Just bought that computer and want to know what power adapter will work with it? I don't know what is the correct voltage, wattage or plug sizekfzhu1229 wrote:As for the extra VRAM, I didn't notice much difference. Just the number looked more pleasing to my eyes,,,Whitieiii wrote:The A30p board will work in the A31p? I don't know how much they go for... does the extra vram make much difference? If not than i don't need the A30p... i was gonna put 512mb and 256mb sticks of regular ram in it anyways
The casing for A30 series and A31 series are the same, just the thermal sponge under GPU and northbridge is a bit different.
Also what kind of thing are you going to do with it? I think A3x's ATI Radeon GPU is slower in Windows 98 than even in Windows 7 and I have 3DMark01 benchmark results to prove that.
If you want something that looks vintage, go for 390X or the numbered series. A3x is basically the transition from vintage to modern while a numbered series (other than 240 series) cannot even be turned on by today's people (power button is on the side lol)
Anyways if you still want A30,
I think you REALLY should check this out:
http://www.ebay.ca/itm/IBM-ThinkPad-A30 ... Sw4DJYjp6Y
This computer is likely to have the higher SXGA+ resolution which is good but finding a Windows 98 driver that supports that resolution takes a pair of keen eyes.
If you are in luck, F9 in the BIOS setup or unplugging devices may fix the resource conflict problem. Otherwise I think this down below will be cheaper than my offer for motherboard replacement if you understand Italian (I spent around $40 on mine because the shipping took 3/4 of that price!):
http://www.ebay.ca/itm/IBM-Lenovo-Think ... Sw2xRYfJQ5
You see the thing is it is IMPOSSIBLE for you to get A30p or A31p motherboard on eBay. I was only lucky last time because that seller marketed my A30p board as A30 motherboard (they only had 4, I ordered 2, another forum member ended up getting the other two which turned out to be defective)!
I think this depends on you. The eBay one is definitely cheaper but if you are not experienced with disassembling these models (even with IBM's manual in the HMM page), I or someone else in this forum may be the one to go.
I can also offer you 2x256mb sticks for free if you decided to go with my unit.
looking to go with an older thinkpad
Re: looking to go with an older thinkpad
My Current Thinkpad Collection:
A30 Pentium 3 512MB ram 55 or 58GB HDD Win 98SE
T410 1st Gen i5 4GB ram 2x320 GB HDD Win XP & 7 Pro
X220 2nd Gen i5 8GB ram 120 GB SSD win 7 Pro
T430 3rd Gen i5 6GB ram 500GB HDD Win 7 Pro
T440s 4th Gen i5 8GB ram 300 GB SSD win 10 Pro
Any IBM adapter from that era will do. I am personally using the one from my T42 and T43 and it works just fine.
It is the 16V barrel connector that you typically see in almost all ThinkPads (Except for G series) from that era...
Also you can try docking it into a port replicator or dock if you simply CANNOT get the correct adapter.
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
Flexview UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10
Flexview UXGA:
ok like this one?kfzhu1229 wrote:Any IBM adapter from that era will do. I am personally using the one from my T42 and T43 and it works just fine.
http://www.ebay.com/itm/GENUINE-IBM-Len ... Swo4pYMQzQ
I would suggest you buying them in bulk if you decide to hit eBay.
Before buying that one, I would suggest you to go to some kind of local theft store or recycling center and see if they are trying to discard a ThinkPad or something and you may be able to find an adapter for free!
Flexview UXGA:
Flexview UXGA:
true... but will that one work for now?kfzhu1229 wrote:I would suggest you buying them in bulk if you decide to hit eBay.
https://1drv.ms/i/s!At7-rt1KJ7WviMtsVN9Y-0w1u-IF2Q
These are the adapters I am using all the time. 4 adapters with 3 different PNs lol...
Yes I have one adapter out of those four with the same PN in your eBay result
Flexview UXGA:
Flexview UXGA:
WTB: older intel 486 Thinkpad & PPC
by enc0re » Mon Feb 27, 2017 11:17 am » in Marketplace - Forum Members only - 0 Replies
- 1018 Views
Last post by enc0re
- 7 Replies
- 701 Views
Last post by LarBob
Thu Feb 23, 2017 6:44 pm
T460P with 940MX graphics for older games
by Whitieiii » Wed May 31, 2017 6:43 pm » in ThinkPad T430/T530 and later Series - 5 Replies
- 271 Views
Last post by umern
Tue Jun 06, 2017 5:31 am
Looking to buy a cheap Thinkpad.
by Lovele » Wed Feb 08, 2017 12:09 pm » in GENERAL ThinkPad News/Comments & Questions - 6 Replies
- 685 Views
Last post by TonyJZX
Sat Feb 11, 2017 12:06 am
