Installing classic keyboard into X230 with EC firmware mod
X230 through X280, plus X390 series specific matters only
skx
Re: Installing classic keyboard into X230 with EC firmware mod
#361 Post by skx » Sun Nov 03, 2019 8:07 pm
matrushko wrote:
Sun Nov 03, 2019 2:36 pm
skx wrote:
Sun Nov 03, 2019 1:55 am
Here you have your issue. Did you read the github instructions? You should downgrade your bios first to 2.76 (G2ETB6WW). 2.77 cannot have its EC modified! It is clearly mentioned in the 1st paragraph of the github instructions. So downgrade BIOS and try again.
Yes, i did.
Sorry I forgot to mention that I DOWNGRADED to 2.76, when I said "2. I solved it with linux,....".
Of course, now i'm with 2.76 but it was precisely when I did it, to solve battery issue, than the keyboard issue appeared.
And now I have tried and tried but nothing achieved on my side.
thanks
thinkpad-ec script has keyboard patch enabled by default and battery patch disabled. so if you only need battery validation patch, you need to disable the keyboard patch and enable the keyboard patch. try again and flash your ec. you just did something in wrong.
ThinkPad X220: i5-2520M CPU 2.5GHz - 8GB RAM 1333 MHz - SSD 860 EVO 250GB - Debian - ME_cleaned
ThinkPad X230: i5-3320M CPU 3.3GHz - 8GB RAM 1600 MHz - SSD 860 EVO 500GB - Debian - ME_cleaned
RoamingAndy
#362 Post by RoamingAndy » Tue Nov 05, 2019 9:28 am
I just lost keys c, d, e, 3. The mod worked great for 6 months. Anyone have any idea what would cause that?
The other keys are working great
#363 Post by axur-delmeria » Tue Nov 05, 2019 9:41 am
A keyboard that's starting to go bad.
Backup: X601 Core 2 Duo T8100
Toy: X60F Core Solo U1300
:cry:
matrushko
#364 Post by matrushko » Tue Nov 05, 2019 3:15 pm
I don't understand that. .. maybe you mistake one "keyboard" by "battery"? or I shall do that , first enable keyboard patch then disable it?
Look:
First time i just put make patch_enable_battery clean among the commands.
But second time I had to do it, I think i went to the github web and copied and pasted "make keyboard patch" or something.
If I just "disable" that, it doesn't work. Or at least, it didn't , last time I did it.
¿Can I boot a Pendrive with just THAT keyboard command, and reboot windows with that pendrive?
I am a bit lost.
I need step by step instructions, from now on, I mean, from my actual state:
bios 2.76, battery Ok, keyboard not.
for instance: "go to linux, copy this... then that.... then flash the pendrive...then reboot... " etc.
I'm not a linux programmer, 100 light years from being it.
thanks. !"
skx
#365 Post by skx » Thu Nov 07, 2019 7:29 pm
yes, I am sorry, that is a typo obviously. first disable keyboard patch and secondly enable battery patch
can you re-try the whole process and post command line output over here including your instructions?
matrushko
#366 Post by matrushko » Fri Nov 08, 2019 4:41 am
[/quote]
[/quote]
Ok!
I will do it, this way (First, I write here my instructions, and after that, I put the former error or "no such file or directory" message that appears if you write it for the first time (keyboard or battery patch), and then, the same mesage but without "no such file or directory" . The point is that no matter it, the battery issue is solved, so I guess that error message doesn't affect keyboard patch either.
I put this and then in other post, I will report the whole linux output.
sudo apt-get install build-essential git mtools libssl-dev
git clone https://github.com/hamishcoleman/thinkpad-ec
cd thinkpad-ec
make patch_enable_keyboard clean
make patched.x230.img
connect a usb
lsblk
sudo dd if=patched.x230.img of=/dev/sdc
AND THE ERROR OR MESSAGE IS:
ubuntu@ubuntu:~/thinkpad-ec$ make patch_enable_battery clean
Makefile:133: .config: No such file or directory
Generated dependancies from descriptions
cp defconfig .config
echo "CONFIG_BATTERY = y" >>.config
rm -f .d/generated.deps \
patched.*.iso patched.*.img *.FL2 *.FL2.orig *.img.enc \
*.img.enc.orig *.img.orig *.bat *.report \
*.img \
*.txt.orig
rm -rf *.iso.extract *.iso.orig.extract
SAME about keyboard.
But if i write it again, firs line doesn't show again "no such file..."
I am going now to work with it.
Thanks !
matrushko
#367 Post by matrushko » Fri Nov 08, 2019 5:46 am
I recorded badly the whole process in video.
Hope it works for you,
https://youtu.be/QUKmTgEXzfI
The following shows the process of putting on battery again, and EC flashing message
https://youtu.be/98Lk0E5vnso
skx
#368 Post by skx » Sat Nov 09, 2019 9:53 am
I understood you only want the battery patch, so you disable the keyboard patch.
make patch_enable_battery clean # Uses the battery validate patch
make patch_disable_battery clean # Turns off the battery validate patch
make patch_enable_keyboard clean # Uses the keyboard patches
make patch_disable_keyboard clean # Turns off the keyboard patches
so in your case, using stock X230 keyboard but aiming to remove the battery validation check you should do:
build the modified firmware and flash it with an OEM x230 battery inside your X230.
matrushko
#369 Post by matrushko » Fri Nov 22, 2019 8:41 am
[/quote]
[/quote]
Ok thanks..let's see:
i did just this (several times):
...enable battery...
...disable keyboard...
but nothing happens. the point is:
I don't have an OEM battery, just this: "ROHS" : li-ion battery pack model x220 (AAAH, is from the 220 anyway, not origina), 5200mah/58wh.
I flashed the usb with those linux orders , reboot without the battery inside, (just cable) etc, and after reboot, i put off and on again the pc, and, already with the non-OEM battery, erverything's fine about "she" but not about "him" (keyboard) (in ispanish they have gender)
Do you think that the problem of the keyboard comes out from a NON OEM?
Tell me , cause if it is so, i won't buy such an expensive one. I can't risk to buy it in amazon an then get it back...
what a pitty .
Thanks.
seasonshu
#370 Post by seasonshu » Wed Dec 04, 2019 11:16 am
I had the same problem after I installed the taping on the connector, I lost keys in two rows, in a similar fashion. Try to apply (reasonable) force to the metal outside of the connector using a plier. It worked for me on the second attempt or so.
roachie54
#371 Post by roachie54 » Tue Mar 31, 2020 4:20 pm
Could anyone tell me please if the trackpad & fingerprint reader from an X230 fit into an X220 palmrest? I'm fairly confident the trackpad would but I've read conflicting reports about the fingerprint reader. I realise I could buy an X220 palmrest with both already fitted but there's a price/availability difference. Would also rather avoid cutting either the classic keyboard or the X230 palmrest.
Also, does the X220 keyboard bezel fit the X230 neatly? I've tried my T420 keyboard in the X230 so can see that swapping the bezel isn't necessary, but it'd make the end result a bit sweeter. Cheers
#372 Post by RealBlackStuff » Wed Apr 01, 2020 1:05 am
xx10 and xx20 keyboards all have the same dimensions and are interchangeable.
And the X220 KB-bezel perfectly fits on the X230.
Lovely day for a Guinness! (the Real Black Stuff). And pigs CAN fly!
"Computers don't lie, but liars can compute." (Terry Hayes: I Am Pilgrim)
Users browsing this forum: obarriel and 10 guests
