purported 2200bg/2915abg and wrt54g problems
DeionDavid
#61 Post by DeionDavid » Sun Nov 26, 2006 1:32 am
sorry noob question but... what is access connections? where can i find this software?
i happen to have 2200 bg and wrt54g too and my connection is sucking very badly =(
T42 2378FVU - 2GB Ram - 40GB HD 4200 rpm - Windows XP Pro SP2
Hotbrick
#62 Post by Hotbrick » Mon Dec 11, 2006 4:16 am
Access Connections can manage your wireless connection instead of Windows:
http://www.pc.ibm.com/us/think/thinkvan ... tions.html
Download:
http://www-307.ibm.com/pc/support/site. ... zlnjb.html
About the wireless disconnects: I changed the security from WPA -TKIP to WPA2-AES and the problems are gone...( thanks for the tip Flightvector)
( I use the intel 2915 adapter and the WRT54GL with Thibor firmware)
T42p 1GB RAM M745
15" UXGA IntelPro ABG 60 GB
nightyyyy
#63 Post by nightyyyy » Tue Mar 27, 2007 4:54 pm
i had disconnect issues with a wrt54gs v1.1 and a intel 2100 3b based mini-pci in my x40.
Nothing seemed to help until i figured out that, at least in my case, setting CTS protection to enabled and frame burst to disabled helped:
http://www.nachtrab.de/temp/wrt54gs.gif
Nighty
Acer Travelmate 663LMi 1.6Ghz 2GB 80GB Seagate Momentus 5400.3 15,4'' 1400x1050 Atheros 802.11b/g
IBM X40 512MB 40GB 8cell/4cell 802.11b (2100 3B) Bluetooth
Aopen Centrino Barebone Server 1.6Ghz 1GB 500GB/320GB
Hotbrick
#64 Post by Hotbrick » Sun Apr 08, 2007 6:40 am
Maybe I can take 1 annoyance away for some people having trouble with disconnects using AC....
A friend of me can´t get rid of his disconnects but he discovered that version 4.23 Access Connections does not reconnect by itself, he had to do it manually after every drop out.
Version 4.21 at least makes him able to download at night........
T42p 1GB RAM M745
Kyocera
#65 Post by Kyocera » Mon Apr 30, 2007 3:23 am
I'm one who does networking for a living, almost every small office I go into...Doctors, Dentists, Construction, Tax, you name it I go to it have the good old linksys, usually WRT54G, the percentage of Linksys to Belkin or Linksys to Netgear is not even close, about like Mac to windows. I've seen a couple of linksys routers die, and seen some give up slowly but you can use tools to trace problems right to the router. I have seen some with to high expectations of a standard samll office router, but that has nothing to do with that particular brand.
I too work with a lot of IT and Network Admins and have never heard any seriously negative comments, the only comments I have ever heard like that are on the various forums around the internet that deal strictly with routing and routers, and I could never understand their hatred of the Linksys.
AdaSch
#66 Post by AdaSch » Fri Jun 08, 2007 5:47 am
hello,
maybe new driver solve this problem
Version: 11.01.0 API
Release Date: 2007/06/07
http://www-307.ibm.com/pc/support/site. ... MIGR-62875
br
W500 @ T9900, 7K750, 2GB ITM as TMP :twisted:
aschb
#67 Post by aschb » Fri Jun 08, 2007 1:44 pm
I downloaded the latest version of Intel Pro 2200BG 11.1.0.
The software is downloaded to C:\DRIVERS\WIN\WLANINT2 and does not contain ACSETUP.EXE at all.
Instruction says: C:\DRIVERS\WIN\WLANINT\ACSETUP.EXE
Of course the exe file is not found.
Any problem known?
T43P/M770 2.1GHz/1GB/60GB/15"UXGA/DVD-RW (UC3H2), IntelPRO Wireless 2200bg
AdaSch
#68 Post by AdaSch » Fri Jun 08, 2007 4:14 pm
aschb wrote:I downloaded the latest version of Intel Pro 2200BG 11.1.0.
Any problem known?
use iProInst.exe from WLANINT2\XP\Apps\x32\
br
aschb
#69 Post by aschb » Sat Jun 09, 2007 1:18 pm
I used iProInst.exe from WLANINT2\XP\Apps\x32\ and the program started to remove the older Intel driver (with a warning first). But after a few minutes the program didnt continue (hang up with no disk movement anymore) and I even couldn't terminate iProinst.exe and had to hard-reboot.
Afterwards the Intel Wlan at AC was not available anymore.
Finally I restored my system and everything is in order again (yes, I did a backup before I started iProInst.exe!)
Anyone else with a similar problem?
AdaSch
#70 Post by AdaSch » Sat Jun 09, 2007 1:49 pm
i don't have any problenms with installation, but this driver don't work too good
very often disconnect and don't help option "best network performance"
i back to 9.0.4.33
br
spikex34
#71 Post by spikex34 » Mon Jun 11, 2007 1:58 am
Can't say I've ever had any problems using 2200bg and WRT54G on any number of operating systems.
X200s: 1.86/4/X25E
T43: 1.86/2/5k80
