T420s/T430s WQHD kits pre-order
Re: T420s/T430s WQHD kits pre-order
Does this have the flicker issue?
According to @rmsmajestic it does (I'm assuming the T420/T430 adapters that were made from -S boards), but less to an extent compared to the v1 of Javi's T420/T430 FHD mod.
Then again the V1 did work with zero issues for some people. So YMMV.
pathan421id wrote: ↑Mon Feb 12, 2018 1:31 pmT420-S/T430-S FHD kit adapted for T420/T430 is available through ebay and aliexpress now. Copy of javi's FHD kit.
https://www.ebay.com/itm/162887293940
https://www.aliexpress.com/item/LCD-con ... autifyAB=0
Can we stick to the topic at hand...the WQHD kit from RMSMajestic?
If you want to discuss FHD, why not create or add on to a previous thread?
Update for those running coreboot (like me). Native graphics initialization and libgfxinit both result in more or less distracting display errors, but both work well enough to enable normal booting with grub. To get perfect graphics during boot, use a VGA Bios Option ROM (How do I get the rom?) with vesa mode 0x037e for 16bit full resolution.
because that thread is locked?mr.rhtuner wrote: ↑Tue Feb 13, 2018 9:41 ampathan421id wrote: ↑Mon Feb 12, 2018 1:31 pmT420-S/T430-S FHD kit adapted for T420/T430 is available through ebay and aliexpress now. Copy of javi's FHD kit.
pathan421id wrote: ↑Tue Feb 13, 2018 6:43 pmbecause that thread is locked?mr.rhtuner wrote: ↑Tue Feb 13, 2018 9:41 am
So create a new thread?
I just finished installing an AUO B140QAN01.1 in my T430s and it appears to work (Kubuntu 16.04, no coreboot). It does have the same screw hole misalignment issue reported by mithodin with his B140QAN01.5. Like mithodin, I'm relying on the screen bezel to keep the bottom portion of the screen in place and it appears to be working. Brightness, viewing angles, higher resolution -- all very nice indeed. I work mostly while plugged in so I'm not worried about the increased power draw. I didn't take any before-and-after measurements of heat or fan noise but subjectively I don't feel/hear a difference from when I was running with the stock screen.
In truth, WQHD is an insane resolution on a 14" screen for my eyes, so I'll likely end up reducing resolution or messing about with scaling, but all in all I'm quite happy with this upgrade. Updating fubu's spreadsheet now. Many thanks to RMSMajestic for facilitating this and to the members of this forum for contributing such good and useful information!
^ this is one of my worries....
Such a high resolution on 14" real estate...I have good eyesight but still...
I'm loving the FHD mod...1920 x 1080...
Whelp, I bought the kits and screens...might as well try one...
How are everyone's temps? I seemed to have +5C/+10C for idle/load temperatures moving from HD+ to WQHD.
decaba wrote: ↑Tue Feb 13, 2018 9:29 pmI just finished installing an AUO B140QAN01.1 in my T430s and it appears to work (Kubuntu 16.04, no coreboot). It does have the same screw hole misalignment issue reported by mithodin with his B140QAN01.5. Like mithodin, I'm relying on the screen bezel to keep the bottom portion of the screen in place and it appears to be working. Brightness, viewing angles, higher resolution -- all very nice indeed. I work mostly while plugged in so I'm not worried about the increased power draw. I didn't take any before-and-after measurements of heat or fan noise but subjectively I don't feel/hear a difference from when I was running with the stock screen.
Did you take any photos of the install to share by any chance?
Did the Upgrade for my t420s today using LP140QH1 SP B1 and it is AWESOME! Everything works perfect (Windows 10 and ubuntu). For me I can't report any changes in temperature. It is even a bit lower than before but I credit this to my fan cleaning while doing the upgrade (Around 60°C in IDLE with 0-1900RPM fan).
Thanks so much!
Thanks so much!
Sorry, I only took three pre-install photos to help me remember where the antenna wires go plus one showing the serial number of the panel. Not sure they'll be worth much to anybody but here they are: https://imgur.com/a/1vgem.mr.rhtuner wrote: ↑Sat Feb 17, 2018 10:00 amdecaba wrote: ↑Tue Feb 13, 2018 9:29 pmI just finished installing an AUO B140QAN01.1 in my T430s and it appears to work (Kubuntu 16.04, no coreboot). It does have the same screw hole misalignment issue reported by mithodin with his B140QAN01.5. Like mithodin, I'm relying on the screen bezel to keep the bottom portion of the screen in place and it appears to be working. Brightness, viewing angles, higher resolution -- all very nice indeed. I work mostly while plugged in so I'm not worried about the increased power draw. I didn't take any before-and-after measurements of heat or fan noise but subjectively I don't feel/hear a difference from when I was running with the stock screen.
Would be nice to know if the B140QAN02.0 HDR from the X1C6 works which apparently is quite nice (https://www.notebookcheck.com/Test-Leno ... vision-hdr)
Silly question, but for those who have received their kit already AND ordered through PayPal, did you get a shipping notification through PayPal? Or did the kit just show up at your house?
I got a notification with tracking number on January 30 and the kit arrived on February 1.
Just installed B140QAN01.5 in my t420s
in bios it works fine, but in Windows I see black screen.
Can someone help me?
fixed with reflashing original bios.motoyarko wrote:Hello,
doesn't work correctly with custom bios that unlocks 1600 mhz memory on t420s. or maybe need to do some extra settings in modded bios. thanks for the great kit
mithodin wrote: ↑Sat Feb 10, 2018 7:16 amGot it off German ebay from ftdlcd. https://www.ebay.de/itm/14-QHD-LED-LCD- ... 2799608880
Although it is listed as B140QAN01.5 or compatible, so it was a bit of a gamble getting that one.
Hey mithodin, how long did the shipping take? On ebay it says over 1 month but that seems too long.
You're not alone. Bought on Dec. 26, haven't received a tracking number or a package yet...
X62s 3rd batch, [s]T61[/s] T70 14" 4:3 1st batch
Have patience, Chinese New Year was just a short while ago and everyone is off for the time being.
We'll get them soon enough!
If you are in fairfax, VA, I can come and do the installation for you if you want lol
I tried to remember sending an email notification when I print labels. But can't always remember.
You should have got a tracking number by now... I will try to drop off the packet at Post Office today, if my work don't get tooo crazy.
Just updated the tracking number
Order processed up to Jan.15th. Will move on tomorrow.
If your order is placed before Jan.15th and there's nothing wrong with your address, you should be able to see a tracking number by now.
I swear I will never ever go back to China during the chinese new year time again......
No shop is opening. (Couldn't even get my hand on a few other X62 and T70); Annoying relatives asking me about my girlfriend; and I take time off during the most intense time of a project at my work
FML >_<
I just hope that I don't accidentally step on my tester screen among this mess in the next few days
I am, thank you very much! I've received the mail today.RMSMajestic wrote: ↑Mon Feb 26, 2018 3:10 amOrder processed up to Jan.15th. Will move on tomorrow.
Do you have an updated display compatibility list?
ThinkPad T430s
FS: TP T700 i7-1165G7 Crowdfunding [W] Paypal Pre-Order
by lulujyc » Mon Aug 24, 2020 5:16 am » in Marketplace - Forum Members only - 5 Replies
- 1193 Views
Last post by RMSMajestic
Tue Oct 20, 2020 11:11 pm
Lenovo Thinkpad X1 Carbon 2nd Gen (20A8) WQHD Touchscreen Replacement Advice Sought
by juicy » Tue Jul 28, 2020 7:08 am » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 0 Replies
- 1964 Views
Last post by juicy
T480 - WQHD upgrade using the FHD, non-IR lid
by tchalikias » Sat Aug 08, 2020 1:13 pm » in ThinkPad T430-T490 / T530-T590 Series - 3 Replies
- 2287 Views
Last post by tchalikias
Sun Oct 11, 2020 7:02 am
X230 WQHD adapter card repair
by la-luva » Thu Oct 08, 2020 4:30 am » in ThinkPad X230-X280 / X390 Series - 1 Replies
- 1146 Views
Last post by la-luva
Thu Oct 08, 2020 4:47 am
