Latency/freezing on IBM Thinkpad T43
paul_1011
#31 Post by paul_1011 » Fri Aug 26, 2005 3:07 am
I might also give them a call, if enough people ring with the same problem they might do some serious investigation as to the cause of the problem. They might even come up with a solution right away.
Only had my T43 a couple of months and been very happy with it apart from this problem, would be nice to get it fixed completely, but it is far far better now anyway.
bing
#32 Post by bing » Fri Aug 26, 2005 10:23 am
bing wrote:
trpt192 wrote:I think I found a solution to this problem for my computer now atleast. In my t43 I have the intel pro 2915abg card and I thought that the hardware interrupt problems that I was having might be related to the wireless card. It turns out that they released an update for the card, bringing it to version 9.0.2.31 just 2 days ago. I installed the update and for the most part, things seem to run a lot better now. Where windows normally took 3 min. to boot, it now takes about 30 sec.. Also, my music in iTunes seems to run a lot smoother. I hope this is the answer to the problem but if not, it seems to be a good temporary fix. Goodluck to others, I know how much of a pain this can be..........
Thanks. Just installed this now and giving it a runthrough.
Never mind. It's still there.
I find it ridiculous that this problem hasn't been documented by IBM yet, as common as it sounds.
paul_1011
#33 Post by paul_1011 » Tue Sep 06, 2005 9:57 am
Did anyone manage to find a resolution to this problem?
I still have it and its now becoming really annoying.
I have tried to abstain from moaning too much about my T43, but I have to say I think my old T23 is better. A smoother machine with less problems than this one.
Roy_W
Drivers Nightmare
#34 Post by Roy_W » Wed Sep 07, 2005 6:56 am
I have recently finished a clean XP Pro installation. No sign of lagging or slowdown.
I installed many of the IBM utilitys, OnScreen Display, Battery Manager, Power Manager, Key Configurator etc..... I started to suffer some serious lag especially when opening the File Explorer, sometimes I would wait 20 seconds before any drives/files were displayed.
OK, 2 + 2 = One of the IBM Utilitys program/drivess must be stuffed.
Unfortunately I did not record the names of all of the utilitys that I installed
Although I do know that I removed at least the following
  • * The Synaptic Touchpad drivers
  • * The "Battery Log" Blog utility
  • * The Power Manager
Here is an extract of my current registry ( Substitute 'path_to' for your own version)
HKLM\Software\Microsoft\Windows\CurrentVersion\Run
  • 1 :TPHotKey REG_SZ 'path_to'\TPHMGR.exe
  • 2 :TPKBLED REG_SZ 'path_to'\TpScrLK.exe
  • 3 :TPKMAPHelper REG_SZ 'path_to'\TPHMGR.exe
Initially I had at least 10 entrys which I have subsequently reduced to 3, even with this relatively abridged set of utilitys everything is running fine.
I do run AV software ( Sophos ) which proves to be no problem at all.
The hardware drivers for the Bios, Ethernet, Wireless, Bluetooth are the latest IBM downloadable versions.
Hope this helps a little.
IBM ThinkPad T43p.
IBM ThinkPad T41p.
paul_1011
#35 Post by paul_1011 » Wed Sep 07, 2005 8:04 am
OK,
In an effort to pin it down I removed every single startup item which consisted mostly of IBM utilites and tools.
I still had a bit of lag during startup but it seems better. I will add one application back everyday to see if I can pin the problem down that way. I dont have time to go through each.
But to me it seems the lag is caused by hard disk activiity, some kind of hardware interrupt problem.
Roy_W
#36 Post by Roy_W » Wed Sep 07, 2005 10:19 am
Paul_1011
One or Two questions..
1: Are you using the "IBM Park the Disk Heads before the machine hits the floor Software". ie "IBM Active Protection System"
2: Is "Windows System Restore" software turned on or off.
3: Are you using any kind of backup software is Acronis, V2I etc ......
Roy
IBM ThinkPad T43p.
IBM ThinkPad T41p.
Roy_W
#37 Post by Roy_W » Wed Sep 07, 2005 10:48 am
Paul
If you want to understand more about who or what is accessing the Hard Disk
you may want to try FileMon, here is the address
http://www.sysinternals.com/Utilities/Filemon.html
Roy
IBM ThinkPad T43p.
IBM ThinkPad T41p.
paul_1011
#38 Post by paul_1011 » Wed Sep 07, 2005 10:49 am
Roy,
First of all, disabling all startup items has not made a difference, so I dont think the problem is down to IBM software loaded on startup.
1) Yes, but I have just disabled it to see if it makes any difference.
2) Is turned off and has been almost since I started using the machine.
3) No backup software, manually back up "my documents" once a week on to a pen drive.
Roy_W
#39 Post by Roy_W » Wed Sep 07, 2005 3:01 pm
Paul,
Refering back to the Hardware Interrupt possibility I noticed in my Bios Setup that all of the PCI Devices were allocated IRQ 11 which seems just a little strange. I have subsequently changed them to Automatic.
There is also an option for Stopping:Starting DMA Disk Access.
It might be worth trying.
IBM ThinkPad T43p.
IBM ThinkPad T41p.
paul_1011
#40 Post by paul_1011 » Thu Sep 08, 2005 2:14 am
Roy,
My IRQ settings were the same as yours. I have now set them all to automatic also and it seems to have made a big difference.
Im not going to starting couting my chickens yet but it looks like promising start. Will be using the laptop all day so I will report back later.
Paul
