IIRC, I mentioned that somewhere. Back in the beginning of 2016 I planned to buy one of those kits, but the seller refused to sell me the kit itself (aside from that he wasn't particularly responsive at all) so I started my own project. Eventually I got a pre-owned Chinese kit and found that for some reason it doesn't work with my AUO display. It also had a pretty cheap and unreliable design which I couldn't trust without gluing the adapter board to the motherboard with epoxy, which I didn't really want to do.frstua wrote:Found this on Taobao:
http://taobao.ua/p/0U3FO9aCKdQba
But didn't found any info about this on youtube or somewhere else (except chinesse forum).
What do you think?
nitrocaster
nitrocaster
What do you mean by a 'battery slab'? A slice battery?boutch55555 wrote:I noticed some weird behaviour using the battery slab. No picture in bios when plugged on boot, lose image in Windows when inserted. It does work in Debian though, both from boot & inserted. Tried changing the default display in bios, same result. Is the fix just covering all the DOCKB_* pins (every odd pin 69-105) ?
boutch55555
Yeah, the 19+ slice.
nitrocaster
Check if it has DP#2 pins. If so, they have to be taped.
I'd like to be in on the 3rd batch as well. Just got my X220 and it's a great machine for my uses but 1366x768 is killing me after being used to a 1920x1200 display the last few years.
EDIT: Or if anyone wants to give up their spot in line I'll gladly take it
Just a curiosity, what is the general time window for development for the tablet versions?
Would we be able to help in some way, possibly to chip in for a motherboard for you, @nitrocaster? Certainly no rush.
How can this be done? Which pins do I have to tape? What does tape mean?nitrocaster wrote:Wrong. You can always dock with single DP station and you can also dock with double DP station after you tape certain pins inside the docking connector. The manual has to be updated on that, as inq mentioned.TankPad wrote:I could be wrong, but i think the whole point is that the new FHD screen IS your docked output, so you lose the ability to dock by using the kit. I'm open to correction on that, but that's the understanding i got.
nitrocaster
inq: ATM I don't have good pictures that could help you understand that, but I'll try to find time and add a note on that to the manual. Maybe some experienced users like boutch55555 could figure that out and post some pictures too.
About a month to make a prototype. The motherboard itself won't be enough - you need to fit the adapter board so that it doesn't get in the way of installing the keyboard and makes possible to use the same eDP cable that I ship with non-tablet kits.phage wrote:Just a curiosity, what is the general time window for development for the tablet versions?
boutch55555
Like this : http://imgur.com/XjGmbz3inq wrote:How can this be done? Which pins do I have to tape? What does tape mean?
Zoom in, you need to put tape between the red lines. I put too much but don't care since they aren't used for the battery, only for dock.
Any update on the March 15 ~ETA? Was the last Google Form a preorder thing? I'd like to know if I'm on it..
T43p - M 770(2.13GHz), 2GB RAM, 60GB HDD, 15in 1600x1200 LCD, 128MB ATI FireGL V3200, CD-RW/DVD-R Multi-Burner, Intel 802.11abg wireless(MPCI), Bluetooth/Modem(CDC), 1Gb Ethernet(LOM)
Ah, thanks for the info. Looking forward to building one of your kits.nitrocaster wrote:Wrong. You can always dock with single DP station and you can also dock with double DP station after you tape certain pins inside the docking connector. The manual has to be updated on that, as inq mentioned.TankPad wrote:I could be wrong, but i think the whole point is that the new FHD screen IS your docked output, so you lose the ability to dock by using the kit. I'm open to correction on that, but that's the understanding i got.
| 701c | X220 | T420 | X230 | T430s |
BalthazzarCorr
Hey I am new here and I was wandering do you have a set number manufactured (pre-ordered) . I am very interested of your kit
vim_all_day
Greetings! New member here. I discovered this thread via Reddit and am very interested in an FHD upgrade kit for my X220.
Thanks for the great work, can't wait to get this thing upgraded!
TheChuckster
How goes the fuses?
SlavicPolski
Been interested in this topic and even thought of trying to make my own adapter pcb but then I saw people were already doing this!
I am willing to sign up for one of your batches when one becomes available and order it on the spot.
How active is the OP in terms of progress updates and batch production?
vim_all_day
OP is fairly active, I think it's suppliers that take some time. I'd be interested in making my own PCB as well, but it's a bit over my head...SlavicPolski wrote:I am willing to sign up for one of your batches when one becomes available and order it on the spot.
3rd batch should have been sometime this month, but so far nothing.
boutch55555
So, I finally fixed rewt's kit, it's installed on a i7 x220 motherboard so I listed it on ebay : http://www.ebay.ca/itm/-/332168181597
Since I don't like making too much money off other people's work, the first 30$ will go to rewt to pay for the kit (I already sent 20$). The next 110$ will pay for the motherboard. Next 50$ is for my time fixing it. Anything over that will be split 50/50 between nitro and myself.
life_on_marx
Hello everyone and congrats to nitro for the amazing job that he has been doing.
I would like to sign up for one of your batches when one becomes available and order it on the spot.
theterminator93
At this point all I want is to make sure I have it ready to go before a trip to Japan at the end of October...
snottierwhale
Hey I'm new here, I saw this mod on reddit. I'm definitely interested in picking up one of the next mods. I ended up with the TN panel so that is the only thing I am unsatisfied about. Got a new keyboard (kinda wish i got backlit), 12Gb of ram, and today i just got a 256gb 850 evo. This laptop is great on Arch.
paperfactory
Did anyone get the modkit running in a hackintosh macos environment?
Everything seems well till the apple loading screen, then the screen goes black.
Could it be that the system doesn’t get the right EDID?
nitrocaster
I guess that's something with the display config, like it starts in dual display mode but then switches to single display mode. Hook up an external display and see what's happening.
TheChuckster
What DE/WM are you using? Might consider installing Arch on mine as well.snottierwhale wrote:Hey I'm new here, I saw this mod on reddit. I'm definitely interested in picking up one of the next mods. I ended up with the TN panel so that is the only thing I am unsatisfied about. Got a new keyboard (kinda wish i got backlit), 12Gb of ram, and today i just got a 256gb 850 evo. This laptop is great on Arch.
recyclojunk64
Also running Linux here, Manjaro (which is based on Arch) with KDE on my x220t. Can't recommend KDE enough, I'd say it's the best DE in existence for anyone who's a power user. There's features and customisations for pretty much everything (just look at kwin-rules for example) and the theming is very consistent, even with GTK applications. There were quite a lot of bugs when KDE 5 first came out, but as of 5.9 it's relatively bug-free.TheChuckster wrote:What DE/WM are you using? Might consider installing Arch on mine as well.snottierwhale wrote:Hey I'm new here, I saw this mod on reddit. I'm definitely interested in picking up one of the next mods. I ended up with the TN panel so that is the only thing I am unsatisfied about. Got a new keyboard (kinda wish i got backlit), 12Gb of ram, and today i just got a 256gb 850 evo. This laptop is great on Arch.
I'm not in that much of a hurry, I think I'll wait it out for the tablet version kit. Did you want any pics of the inside of the multitouch version tablet screen?nitrocaster wrote:If that's true, I could take an attempt to make a prototype. In tablet versions of X220/X230 LCD cable is combined with the camera cable. Since I'll be using standard eDP cable, camera cable would have to be separated from the combined cable and connected to the adapter board. Anyway, I would need to get a working tablet to design and test the kit. If you want it right now - use plain X220/X230.
snottierwhale
I'm using xfce4. I switched from mate(on laptop) and gnome(desktop). It is low on resources but provides great functionallty.TheChuckster wrote: What DE/WM are you using? Might consider installing Arch on mine as well.
TheChuckster
Ah, I was looking at Openbox. Used to be a huge Fluxbox fan back in the day when I was still running Gentoo. Wonder how FHD mod will fare with Linux.
nitrocaster
Good news: I got the fuses.
Good news!nitrocaster wrote:Good news: I got the fuses.
So, the pre-order will be opened soon?
nitrocaster
Not really. Today I finished assembling 24 boards (from 120). I hoped to complete it quickly by using a stencil (which became much more important since the new design uses smaller passive components), but I'm not getting a sustainable quality, so for now I just solder every single part manually. But I'll try to find a way to use a stencil again.
With the first batch I begun to accept payments after the whole batch was ready. Maybe it would make sense to split the current batch into sub-batches and dispatch them separately. We'll see.
Great stuff. Looking forward to hearing more on these.
- 3314 Views
Last post by jaspen-meyer
Fri Apr 14, 2017 9:34 am
WTB Feeler: W530 T530 FHD 1080p Models - Also, how to fine tune Ebay search for them?
by crashnburn » Tue May 16, 2017 9:51 am » in Marketplace - Forum Members only - 5 Replies
- 382 Views
Last post by RMSMajestic
Wed May 17, 2017 2:56 pm
Upgrading X220/X230 to WQHD 1440p
by nitrocaster » Mon Dec 26, 2016 6:45 am » in ThinkPad X200/201/220 and X300/301 Series - 18 Replies
- 3721 Views
Last post by crashnburn
Wed Mar 29, 2017 3:10 am
BUYING: Willing to buy Nitrocaster X230 FHD mod board at over 2x cost
by TheChuckster » Fri Feb 24, 2017 2:01 pm » in ThinkPad X200/201/220 and X300/301 Series - 0 Replies
- 1777 Views
Last post by TheChuckster
Users browsing this forum: ethink and 6 guests
