so I couldn't take an actual picture and had no choice but make some drawing. Second version will come with this:evening_hunger wrote:Lovin the 3D drawing of sense wire solder. MSc level university report standard
dogeitrade
TAKE MY MONEYnitrocaster wrote:That's 11 soldering points in total. Not quite a 'couple of pads', but nothing really tricky.
And where can i buy this mod? WHERE! i def need this..
nitrocaster
I have 19 boards ready, but a batch of eDP cables is on its way from China.
- 3329 Views
Last post by jaspen-meyer
Fri Apr 14, 2017 9:34 am
T420s/430s FHD/2k upgrade
by tomatohat » Sun Feb 05, 2017 1:31 pm » in ThinkPad T430/T530 and later Series - 18 Replies
- 1959 Views
Last post by llemon
Wed May 24, 2017 6:05 pm
SOLD: Lenovo Thinkpad T440, 256gb SSD, 12GB, i5 4300U, 2.5ghz, FHD 1920x1080
by nizmoz » Sat Dec 31, 2016 7:27 pm » in Marketplace - Forum Members only - 4 Replies
- 682 Views
Last post by nizmoz
Fri Jan 13, 2017 6:17 pm
[FS] T440p i7 4700mq, dGPU, FHD, 16GB RAM, 256SSD, 256 SSD (ultrabay)
by suchness » Mon Feb 06, 2017 3:40 pm » in Marketplace - Forum Members only - 2 Replies
- 516 Views
Last post by Johan
Thu Feb 09, 2017 11:02 am
