T70 with Quad Core i7 mobo for T6x is coming!!
Seggybop
Re: T70 with Quad Core i7 mobo for T6x is coming!!
#91 Post by Seggybop » Mon Jun 19, 2017 8:54 am
Buying a camera is excessive... I think a regular cooking thermometer measuring at the beginning, middle, and end of a pipe would work alright for this. It's not super necessary though.
Thinkpad4by3
#92 Post by Thinkpad4by3 » Mon Jun 19, 2017 1:52 pm
Seggybop wrote:Buying a camera is excessive... I think a regular cooking thermometer measuring at the beginning, middle, and end of a pipe would work alright for this. It's not super necessary though.
Laser thermometer? Theyre not expensive. https://www.walmart.com/ip/Ktaxon-GM320 ... 3=&veh=sem
Sent from my SM-G550T using Tapatalk
The only acceptable use for a MacBook is to shop for a Thinkpad.
Thinkpads: 570e,A31p,T40,T42 x3,T42p UXGA,T60p,T61,X61s,X201,X220,X230,T410,T420,T430s(dead),X240 with mod.
New: 701c, 755c, 755cdv
Others: Zenith 286 supersport, Mac Portable 5120, Tandy LT1400
pflugshaupt
#93 Post by pflugshaupt » Mon Jun 19, 2017 2:04 pm
I have a laser thermometer, but it doesn't work well on metallic surfaces. I could try putting some thermo-resistant vinyl tape on top, but first I'm away for a week.
Thinkpad4by3
#94 Post by Thinkpad4by3 » Mon Jun 19, 2017 2:11 pm
pflugshaupt wrote:I have a laser thermometer, but it doesn't work well on metallic surfaces. I could try putting some thermo-resistant vinyl tape on top, but first I'm away for a week.
Metallic surfaces may not work but those blue thermal pads could be accurate since they conduct heat well.
mr.rhtuner
#95 Post by mr.rhtuner » Wed Jun 21, 2017 1:04 pm
Interesting thread...anybody else get a T70?
ElusiveRoberto
#96 Post by ElusiveRoberto » Thu Jun 22, 2017 12:04 pm
Seggybop wrote:
Sat Jun 10, 2017 12:10 am
Update on the heatsink. I think I have it under control now. I removed some more material from the frame around the inductors and then removed and reseated the heatsink after reassembling everything. PCB flexing was probably contributing to the problem. Temperatures are now within 5c with everything tightened down. So to summarize, make sure that the frame isn't impeding the clamping of the heatsink through whatever means necessary, and then reseat it it after you've screwed the frame back into the shell.
I'm interested in seeing if ElusiveRoberto has similar problems.
apojoga wrote:
Fri Jun 09, 2017 5:22 pm
I hope they get to selling ready-made T70s, with all the kinks worked out, because this type of tinkering is way over my pay grade...
Yeah, it definitely requires some work right now. However, I think zhangyongtao (jacky) will sell you a prebuilt.
I will be doing some heat tests tonight, everything is assembled!
Edit: My heatsink wasn't rough but it looked similar to the others, sort of smooth. I was a bit confused what to do with the USB 4 cable until I saw someone on 51nb show the original cable ending in a new usb port floating at the end of the cable, I think they thought they could get the vertical usb on a cable going there.
The 2nd wifi antenna was a bit annoying to have to fix, I'm going to just buy and install new cable rather than splice one like they say. Although it says the next batch will include that cable.
The removal of the metal is sort of not the best. The 4 vrms I believe thats what they are, the last one hits the bottom of the metal frame sort of which isn't mentioned.
I figured out which way to put the screen switch but this wasn't mentioned.
I did run a short stress test earlier though. It seemed to take a long time to get the temperatures to increase. Will do a proper aida64 test later. I didn't notice the idle temps being very high, but I will measure it more later.
Robb
-On aida64 I seem to get around 95 degree temperature average after 15 minutes. They hover around 45 at idle.
I have a uxga screen coming so I will do modifications to get the heatsink to fit better.
Why does Speedfan report my core temps as mid 30s? but then aida shows them in the 50s? I would assume aida is the more accurate program though.
Seggybop
#97 Post by Seggybop » Sat Jun 24, 2017 2:55 am
I've applied the liquid metal TIM (phobya) and temperatures are much better. There's one core that's spiking above the others during stress tests (but not real-world testing of rendering) that's kind of weird, but even that is still better than before.
http://i.imgur.com/YABwSb1.png
Results are similar pflugshaupt's with iGPU also being stressed.
I'm pretty confident that the limiting component of the heatsink is the solid copper block and if I ever find a source for vapor chamber parts I'll try replacing it, but no idea where to find one for now.
pflugshaupt
#98 Post by pflugshaupt » Sat Jun 24, 2017 1:03 pm
You should really try undervolting. I'm now running -125 mv on the CPU and it is stable and I also use Throttlestop to undervolt the iGPU with -50 mV and temps are very reasonable now.
Seggybop
#99 Post by Seggybop » Sun Jun 25, 2017 6:57 am
Did you do -50mv on iGPU both slice and unslice?
