A31p - common issues - fix?
Re: A31p - common issues - fix?
#31 Post by ajkula66 » Sun May 29, 2016 11:36 pm
kfzhu1229 wrote:I wanted to upgrade my A30 into SXGA+ but I can only find a screen cable that is SXGA+ according to the part number and I am not sure, and a SXGA+ display that has the same connector as my T4xs (screen bezel is easy to find).
Check out this page...
http://www.thinkwiki.org/wiki/TFT_display
If you bump into a decent UXGA screen, I've got plenty of A3xp cables that you can have for the price of shipping. Fairly certain that I don't have a single SXGA+ one left.
The connector on my A30 is around 5-7cm long, how about your A31p?
Let me make this easy for you: you can use almost any ThinkPad IPS screen (A3x, T4x, R5x, T60/p) on an A3x as long as you've matched it with a proper A3x cable. Depending on what panel you end up using, you may or may not have to finagle with the cable fitting and/or sponge bumpers.
I have a 14.1" SXGA+ and a 15" XGA + cable for T43 lying around and I do not know which one of them can I make use of
These cables are worthless if you're dealing with an A3x planar.
kfzhu1229
#32 Post by kfzhu1229 » Mon May 30, 2016 10:04 am
Wel I do have a UXGA display that is currently on my T43 and the seller is still selling them. So do you think that would at least work with your cable and my existing inverter? I know I have to add sponge and stuff
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
Flexview UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10
kfzhu1229
#33 Post by kfzhu1229 » Mon May 30, 2016 10:06 am
Also if you have any UXGA cable for 15" T43 that would be much appreciated as well
Flexview UXGA:
#34 Post by ajkula66 » Mon May 30, 2016 10:34 am
kfzhu1229 wrote:Wel I do have a UXGA display that is currently on my T43 and the seller is still selling them. So do you think that would at least work with your cable and my existing inverter? I know I have to add sponge and stuff
Yes, it will work. You need a different inverter, though and I don't have any to spare. I can't recall what finagling *exactly* is required with the cable, but am almost certain that you'll have to go through some.
I'll have to look. If I do, these won't go for just the cost of shipping. Will let you know by the end of the week, one way or another.
kfzhu1229
#35 Post by kfzhu1229 » Mon May 30, 2016 5:19 pm
Also when they say upgrading a T43 15" from XGA to UXGA need an new inverter, I did not replace mine, and it still works just fine, even though it gets a little bit hotter... So I am not sure about A30 and it seems like finding the matching inverter is almost impossible. And I am willing to pay you some money for the cable too, if you can guarantee that it will work on my A30 as it is really hard to find on eBay (I literally bought the last T43 UXGA cable available on the entire eBay site and it works just fine on my T43 even though the Radeon X300 seems to struggle with it at times)
Flexview UXGA:
