WiFi Keeps disconnecting
Re: WiFi Keeps disconnecting
Thanks everyone for your help and suggestions. Hopefully that's it working now.
I think two antennas are used either alternatively e.g. whichever achieves better signal is used or perhaps simultaneously for higher bandwidth. It totally makes sense that with only one antenna it worked but less reliably. Good find! Hope it works now. The other part of the original suggestion was to disconnect 1st antenna too, do some IPA cleaning - both on socket and cable and connect it back. Well if things work without it - so much the better. I may need to attempt this myself on this Samsung Note 3 - works but isn't as good as other phones at connecting to cellular network.. Or maybe I just need to flash a fresher "baseband" - firmware for cellular part of the phone..
X220, 2 *T520
Unless it's an engineering sample, all wifi cards should use 2 (some even 3) antenna wires.
One method that helped my AC-7260 disconnecting at random was:
go into Device Manager, rightclick your wifi-card, select Properties, select Advanced tab,
and set ARP offload for WoWLAN to Disabled.
Still NOT a great day for a Guinness! (the Real Black Stuff).
Ireland is on FULL lockdown until Easter 2021!
Covid-19: Stay safe, so Mask it or Casket!
Hi
It seems to be working fine now. The link to the video I posted showed that when the guy was changing his WiFi adapter the 2 wires were connected when he opened the laptop up. Surely that means that 2 wires are meant to be connected. Thanks again for all your help and suggestions.
w520 keeps looping back to startup
by elizalew » Mon Oct 26, 2020 4:06 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 4 Replies
- 1468 Views
Last post by elizalew
Thu Oct 29, 2020 3:03 pm
ThinkPad X270 - upgrade wifi to wifi 6?
by Edward Mendelson » Fri Sep 04, 2020 4:21 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 2340 Views
Last post by Edward Mendelson
Sat Sep 05, 2020 6:25 am
T430 WiFi card options
by sktn77a » Sat Sep 05, 2020 1:25 pm » in ThinkPad T430-T490 / T530-T590 Series - 4 Replies
- 2119 Views
Last post by sktn77a
Sun Sep 06, 2020 1:30 pm
- 7 Replies
- 1871 Views
Last post by jaaa
Fri Sep 25, 2020 2:49 pm
