X62 problems, quirks, and fixes
ctoph0
Re: X62 problems, quirks, and fixes
#91 Post by ctoph0 » Sat Apr 01, 2017 9:23 pm
mdancer wrote:Yep, I've got pc7 as well now. The nice thing about having pc7 is that the laptop is absolutely silent now
(finally!) during the usual work including watching video using vaapi.
I'm not exactly sure what you are doing here, regarding pc7 but im intrigued. Can you give me a bit of context as to what you are doing and how you made the laptop silent?
Past: A22M T61P X41T X200 X201
Present: X201 X220 X61s T420
Future: Upgrading the present!
andykrej
#92 Post by andykrej » Tue Apr 04, 2017 1:03 pm
Looks like PC7 works in windows as well.
You have to update the Realtek GBe driver as the one built into Windows won't allow the PC7 state. I went with the latest from Realtek:
http://www.realtek.com/downloads/downlo ... Down=false
I also followed harryK's steps for BIOS settings:
I enabled Aggressive LPM and DEVSLP in the BIOS (I used shorter intervals than the default), and activated SATA min_power in TLP.
Unfortunately the PC is not silent. Fan still turns on. However i need to update my BIOS to the latest and see if it differs.
X62s / SXGA+ Xiphmont / i7-5500u / Samsung 840 pro/ 16GB
T61 / QXGA IPS / 2.4GHz / 8GB
whitelabel
#93 Post by whitelabel » Mon Apr 10, 2017 11:24 am
Hi folks!
I'm asking for assistance.
I'm trying to install a WLAN and a WWAN card into X62. So the idea is to have them both. However the WLAN card is not working
in the upper slot and the WWAN card is also not working in that slot. They are working in the bottom slot though...
So.. Any idea?
dmdsoftware
#94 Post by dmdsoftware » Mon Apr 10, 2017 11:27 am
whitelabel wrote:Hi folks!
So.. Any idea?
it seems the upper slot is for msata only. I couldn't get any WWAN or WLAN to work from it.
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
"Think" Ultrabook i7
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
X60/X60s, X61, T61, T420, X30
past:
X24, X23, X22, X21, X20, 390X
whitelabel
#95 Post by whitelabel » Mon Apr 10, 2017 11:30 am
So.. Any idea?
Thanks for your reply!
Dammit! What a huge disappointment! I really thought that I can have them both..
Looks like there is no X62 for me anymore.
dmdsoftware
#96 Post by dmdsoftware » Mon Apr 10, 2017 11:34 am
unless there is some trick / mod to get the card to work.
My T420/W520 can accept either a msata or WWAN in the second slot.
I didn't deep-dive into the Bios when I tested and failed to get it working. There may be some kind of toggle.
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
whitelabel
#97 Post by whitelabel » Mon Apr 10, 2017 11:41 am
I see. Thanks for sharing this.
My W520/X220 is also working fine with this pair, but it seems like our Chinese colleagues did not implemented this feature.
What a waste! This mobo is gorgeous. And with a LED mod from Monty this laptop turns into a small and powerful beast.
flyingfishfinger
#98 Post by flyingfishfinger » Mon Apr 10, 2017 12:09 pm
With the spare internal USB port, you can probably fit one of those WWAN-Adapter things next to the sound board and have both.
Seems to lack a 2nd true mPCIe lane though, which is sad.
R
dmdsoftware
#99 Post by dmdsoftware » Mon Apr 10, 2017 12:10 pm
Which screen panel are you using the LED mod on? (XGA? SXGA+ IPS? SXGA+-from-tablet? or panel provided with X62?) I just got 2 LED mod kits shipped from Monty.
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
dmdsoftware
#100 Post by dmdsoftware » Mon Apr 10, 2017 12:13 pm
flyingfishfinger wrote:With the spare internal USB port, you can probably fit one of those WWAN-Adapter things next to the sound board and have both.
R
I wish more motherboards had internal USB. On a particular ultrabook, I ripped out the keyboard and replaced it with a Thinkpad keyboard + usb converter, but I had to wire it to one of the external USB ports. Would have been an ideal mod had it been to an internal connector.
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
past:
flyingfishfinger
#101 Post by flyingfishfinger » Mon Apr 10, 2017 12:23 pm
X62 does have an internal USB port, it's by the fan
whitelabel
#102 Post by whitelabel » Mon Apr 10, 2017 12:35 pm
I'm using SXGA -100 panel which was upgraded with the daylight kit from Monty. Can go working on a direct sunlight. No problem with it.
Funny thing, but I'm not able to use my WWAN modem in the bottom slot. I just got some cheap SIM card holder with a bus line which should
be connected to the mpcie slot simultaneously with the modem. And no SIM is found...
flyingfishfinger
#103 Post by flyingfishfinger » Mon Apr 10, 2017 4:44 pm
I've got a combination BT + Wifi working fine, meaning that the PCIe lane and USB both seem to be wired through correctly. AFAIK the WWAN cards tend to be USB, so they should work...
In other news, I'm running an Apple Cinema over miniDP at 2560x1440 right now and it works great, no issues :)
R
whitelabel
#104 Post by whitelabel » Tue Apr 11, 2017 8:55 am
Hi everybody!
I just got some interesting information from Jacky. He's always helpful. And I hope that I can share it with you.
He said that there's an internal USB port. Check this pic: http://funkyimg.com/i/2rAUn.png (Size: 1.31 MB)
I'm thinking about this option. Seems like I can solder my mini pcie-to-usb wwan converter to this internal port.
And hide this thingy inside the laptop.
flyingfishfinger
#105 Post by flyingfishfinger » Tue Apr 11, 2017 10:57 am
As I said 8)
In fact, it's the same plug that the fingerprint reader in the X61t lid uses, it was just discussed over on the German forum where someone used it to hide a small internal hub / mouse transmitter
R
whitelabel
#106 Post by whitelabel » Tue Apr 18, 2017 8:43 am
Hey hey!
Just wanted to let you know that it's absolutely possible to fix the upper mini pcie slot (MSATA) by manually
providing it with some pins from the internal usb port. I've asked my friend to help me with this task. And he succeeded. 2 hours work.
Right now my upper mpcie slot has the LTE-A modem (with the SIM holder) in it. Glorious thing.
No need to find the place to hide that monstrous USB-to-MiniPCIE converter.
andykrej
#107 Post by andykrej » Tue Apr 18, 2017 10:43 am
whitelabel wrote:Hey hey!
Nice job!
Do you have a modem with a sim holder on it, or did you attach it somewhere else? Which modem are you using?
whitelabel
#108 Post by whitelabel » Tue Apr 18, 2017 11:10 am
Nice job!
Hi!
I'm using Sierra MC7455 with this external SIM holder:
(_http://www.ebay.com/itm/Usim-sim-card-socket-s ... 1659521304)
andykrej
#109 Post by andykrej » Tue Apr 18, 2017 12:48 pm
whitelabel wrote: I'm using Sierra MC7455 with this external SIM holder:
Thanks. Do you know which pins where connected? Is it enough with just two cables to pin 36&38? They're called usb d+ and usb d- in the specs.
whitelabel
#110 Post by whitelabel » Thu Apr 20, 2017 7:27 am
Hi!
Yes, you only need D- and D+ from that internal USB port.
As for the mini pcie slot pinout assignment - it has the standard pinout, just google it.
And here's the pinout for the internal USB port: 5V/D-/D+/GND with GND being the closest to the fan connector.
Also you might face some strange problem when the modem is still not recognized by the OS. In that case you can ask me
and I'll provide you with my BIOS settings. I'm just not sure about the reason of this issue. And I hope you won't face it and
your modem will be working without any additional steps.
HTH
andykrej
#111 Post by andykrej » Sun May 07, 2017 1:59 pm
To Whitelabel: Thanks for your instructions. I have succeeded installing a MC7710 into the mSata slot.
I would never have attempted or even come by this idea if not for your pioneering.
Do you know the speed of the internal USB? I read somewhere that your MC7455 needs USB 3 to reach the CAT6 speeds.
I thought about installing a Jack for an external antenna to get better coverage. I think the WWAN antenna on X61 was only for 3G.
I also instlled a second WWAN antenna from X201 into the left palmrest. I didn't notice any performance improvent.
I am in a bad covered area, and my Huawei P9 is consisently reaching higher speeds.
whitelabel
#112 Post by whitelabel » Mon May 08, 2017 2:28 am
Hey! That's good news! Glad I could help :)
I don't have any info regarding the speed of that port. Should probably ask Jacky about this when I have a chance.
I did some quick downloads during the period of testing and I got (most of the time) ~10MB/sec with this modem on the LTE-A connection.
However our Moscow cellular networks are overloaded and I don't know how to reach CAT6 speeds..
Probably this is a chance to try some link aggregation technics..
I was thinking about replacing/upgrading the hardware part of the WWAN subsystem (cables, antenna), but I'm still thinking.
Here are some interesting and useful links for you to check (there are some attractive ideas):
http://www.itocp.com/htmls/27/n-127.html
http://www.itocp.com/htmls/56/n-156.html
http://www.itocp.com/htmls/58/n-158.html
http://www.itocp.com/htmls/59/n-159.html
flyingfishfinger
#113 Post by flyingfishfinger » Tue May 09, 2017 12:15 pm
FYI, user "mifritscher" over in the German forum has dumped and disassembled the EC. You can read about it on his wiki page here.
Maybe this will help us get our hands on fan control and various other stuff, I'm curious to see what he comes up with...
Cheers!
R
mifritscher
#114 Post by mifritscher » Mon May 15, 2017 1:47 pm
Hio :-)
Yes, I'm playing a bit with the EC's firmware ;-) I hope that I get some further insights. Yesterday I compared some versions and identified the main algorithm for the fan (I hope). Theoretically I should be able to put the old algorithm in the new firmware, but to do this I'll need some more boldness *g*
I've built 2 x62t, which are working nice. One little problem is that one board is a bit unstable if I use both DIMM-slots - e.g. hard hang on memcheck86+ on 21%. Single channel works flawlessly - tried both modules, both slots. I'm using 2x4GB DDR3 (no L), which are working in the other x62t yust fine.
The biggest missing thing so far was the lack of the PXE firmware for the network card... The bios seems to have the functionality, its just the ROM option which is missing. http://www.realtek.com.tw/Downloads/dow ... &PNid=13#3 has some UEFI UNDI drivers and PXE code ;-)
fatpolomanjr
#115 Post by fatpolomanjr » Mon May 15, 2017 8:11 pm
I hope you have a way to hard flash your motherboard in the worst case scenario.
Even if you tweak the fan behavior through the BIOS, there will never be a way to control the fan through any kind of OS, due to lack of sensors, correct? I know that there is a relatively easy method to flash a custom image on the splash screen; if you find out how to tweak the fan software do you think it will be possible for end users, that are not afraid of playing with BIOS firmware (like me), to set our own fan behavior?
T60/61 Frankenpad | 15" UXGA LED | T9300 | Intel X3100 | 8GB RAM | 256GB SSD | Manjaro i3 / Windows 7
X62 | 12.1" SXGA+ Xiphmont LED | i7-5500U | 8GB RAM | 256GB SSD | Xubuntu / Windows 10
Thinkpad 10 Tablet | Atom Baytrail | 128GB eMMC | 4GB RAM | Windows 10
mifritscher
#116 Post by mifritscher » Tue May 16, 2017 1:39 am
There is a known interface to interact with the ec, which e.g. https://github.com/hirschmann/nbfc/wiki/EC-probing-tool uses. Works also under linux (albeit the need to compile yourself). Reading give some meaningful results (e.g. one temperature and some power stats), writing is also possible with this interface (albeit the EC firmware seems to ignore writes). And even if not: the EC has direct access to the keyboard matrix - so as a last resort some "magic key combos" can be used ;-)
Regarding sensors: The CPU has some sensors, also most HDDs/SSDs and some WLAN cards can measure temperatures. I think that even only the CPU sensors alone are enough.
The firmware for the EC resides on U19 (bottom side), which can be written with a simple SPU programmer (or AVR/rasberry/...) :-)
The "main BIOS firmware" is another kind of beast and resides on U2
whitelabel
#117 Post by whitelabel » Tue May 16, 2017 2:36 am
Hey mifritscher,
glad to have you onboard!
Could you describe this X62T, please? Does the touch-function (pen/finger) work as intended?
I suppose there's no point in building X62T only for the chassis.
mifritscher
#118 Post by mifritscher » Tue May 16, 2017 9:00 am
In the german forum, el-sahef did the first x62t of I know. You can see it here: https://thinkpad-forum.de/threads/20254 ... ost2045818 . For the most things I used his ideas/ways.
The main mods are the leds (further wires needed), the wacom+keys on the screen (2 avrs + hub needed) and the HDD bay (mod the little pcb or the bay itself)
mifritscher
#119 Post by mifritscher » Tue May 16, 2017 1:05 pm
I've got the problem that memcheck+ 5.01 hangs hard at 21/66% when I use 2x 4 GB DDR3 modules. Tried 3x2 different parts, 2 had 1333 MHz, 4 1600 MHz. And in 2 62 mobos. Single channel is working fine... Bios problem?
P.S. I used always the force smp option.
el-sahef
#120 Post by el-sahef » Wed May 17, 2017 3:17 pm
The SMP option of memtest86+ seems to be buggy. If you have errors or freezes with it try again in non-SMP mode.
I got a second 8 GB RAM module today and ran memtest86+ in non-SMP mode for two passes with no errors. In SMP-mode it freezed at some point.
Users browsing this forum: TPFanatic and 3 guests
