T420s/T430s WQHD kits pre-order
Re: T420s/T430s WQHD kits pre-order
In quick summary, possible panels for the adapter:
- LG LP140QH1-SPB3 ??? not listed anywhere.
- LG LP140QH1-SPB1
- AUO B140QAN01.1
- AUO B140QAN01.5
LG LP140QH1-SPB1 vs AUO B140QAN01.1
http://www.panelook.com/modelcompare.ph ... 1975,25359
Measurements by Notebookcheck (source LG, AOU)
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Interesting differences:
- tech: IPS vs. AHVA
- brightness: 300 vs. 340 cd/m2
- color gamut: 60% vs. 72% NTSC
- response time: 35 vs 30 ms
- LG LP140QH1-SPB1
- AUO B140QAN01.1
- AUO B140QAN01.5
Another interesting option might be the 500 nit, 100% Adobe RGB panel from the new X1C.
X62s 3rd batch, [s]T61[/s] T70 14" 4:3 1st batch
Yes, it is really good option. Big question is the price and availability.
My previous post updated with Notebook check measurements.
Any chance that a Panasonic VVX14T058J00 panel (WQHD used in T670s) will be compatible with this kit?
Probably not the best panel, but might be cheaper than the best panels.
IBM X20, X40, X41T, X60s, X61s, R52, T40, T42-IPS, T43, T60, T60p-IPS, T61, T61 QXGA-IPS (T60 body + T9500, Intel GPU, 250GB SSD, 8GB, Win 10 Pro)
Lenovo X230-IPS, X301, T420s, T430s-IPS, T440s-IPS, W500, W700, T520, Slate Tablet
Non-TP: Google Chromebook Pixel 2013, Surface 4 Pro
I missed it...
How did I miss it...
I lusted so hard for this upgrade kit...
As I type this on my T61 because my T420s is being a miserable butt munch.
T61 14.1 WXGA+ 220nit, T9300, Owl blade fan cooler, 8GB PC2-6400, 2010 revised NVS140M, Samsung 840Pro 240GB, AR9390 N, BT4.1, NMB keyboard, T400 palm-rest, 33++ battery.
T420s 14.0 HD+, i7-2460M, 16GB PC3L-12800, NVS4200M, Samsung 850Pro 512GB, Intel 7260AC, BT4.1, Chicony KB, 81+ battery
OKay guys! Kits are finally in. Thank God!
I will be testing and posting in the following week!
I will also post a Etsy listing later, since I'm so fed up with feebay. For those of you who don't trust me or paypal, you have another option.
Please post what screens you used to test!
I'm gonna use LP140QH1(SP)(A2)
- Moderator
Great news! I'm so looking forward to this
It think it would be good to add the list of compatible panels on the first post, just for the sake of clarity...
Really good news.
My LP140QH1(SP)(B1) ready to install.
For those of you who are fed up with feebay but still wanna a third party gurantee
Price is $67.5 as of now. I'm uncertain whether Etsy would be a PITA like feebay or not. But if it turns out to be reliable the price would only slightly (~$1-2 ) more than paypal
Etsy link:
https://www.etsy.com/listing/588618811
Etsy link:
Oh.. More kits... Drool... End of the month can't come soon enough!
So these are only compatible with T420s/T430s right?
Cheers!
Cheers!
Yes, and unfortunately parts are not interchangable with the FHD kitsSaskFellow wrote: ↑Wed Jan 24, 2018 1:25 pmOh.. More kits... Drool... End of the month can't come soon enough!
Cheers!
I'm very excited to do this upgrade. I bought a T430s to replace my crappy Samsung Ultrabook, and it's already way more fun to use. A nice screen will make this an absolute dream machine
woot!! I'm excited....so excited!
Now the dilemma for me is - do I keep my T420s i7 (it heats up quickly for some reason) or do I try and procure a T430s i7 for a good price and mod that one? Thinking the T430s will be better in terms of power handling and performance?
And I can do the keyboard mod on the T430s....just may need to find someone to help with the security chip thingy so I can use a whitelisted AC7260 Wifi card....
I have sucessfully installed coreboot on my T430s - so no problem with wifi-cards at all
. It is very likely though that you need to do some soldering, because the original bios eeprom is not easily accessible with an external programmer.
Long time lurker and finally registered so I could say thanks for doing this upgrade!
Ordered one through the PayPal link a few minutes ago
The search for a screen begins!
@rmsmajestic When will T420 and T430 kit (non-S) be available?RMSMajestic wrote: ↑Wed Jan 24, 2018 9:16 pmYes, and unfortunately parts are not interchangable with the FHD kitsSaskFellow wrote: ↑Wed Jan 24, 2018 1:25 pmOh.. More kits... Drool... End of the month can't come soon enough!
Cheers!
I haven't heard back from you.
Thanks in advance.
Apparently the S kit can be used on a regular non-S device as shown here.
https://item.taobao.com/item.htm?spm=a2 ... t=5#detail
That's a copycat of Javi-Jie's work.... And it will alleviate, but not completely resolve the problem.pathan421id wrote: ↑Sun Jan 28, 2018 5:14 pmApparently the S kit can be used on a regular non-S device as shown here.
RMSMajestic wrote: ↑Sun Jan 28, 2018 7:32 pmThat's a copycat of Javi-Jie's work.... And it will alleviate, but not completely resolve the problem.pathan421id wrote: ↑Sun Jan 28, 2018 5:14 pmApparently the S kit can be used on a regular non-S device as shown here.
Not completely?
By "will alleviate" do you mean it at least has better resistance to flicker compared to the initial T420/T430 FHD mod?
Whoo, I just got my tracking code. I guess this means I can order a screen now? I have a decent offer for a B140QAN01.5
Errrr I'd suggest not. But if the price is less than $70 then go for it
Yes. Javi has thought about that workaround but it is not 100% fail-proofpathan421id wrote: ↑Mon Jan 29, 2018 1:55 amRMSMajestic wrote: ↑Sun Jan 28, 2018 7:32 pm
Not completely?
I'm sitting on nails until my tracking number arrives and after that until the adapter arrives.
Quantumcross wrote: ↑Mon Jan 29, 2018 12:46 pmDoes anyone have any information on this panel? Is there a Maintenance manual out for X1C 6th gen?
I don't think so, the computer isn't even available in the US/JP yet.
RMSMajestic wrote: ↑Mon Jan 29, 2018 10:27 amYes. Javi has thought about that workaround but it is not 100% fail-proofpathan421id wrote: ↑Mon Jan 29, 2018 1:55 am
Not completely?
Ok thanks for the info.
Update in policy:
If you wanna ask for troubles by enabling fast boot or secure boot, you should solve the troubles you asked for by yourself.
No zuo no die
No zuo no die
How are fast boot / secure boot relevant to this display mod kit, and what problems can they cause?RMSMajestic wrote: ↑Tue Jan 30, 2018 1:35 amIf you wanna ask for troubles by enabling fast boot or secure boot, you should solve the troubles you asked for by yourself.
Secure Boot - maybe (does it apply more strict checks to display EDIDs or something?), but Fast boot? That's just a mix between Hibernate and Shutdown.
X61 7673-V2V, T60 2007-QPG, T42 2373-F7G, X32 (IPS Screen), A31p w/ Ultrabay Numpad, A21m 2628-GXU
FS: TP T700 i7-1165G7 Crowdfunding [W] Paypal Pre-Order
by lulujyc » Mon Aug 24, 2020 5:16 am » in Marketplace - Forum Members only - 5 Replies
- 1223 Views
Last post by RMSMajestic
Tue Oct 20, 2020 11:11 pm
T480 - WQHD upgrade using the FHD, non-IR lid
by tchalikias » Sat Aug 08, 2020 1:13 pm » in ThinkPad T430-T490 / T530-T590 Series - 3 Replies
- 2395 Views
Last post by tchalikias
Sun Oct 11, 2020 7:02 am
X230 WQHD adapter card repair
by la-luva » Thu Oct 08, 2020 4:30 am » in ThinkPad X230-X280 / X390 Series - 1 Replies
- 1236 Views
Last post by la-luva
Thu Oct 08, 2020 4:47 am
Adjusting brightness in Pre-OS environment on a T410, is it possible?
by bluesteel649 » Sun Nov 08, 2020 11:41 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 8 Replies
- 1147 Views
Tue Nov 10, 2020 10:22 am
Users browsing this forum: djammin16 and 19 guests
