Would you pay $54 for such kit for X220T/X230T?
Yes
75
89%
No
9
11%
Total votes: 84
T3f4l
#211 Post by T3f4l » Mon Feb 06, 2017 5:43 am
I'm patiently waiting for the second batch, my X220 screen has finally died (It had a hairline crack running through it)
X220, 2.8 i7, 16gb 1866mhz, 512gb Samsung msata boot and 480gb Sandisk ssd storage
T22, 1ghz PIII, 512mb PC100 Ram, 128gb ssd boot and 320gb Weston Digital Storage
T21, ???ghz PIII, ???mb PC100 Ram, Its a parts donor that may see life again!
Quantumcross
#212 Post by Quantumcross » Mon Feb 06, 2017 1:27 pm
Just recieved a 1080p panel from win0win! Now to patiently wait for the kit :)
seasonshu
#213 Post by seasonshu » Thu Feb 09, 2017 6:06 am
carcuevas wrote: Well I order some samples for the FFC, I think the problematic is as you said the LVDS, the FCC cables have a limit for flexing, after this limit they cannot assure it's not working, the one I orderr now they resists 20 times 180 degrees let's see how they will work... they should arrive soon :)
@carcuevas, @technopanda: can you share a source for the LVDS cable? One of mine are wrong from the get-go (probably went wrong in the repair shop). It's 180 degrees bent. Effects are flashy to blank screen. I could make it work though I even dread using the keyboard now. @nitrocaster may be able to send one though not sure about the postage costs?
Off topic, probably I should ask it on eGPU reddit... If my expresscard is plugged in, the machine won't go past POST. Tried removing battery and hard-resetting by pressing the power for 30 seconds. It worked once (simple laptop overheating?) but then I made the mistake of running the eGPU without the external power source on. Worked for 2-3 hours and eGPU got disconnected again. So, I suspect it may have drawn too much power from the express card slot and fried that? The machine boots fine without the express card + the same setup (Beast v8 + GTX1060) is working fine on my W520. Once I replace the LVDS cable I may retry but not willing to risk my other X230..
carcuevas
#214 Post by carcuevas » Thu Feb 09, 2017 6:20 am
Hi seasonshu, actually I got mines as a sample from here http://katalog.we-online.de/en/em/FFC_0 ... 1486638987 specifically the 28pins reference: 687728050002 , it's just maybe my impression but it looks for me that they are a bit more quality ones than the one I got... About prices and so I cannot tell, I just got a couple of them as samples, since I could not find any Wurth distributor for electronics here in Czech Republic...
Admin note: there's no need to quote every message! If you are the first to answer anybody's post,
please click on the post reply button on the left. Thank you.
Running Debian on x230 (i5-3320m-12GB-250GB Samsung 850EVO-FHD mod by Nitrocaster + LP125WF2SPB4)
technopanda
#215 Post by technopanda » Thu Feb 09, 2017 6:46 am
@seasonshu I don't have any issue with the internal LVDS cable in my X230. Sorry I can't provide any helpful information about where to getting a replacement cable.
#216 Post by RealBlackStuff » Thu Feb 09, 2017 7:15 am
I posted about those cables earlier: http://forum.thinkpads.com/viewtopic.ph ... 15#p794115
Farnell UK has only 10cm and 15cm in stock
http://uk.farnell.com/webapp/wcs/stores ... 303336&vw=
10cm works fine (someone else on the forum tried it.
theterminator93
#217 Post by theterminator93 » Thu Feb 09, 2017 8:09 am
Just out of curiosity, are there any differences between batch 2 and batch 1, either from a software or hardware perspective?
carcuevas
#218 Post by carcuevas » Thu Feb 09, 2017 8:17 am
RealBlackStuff wrote:I posted about those cables earlier: http://forum.thinkpads.com/viewtopic.ph ... 15#p794115
Yep I can confirm that, it's exactly the one I am using ...
nitrocaster
#219 Post by nitrocaster » Thu Feb 09, 2017 8:21 am
theterminator93 wrote:any differences between batch 2 and batch 1, either from a software or hardware perspective
4th revision has separate power rail for LCD logic and more convenient aux power pad placement. Regarding the firmware - I don't plan anything yet, but we'll see.
seasonshu
#220 Post by seasonshu » Thu Feb 09, 2017 8:42 am
Thank for both RealBlackStuff and carcuevas, I was sure I read about 10cm cable somewhere.. How does it fit under the keyboard?
Actually UK or not, the delivery charges are extraorbitant. Farnell being the 'best' with £2.42+£3.95 shipping. Maybe I should ask for a 'sample' from Wurth (ehm, if I am honest, maybe they won't mind?)
So am I looking for "FFC Flat Cable, Standard 28-pin, 0.5mm Pitch, 50mm Length, Opposite sided contacts" (did I missing anything?) (or, up to 100mm).
#221 Post by RealBlackStuff » Thu Feb 09, 2017 9:08 am
There are plenty more FFC options in the UK, but most have a lousy, nondescript website that gives you zilch useful information.
Google with: ffc cable, uk
and try calling them.
Smradek
#222 Post by Smradek » Sat Feb 11, 2017 1:41 pm
You can add win0win's AliExpress shop to the list of recommended sellers.
I asked for and got two LP125WF2-SPB4 for $59 each incl. shipping.
https://www.aliexpress.com/item/B125HAN ... 29067.html
I installed one in my i5 x220 and it is working perfectly except brightness fixed at 65% when running on battery (fixed by uninstalling Lenovo power something something).
The other was for my i7 x220. No picture. Troubleshooting, no picture. Tried the other FHD panel, no picture. Old panel back, no picture. Troubleshooting, fuse f12 32V 1A blown :(.
mr.rhtuner
#223 Post by mr.rhtuner » Thu Feb 16, 2017 9:15 am
Waiting for a status update on the next batch :-)
Smradek
#224 Post by Smradek » Thu Feb 16, 2017 9:58 am
nitrocaster
#225 Post by nitrocaster » Mon Feb 20, 2017 11:56 am
Update: 2nd batch production is going to take a little bit longer than expected due to delayed shipping of some components.
TheChuckster
#226 Post by TheChuckster » Mon Feb 20, 2017 1:42 pm
Thanks for letting us know @nitrocaster
I was wondering how well this mod will likely work with hackintosh macOS Sierra?
It is completely equivalent to plugging in a 1080p monitor into the DisplayPort port on the dock while the laptop is docked, right?
If so, then there should be no trouble at all.
nitrocaster
#227 Post by nitrocaster » Mon Feb 20, 2017 2:20 pm
It's eqivalent to plugging in a 1080p monitor into the DisplayPort on the dock and using dual display confiruration with mirroring.
TheChuckster
#228 Post by TheChuckster » Mon Feb 20, 2017 2:57 pm
Cool, my LCD panel arrives tomorrow!
6sicSIX
#229 Post by 6sicSIX » Mon Feb 20, 2017 5:28 pm
Hi all,
I have instaled the kit and 1080p lcd with no issues, but how to you get the intel dithering to function?
I can't read the readme files and when I run the program nothing seems to happen at all....
Thanks.
nitrocaster
#230 Post by nitrocaster » Mon Feb 20, 2017 5:36 pm
This program adds its icon to the system tray. Its menu is pretty much self-explanatory and straightforward.
TheChuckster
#231 Post by TheChuckster » Mon Feb 20, 2017 5:41 pm
nitrocaster wrote:Update: 2nd batch production is going to take a little bit longer than expected due to delayed shipping of some components.
Got it. What's the updated ETA? Before March?
6sicSIX
#232 Post by 6sicSIX » Mon Feb 20, 2017 5:44 pm
nitrocaster wrote:This program adds its icon to the system tray. Its menu is pretty much self-explanatory and straightforward.
Thank you :)
nitrocaster
#233 Post by nitrocaster » Mon Feb 20, 2017 5:45 pm
Probably no. I updated the first post.
mr.rhtuner
#234 Post by mr.rhtuner » Tue Feb 21, 2017 10:32 am
If anybody has a kit they purchased and no longer need, please let me know.
dotsha747
#235 Post by dotsha747 » Thu Feb 23, 2017 7:03 am
Guess I have missed the window to order.
Would be interested if there is a third batch.
renixreborn
#236 Post by renixreborn » Thu Feb 23, 2017 1:07 pm
dotsha747 wrote:Guess I have missed the window to order.
Yeah me too.
mr.rhtuner
#237 Post by mr.rhtuner » Thu Feb 23, 2017 2:29 pm
Truthfully, even if Nitrocaster makes a 3rd batch, selling them on ebay will be very easy. There was a kit on there a few weeks ago, 3 of them I believe and they were selling for a bit more than what he is asking.
I would possibly even consider two, depending how the first install goes.
Starlight5
#238 Post by Starlight5 » Fri Feb 24, 2017 8:57 am
So, any chance to get this for X220 tablet? How many touch points will the modded display have, if it's possible?
cherryblue
#239 Post by cherryblue » Fri Feb 24, 2017 10:01 am
Yeah me too.
Me too.
nitrocaster
#240 Post by nitrocaster » Fri Feb 24, 2017 12:51 pm
Starlight5 wrote:So, any chance to get this for X220 tablet? How many touch points will the modded display have, if it's possible?
Probably no. Replacing the LCD is too tricky, because it's glued to the protective glass.
