Yesterday the package arrived!
The removal of the resistor (x220 I7) was the most difficult part, followed by the sense wire. But after all the mod is quite easy to do!
Very happy with the full hd display! Thank you very much!
I only have a 1 pixel vertical line in the screen, not sure if it's the cable or screen... Will do some research tomorrow.
Tomorrow I'll try to tape the pins of my dock. Is there any guide? I saw a picture, but it wasn't very clear which 2 pins should be untaped?
On my X230 with FHD-mod, BIOS Config/Display is set to Thinkpad LCD.mr.rhtuner wrote: ↑Mon Jun 12, 2017 6:57 amANY FEDORA/LINUX USER'S WITH THE FHD MOD?
My one existing issue is with fedora. When I bootup, I need to press FN+F7 to switch displays to cycle to the display showing the fedora login.
I'm unsure how to get Fedora to use this new FHD display as the primary display for the OS boots up.
Running W7-Pro/SP1 64-bit with 8GB RAM, 256GB mSATA SSD(W7) and 500GB/7200rpm(Storage).
The storage HD (in the main bay) is set to power off after 3 minutes of non-use, to save battery.
In W7 there were NO display changes made at all (other than resolution lowered to 1600x900).
When I first started this mod, there were all sorts of instructions/discussions/questions about Windows Display Settings:
- Dummy Display
- Mobile Display
- External Display
- Multiple Displays
- Duplicate Desktop
- Extend Desktop
- DP0/DP1
etc.
In the end I ignored every single one of the above discussions, left everything as it came, and it's working great OOTB.
That is with almost 99.9999% an LCD problem with a column-connection that has become unstuck.
All along the top of the screen, the electronics from the backside PCB are connected to the liquid crystal layer.
The smallest distortion/pressure/knocking can cause such a disconnect.
You could try to gently rub along the top of the LCD where that line is, to get it to disappear.
Or get it "reconnected" by putting something (a folded piece of paper might be all that's needed) between lid and LCD-rear.
nitrocaster
I got the rest of the 2nd batch assembled (70 pcs), so some of you will be reading payment emails soon!
Which laptops can the LCD come from for installation into an X220?
I have the original display, so I have the rails, but apart from X240 I'm not sure which laptop screens to look for. I want to browse some classifieds and look for dead laptops with the correct screen.
Nevermind, at $60 it'll be best to buy from china.
nitrocaster: Are any kits still available?
Thinkpad W500 4063-VA4 CD2 Penryn 2,80GHz, 4GB RAM, 320GB HDD, 15.4" WUXGA, FireGL V5700, Win7u
Thinkpad R60 9461-DXG P-CD2 1,83GHz, 2GB 667MHz, 100GB HDD, ATI X1400@512MB, XP2 Pro
Thinkpad T23 2647-AG0 PIII M 1,13GHz (512KB), 256MB RAM, 20GB HDD, XP2 Pro
nitrocaster
They're all pre-ordered, but the 3rd batch is coming soon.
When can i order the batch 3?
Can I get the batch3 if I write pre-oreder form now?
I am having a similar problem, only with two columns that occasionally flicker blue or yellowish colors and then go away after a second or two. I suspect you're right about this since the black cover material for the display's logic board looks sort of roughed up and scuffed on the left (the same side of the screen as the afflicted columns). I hope I can fix mine. I'd hate to have to buy another.RealBlackStuff wrote: ↑Wed Jun 14, 2017 7:12 amThat is with almost 99.9999% an LCD problem with a column-connection that has become unstuck.
nitrocaster
Read the first post, please.
- 3314 Views
Last post by jaspen-meyer
Fri Apr 14, 2017 9:34 am
WTB Feeler: W530 T530 FHD 1080p Models - Also, how to fine tune Ebay search for them?
by crashnburn » Tue May 16, 2017 9:51 am » in Marketplace - Forum Members only - 5 Replies
- 382 Views
Last post by RMSMajestic
Wed May 17, 2017 2:56 pm
Upgrading X220/X230 to WQHD 1440p
by nitrocaster » Mon Dec 26, 2016 6:45 am » in ThinkPad X200/201/220 and X300/301 Series - 18 Replies
- 3721 Views
Last post by crashnburn
Wed Mar 29, 2017 3:10 am
BUYING: Willing to buy Nitrocaster X230 FHD mod board at over 2x cost
by TheChuckster » Fri Feb 24, 2017 2:01 pm » in ThinkPad X200/201/220 and X300/301 Series - 0 Replies
- 1777 Views
Last post by TheChuckster
Users browsing this forum: ethink and 6 guests
